elia
03-28-07, 10:28 PM
I have a 1992 Brougham RWD with a 5.0 TBI. When I turn on the car the engine is idleing just fine, with less then a mintue the motor starts to idle low and then idel up to normal what can be wrong
| View Full Version : My Idle goes up and down elia 03-28-07, 10:28 PM I have a 1992 Brougham RWD with a 5.0 TBI. When I turn on the car the engine is idleing just fine, with less then a mintue the motor starts to idle low and then idel up to normal what can be wrong 90Brougham350 03-28-07, 10:41 PM Any trouble codes? Sounds like an idle air control problem to me. elia 03-28-07, 10:43 PM No codes, how can I check to make sure danomac 03-29-07, 05:36 PM There is likely a thermally-activated vacuum switch that is activating after a minute or so of running. Whatever is connected to this switch (or the switch itself) is leaking. You'll need to trace vacuum hoses to locate it. It helps greatly if you have a hand-operated vacuum pump to test the lines and other devices. elia 04-02-07, 11:49 PM I changed all the vacuum holes and nothing same problem still, anyother suggestion N0DIH 04-03-07, 12:52 PM Have you cleaned the throttle body blades? They will cause this. Too high ignition timing will cause erratic idle as well. Lean conditions can also cause erratic idle. elia 04-03-07, 06:07 PM With the car on park I turn the steering wheel and the car goes to low idle like if it wants to turn off, almost like if I was running out of gas. elia 04-04-07, 05:09 PM does any one have pictures or a diagram where I can check to make sure that the vacuum line are at the right place N0DIH 04-04-07, 05:57 PM I wish I did, I have nothing on the TBI cars except the 85 4.1L Brother_B 04-05-07, 12:12 AM This might be a smooth trick for people in search of a vacuum diagram: I have the Haynes and Chiltons manuals that cover something like 1970 to 1987. I don't think Haynes had a vacuum manual at all and Chiltons had a bunch to choose from. You are supposed to pick the one that looks the most like your car or something. Anyway, nothing really matched mine very well, so I called Haynes and said "Your book is missing the vacuum diagram that I need." The guy on the phone was actually really nice and sent me one by e-mail. It wasn't the greatest diagram, but maybe somebody else should try this and see if you have better luck. N0DIH 04-05-07, 01:37 AM Something to look for is PCV hose cracks and any other vacuum line crack. With that age, they are bound to be pretty brittle. elia 04-05-07, 06:07 PM OK guys this is the update I purchased the car about a week ago and the owner told me that the car has a full tank, I been driving the car for two days and notes that the fuel gauge does not go down so I drop the gas tank down and I notes that the middle fuel line on the sending unit was lose from the sending unit, so I went too two auto parts and one has the sending unit so I came up with the idea of using JB welding, now do you guys thing that JB welding would work and do you guys thing this can be my idle problem also. When I'm at a red light the car turns off unless I accelerate a little then I stays on. N0DIH 04-05-07, 09:21 PM How is the fuel pressure? Can you check it? Is vacuum line to Fuel Pressure Regulator (FPR) good? Put a vacuum pump on the line and a gauge on the port and check pressure with and without vacuum (you can use engine as "pump" too). I like pump because I can check the leakdown of the FPR too. elia 04-13-07, 02:42 PM will JB welding does not work so I had to order a new sending unit I put it on and my fuel gauge is marking half a tank so now its wroking correct but I still have idle problems, I removed the idle control valve and cleaned it up a little but nothing, is the pin on the idle control valve supposed to be hard and stiff elia 04-15-07, 05:26 PM I play with the timing and was able to set it where the car stop giving idle problems, so I think I found the problem:bouncy: | |
