View Full Version : I have a distributor oil leak
moses912
03-26-07, 09:13 PM
Well I have a 94 Cadillac Fleetwood and I recently changed my distributor and o-rings and seals. I changed it the first time and had a leak coming from right behind my distributor. So I took it out and changed everything again. Right now when my engine is idling or moving oil drains from behind my distributor. I was wondering can anybody tell me the problem. Or what I can do to eliminate the leak. Is their a rig job I can do. because we tried everything.
BCs71
03-28-07, 02:08 PM
SOunds like one of the three seals in the timing cover are leaking. This would be the water pump shaft seal (top), distributor/opti seal (middle) or crankshaft seal (lower). These seals have a teflon subtstance on the outside and must be pressed in DRY (no oil on outside so they slide in easier).
SOmetimes the top seal (WP shaft) leaks and drips down, making it appear as though one of the other seals are leaking.
See here for details and pics:
http://www.impalasuperstore.com/naisso/forum2005/topic.asp?TOPIC_ID=30984
XXL-VETE
03-29-07, 10:31 PM
The most common leak is the water pump drive seal being installed incorrectly; the seal has to face inward, there is a special tool from K-D and others have used a sharpie pen cap; I prefer the “coke” can method myself ; the important think to keep in mind here is the seal orientation ;
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0588.jpg
Notice that the black seal lip faces inward toward the block.
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0590.jpg
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0589.jpg
This is why you need the spiffy install tool .. to keep the black seal inward .. with out the tool; as you slide the seal over the shaft it would flip the black part of the seal outward and then you have an oil leak .. I cant tell you how many shops cant figure this out .. I’ve had a bunch of b-body owners contact me because the shop they were using could not stop there oil leak .. “ hi Kenny? I here you are the b-body master.. I have an oil leak my shop can’t stop” .. I know just what the problem is .. come on over … :D ..
Kenny
93 Fleetwood Brougham and Wife’s 96 Fleetwood Brougham
Kenny Canniff
Both lowered ( http://impalassforum.com/noncgi/ultimatebb.php?ubb=get_topic;f=35;t=001395#000000) 17” wheels on mine 18” wheels on hers
http://i39.photobucket.com/albums/e153/XXL-VETE/caddysig.jpg
HOME PAGE (http://www.cardomain.com/ride/760486)
caddycruiser
03-30-07, 01:33 PM
Wow, great info for future reference, as always.
