: Loose Wire Help- Blue single pin with oval connector?? top of manifold
54Cadillac
03-25-07, 08:14 PM
89 Fleetwood Brougham 5.0, 307, appears to be in harness that goes to computer behind glove box? The blue wire leaves the harness right in front of the carburator. Someone look and see where it goes? I'd really appreciate your help! Yeah, my first post! yahooo! gooogle! Caddies Rule:thumbsup:
54Cadillac
03-26-07, 01:25 PM
I found out its just a test wire of some sort, no biggie!
joe_padavano
03-27-07, 08:56 AM
Correct, though the plastic connector is usually green, not blue. It is used to monitor the mixture control solenoid in the carb when setting the idle mixture. You connect a dwell meter to this terminal and read out on the six cylinder scale. Try to adjust the idle mixture screws to come as close to 30 degrees dwell as possible.
