: Wiring Scheme for 98 Deville
fristim
03-28-07, 07:24 PM
Anyone know where I can find a wiring scheme for a 98 deville. Mainly need the underhood stuff like Mass Airflow sensor, and fuses and relays. I have a wierd problem with some codes that Im believing are all tied together as far as wiring is concerned.
Well after I put 12 volts to the pump and it ran I plugged it back in and still nothing. So I checked the relay plug in on the fuse box for voltage and I get 12.2 volts for about 2 secs when I turn the key on. Checked the other side of the relay circuit and I get nothing. So I went ahead and pulled 12 volts from another fuse, ran a jumper wire to the fuel pump fuse and there we go, got the fuel pump running and the car fired right up. But now I a whole shit load of codes that follow. Any Ideas thanks.
P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0753 - 1-2 Shift Solenoid Circuit Electrical
P0758 - 2-3 Shift Solenoid Circuit Electrical
P1645 - Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
P1860 - TCC PWM Solenoid Circuit Electrical
Those are all current by the way.
*SEE "STRANDED OUT OF TOWN" POST FOR THE FULL STORY*
Ranger
03-28-07, 10:34 PM
FSM is the only place I know of to get a wiring schematic.
scl98sts
01-25-08, 04:12 PM
i have these same exact codes but cant seem to find anybody to help .if you got this fix please help me so i can get my car back in working order . thanks
Submariner409
01-25-08, 07:03 PM
There is no single wiring diagram. Unfortunately, all the diagrams for modules and circuits are placed in with the repair and maintenance sections for everything from sections on engine electrical to tag light wiring. It's 2 books the size of NY telephone books.
Buy the FSM, get all diagrams plus all codes and how to troubleshoot them. Not Chilton's or Haynes, GM only.
AJxtcman
01-25-08, 07:53 PM
I will pull it.
I will be right back.
AJxtcman
01-25-08, 08:05 PM
FIGURE Cell 20: MAF Sensor, EVAP Components and EGR Valve(c)
http://i224.photobucket.com/albums/dd25/AJxtcman/Electrical/230712.gif
FIGURE Cell 20: ABS/TCC Switch and Transaxle Solenoids(c)
http://i224.photobucket.com/albums/dd25/AJxtcman/Electrical/230735.gif
scl98sts
01-25-08, 09:14 PM
ok can somebody read my origanal post 'trans problem please help' . can any body tell me if the codes i am getting is from the wires getting soaked in power steering fluid ? and or the solenoids are bad ? codes p0753,p0758,p0102,p1645.p1860 . thanks
AJxtcman
01-25-08, 09:25 PM
The Under Hood Electrical Center is a big problem. Lots of corrosion. I have cleaned many fuse to fix a car. I have had many no cranks with corrosion on the starter relay. I have seen many no starts for corrosion on the fuel pump relay
AJxtcman
02-04-08, 08:09 PM
The ESC fuse will set the P0753, P0758, P1860, P0102, P1645
Even corrosion or High resistance on the fuse will set the DTC's
scl98sts
02-08-08, 11:37 AM
ok i will check . i havent touched anything i dont want to mess it up and i refuse to take it to the dealer or mechanic shop. everybody wants to tear it apart or replace the most expensive parts thanks
scl98sts
02-14-08, 03:52 PM
Thanks It Was The Esc 10a Fuse. I Changed It And All The Codes Cleared And Car Runs Good .
roym01
07-24-10, 06:51 PM
Ive got the same issue on my 99 STS. Where can I get a fuse and can I easily change it myself?
Submariner409
07-25-10, 01:22 PM
If you remove the cover on the underhood fuse box there's a fuse/relay legend sticker there. On that legend there will be all the fuse and relay locations as well as 4 spare fuse locations and a plastic fuse puller: they're TIGHT !!
Same for the fuse box under the back seat.
It's all in the Owner's Manual.
Fuses come from any car parts store, K-mart, Walgreen, gas stations.
Glad to see you did some searching - this thread is 3.3 years old...........
Marknmaui
07-25-15, 02:53 PM
I haven't been able to locate this ESC 10 amp fuse your talking about in the underhood fuse box
