: Chevron Delo 10W-30
jadcock
04-12-07, 12:19 PM
First off, this is not meant to be an oil thread, please don't turn it into one! :bouncy: I simply have three questions about this one particular product.
1) You guys with flat tappet Northstars (1999 and prior) would like this oil, being an SL, due to having more ZDDP, right? (Clark, I know, you like ZDDP!)
2) This oil would still be totally appropriate for my 2001 engine, even though it's a roller tappet Northstar, because it is SL rated, right?
3) I've never seen Delo in anything other than 15W-40, but I know it's sold in 10W-30. Where do you guys buy it in that weight if you do buy it in that weight? How much wood could a woodchuck chuck if a woodchuck could chuck wood?
Thanks.
Ranger
04-12-07, 06:05 PM
2) Yes.
3) It is pretty hard to find, but someone in a recent oil thread said they found some, though I am not sure where. Murrays comes to mind, but I would not swear to it.
Patrick7997
04-12-07, 09:52 PM
I've looked high and low for that 10/30, and never found it...
I use the 15/40 variation and it's fine....
Although what I HAVE found is a 5w40 Synthetic variation of Rotella... I've seen that around... that could be an interesting alternative....
eldorado1
04-13-07, 09:52 AM
^^ I use the 5W40 Rotella T.
Good stuff.
jadcock
04-13-07, 02:21 PM
I saw the Rotella T in 5W-40 at Wal-Mart. But when looking at the spec sheet, the viscosity of that oil is alarmingly high compared with 10W-30 oils. The price was pretty fair for a full synthetic oil, about $4/qt.
I'd still like to find the 10W-30 Delo 400. The viscosity on that oil is higher even than many of the high mileage SL oils, which are already pretty thick compared with the "standard" SM oils out today.
eldorado1
04-13-07, 03:20 PM
Link for both?
jadcock
04-13-07, 03:52 PM
On manufacturer's websites.
jadcock
05-05-07, 08:03 AM
Just wanted to follow up that I found Shell Rotella T in 10W-30 at my...local Wal-Mart. I scoured the shelves before and never found it. Still didn't see it yesterday. But for whatever reason, I started looking at the shelf price tags and noticed that the tag for the 30W Rotella actually said 10W-30 Rotella. Bingo...I had a SKU, so I knew they at least had it in their system. I asked the girl to check in the back and they had a whole pallet of it back there. None on the shelves...
It was a little under $10 for the 1 gallon jug, or $2.50/qt. Great price for a great oil.
Patrick7997
05-05-07, 10:26 AM
I'll have to check the Wally World again....
If I ever see a bottle of that stuff, it'll be a first...
Not that I'm that concerned... the car runs great on the 15w40...
jadcock
05-05-07, 12:48 PM
I put Mobil Delvac (15W-40) in my '97 with almost 160k miles, and it really seemed to LOVE it. I did that about a week before shipping the car off to my brother, and really wish I had tried it sooner. It doesn't get all that cold in NC, but I'm not comfortable running a 15W-40 where a 5W-30 is spec'd (my 2001) without having a lot of miles on it (it has less than 60k). I knew the 15W-40 was going to work great for my brother because he's in Tucson, and the car will be seeing LOTS of +100*F temperatures and very little below 50*F I'm sure.
MonzaRacer
05-05-07, 02:05 PM
HOW do you come up with the ideathat a 5W40 synthetic oil has a greater viscosity index over the 10W30 that your older engines would actually notice?
while yes the 5W40 is slightly heavier after it warms up it should never give that engine any problems.
I know several N*s running rotella contiuosly in the 15W40 range here in Indiana and have no problems and have ran it since new(as we all know and love the antiwear capabilites of Rotella oil.
After the oils heats up I dont think the difference of 30 and 40 weight are not enough to kill an engine especially with an older ,higher mileage engine.
jadcock
05-05-07, 03:04 PM
According to Shell, the vis @ 100*F of the 5W-40 is 15.1 I believe. Even the heaviest 10W-30s are only about 12.5. If the viscosity scale is linear, and I don't know that it is, that's 20-25% thicker than a 10W-30 at that temperature.
But if you read my follow-ups in this thread, you'll find that I did use Delvac (15W-40) in my high mileage 1997 Northstar. My current Northstar has less than 60k miles on it, and I'm not comfortable running a 40W oil in it. It may not do any damage, but now that I have discovered that I have Rotella in 10W-30 available to me, I'd rather run that because I KNOW 10W-30 is good for the engine.
