Hollis Walker
04-21-03, 11:24 PM
Question:
My heat guage has jumed one bar over the center bar when ideling in traffic. It is a 901/2 model purchased new in late `1990, now having 43000+ miles on the odometer. I have had only minor problems, this being one of them. Anyone with some knowledge please let me hear from you. Hwalker426@aol.com.
Hollis
Allante North *
04-24-03, 07:14 PM
From what I have heard, that is normal operating range for the Allante. If it worries you, you could put a 160 degree thermostat in it.
Hollis Walker
04-25-03, 12:27 AM
I'll put the 160 thermo on my list. What it the rating on the factory thermostat?
Hollis
Allante North *
04-26-03, 10:46 AM
My service manual says the operating temperature is between 185 and 230 degrees. If the temperature exceeds 259 degrees the air conditioner compressor clutch will disengauge and code B450 will set. I would guess that yours is similar. I have a 1993 and the thermostat is a 180 degree. Your temps are within range, but if you feel better, go ahead and install the 160.
Don
Hollis,
I hate to send you to another board, but there was some pretty extensive discussion on this on the AAG board. Unfortunately, we/they are having problems with the domain registrar. Normally, the board would be www.allantenet.org, but due to the problems you have to get there via http://66.216.15.167.
Do a search on something like thermostat (make sure you set the max age something large, like 500 days - it defaults to 7).
There are a couple of issues. Depending on the situation, what you see could be normal. If it isn't normal, you're looking at potentially the cooling fans, the cooling fan relays, the thermostat, or possibly, a blockage caused by poor cooling system maintenance.
Pay particular attention to any posts by Jestal, as he is a GM powertrain engineer who worked on the Allante line, among other things.
Here's some possibly relevant info...
http://66.216.15.167/cgi-bin/yabb/YaBB.cgi?board=talk;action=display;num=1046971407
This one has a good description of what is "normal"
http://66.216.15.167/cgi-bin/yabb/YaBB.cgi?board=AAGTALK;action=display;num=10375801 81
