View Full Version : Gap setting for 472 points
limousine rider
04-14-07, 12:07 PM
Whats the recomended setting for points on a 472?
.08 <----- Gap ?
whats your input ?
:thumbsup:
The Ape Man
04-14-07, 01:10 PM
.08 <----- Gap ?
whats your input ?
:thumbsup:
IIRC .017 . Tune-up specs are on this board.
Brother_B
04-14-07, 01:23 PM
Chiltons lists .016" for the point gap. More importantly, set the dwell angle to 30* (28* to 32*), assuming the car is running and you have a dwell meter. Also if it is running, you can try the following alternative method from my shop manual: (1) Turn adjusting screw in (clockwise) until engine begins to msifire. (2) Turn wrench 3/4 turn (270*) in opposite direction (counterclockwise), and then turn clockwise 1/4 turn (90*) to obtain proper gap and dwell.
The Ape Man
04-14-07, 02:27 PM
You set the points then always check dwell. Just setting the gap is half the job. The dwell can be set with the engine cranking and the secondary of the coil grounded if you are quick enough. In other words the car doesn't even have to be running..
limousine rider
04-15-07, 06:50 AM
Thanks, worked out real good !
cadillacmike68
04-22-07, 01:33 PM
Get a tach / dwell meter at Sears or most auto shops - get an old style one that is meant for points / condenser. You also need a 1/8" allen wrench. Lift up the window on the distributor cap and you can adjust the points while the engine is running! Note this only applies to GM V8s from 1968 to 1974 after which they went to HEI.
Yet another example of GM engineering triumphs in the late 60s!
limousine rider
04-22-07, 02:43 PM
Great information! what should the dwell #s range? 800 idle rpm?
cadillacmike68
04-22-07, 07:01 PM
Please read my last post in this thread:
http://www.cadillacforums.com/forums/500-472-425-368/104260-proper-idle-rpms-park.html
I could be all wrong by the way, but I'm probably not ...
