View Full Version : Seville Sound Systems
Budabear
03-27-04, 01:44 PM
Has anyone here used the existing stereo wiring to hook up to there own stereo. I'm thinking of throwing in my Sony head unit and my JL Audio speakers but I hate the idea of having to try to run new wiring to my doors.
Can anyone tell me where I can find a wiring diagram for the stereo / speaker wiring in the car. This would make the job much easier and cleaner.
Budabear
03-30-04, 10:42 AM
Wow! :confused: I can't believe no one here has a clue about the factory stereo wiring.
DaveSmed
03-30-04, 09:16 PM
Bose system? The biggeast obstacle is the fact that most likely the wires going to the speakers come from the BACK of the car. Usually the headunit connects to the module in the trunk, which connects to the speakers in the car.
Budabear
04-11-04, 11:52 AM
That's not much of an obstacle! My changer and amps would be in the trunk. So, the front speaker wires are all I would need to find. I'd use better cable for my 6x9's in the trunk.
BMcNamara
04-11-04, 10:59 PM
If your looking to upgrade your system its best to use all new wiring preferably 14au or so. At higher ampiers the thinner (higher guage) wire will not handle the response and make you think your spekers are blown. I am also looking for a wiring diagram for my 97 sls but I just joined the site and haven;t asked yet... did you ever end up getting a response?
BMc
Lawrence
04-12-04, 12:58 AM
Budabear,
Be carefull here and make sure you bypass the OEM amp/s.
This may help.
http://www.metraonline.com/locator.aspx?year=1994&make=14&model=617&type=7
1994 Cadillac Seville Stereo Information
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Rear
Front Speakers 5 1/4" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
2003 Metra Application Guide
1992-1995 Cadillac Seville (console shift)
Premium Kit N/A
Budget Kit N/A
Custom Kit 99-2002
Harness Into Car 70-1856
Harness Into Factory Radio N/A
Speaker Adapter Harness 72-4568
Speaker Accessory N/A
Custom Antenna 44-GM935
Universal Antenna UT-L
Power Antenna 44-PW22
Power Antenna Base N/R
Antenna Adatper to Factory Antenna 40-GM10
Antenna Adapter to Factory Radio 40-GM21
Outside of this all I can add is to buy the OEM service manual, www.helminc.com
Lawrence
04-12-04, 01:22 AM
BMc
Here's the same for your 97,
http://www.metraonline.com/locator.aspx?year=1997&make=14&model=617&type=7
1996-97 Cadillac Seville Stereo Information
Ground Black
Illumination Gray
Dimmer Brown
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
1996-1999 Cadillac Seville
Premium Kit N/A
Budget Kit N/A
Custom Kit N/A
Harness Into Car N/A
Harness Into Factory Radio 71-2001
Speaker Adapter Harness N/A
Custom Antenna 44-UL15
Universal Antenna UT-S
Power Antenna 44-PW64#
swimmster
04-13-04, 11:13 PM
the actual radio module is in the trunk.. in my Eldorado, it's right next to the power antenna... your BEST bet is to put your own amps in the trunk with RCA cables going to your head unit.. in the trunk at the radio module, you will find ALL the speaker wiring in one connector. to find them, the radio module has the same info that is up above stamped into the module cover.. Just find your speaker wires and there you go.. run them over to your amps output and you're done.. I'm getting ready to do this to my car as my stock sound system sounds HORRIBLE.
alexinvancouver
07-12-04, 08:58 PM
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Rear
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Not always the case.
I've spent the whole day trying to find wiring diagramm for my STS - it has two connectors and wires completly different in colours than any on diven diagramms
here's what i got -
1
Yellow
gray
purple/white
black
blk
brn/wht
grn
blk/wht
grn/wht
orange/wht
yellow
blk
i'm trying to install Delco stereo from 94 eldorado also with two connectors. they perfectly fit, but wires differ and of course it doesnt work =o(
