View Full Version : 1995 SLS cranking but not starting, code p035
rabnestic
04-02-07, 10:46 PM
A few days ago my mom's 1995 Seville shut down and hasn't started since. I've checked the codes and found P035 - PCM issue. Prior to this I checked the timing belt aok, spark aok, ICM aok - Has anyone out there had problems with the PCM?? If so how do you know, other than find it and replce the beast. Also, where is it?? HELP!
fubar569
04-02-07, 10:57 PM
should be inside the airbox under the hood...
check all of its connections, and make sure the memcal is seated properly...
upon doing so...if it fails to resolve the issue, i would purchase a reman PCM or find one out of a similar OBD1 equipped northstar seville and install...
Ranger
04-02-07, 11:35 PM
P035 (E035) .......................... PCM reference low signal voltage Out of Range
Check the battery voltage and cables.
fubar569
04-02-07, 11:49 PM
thanks ranger for the clarification...i was going off from his description and didnt think to double check the code number...
rabnestic
04-03-07, 07:53 AM
I took the airbox completely apart and did not find this item. I did se a connector at the abs box which is directly under the airbox, but considered that tyo be abs related. As for the voltage, I'll check it, but the car hasn't needed a jump since it stalled on 3/31. I've been cranking it for numerous times over 2 specific days and it still cranks strong. Makes me think that the voltage is fine.
Ranger
04-03-07, 10:34 AM
I think PCM on the '95 is still under the dash, near the glove box. I am not sure what year it was moved to under the air filter housing, but I think it was after '95.
fubar569
04-03-07, 10:46 AM
though the PCM's connection to the battery could be bleeding power and that could be causing the issue...based on rangers code description...
zonie77
04-04-07, 10:36 AM
Do you have fuel pressure? If you do not have a pressure gauge give it a good shot of starting spray and see if it starts.
rabnestic
04-06-07, 01:40 PM
BINGO Zonie77. Turns out to have been a bad fuel pump, eventhough I heard the thing priming. Thanks all for your help on this one!
You forum guys are great!!:worship:
