: Forgive me, but im looking for a few things (all chime in)
fubar569
03-25-07, 05:27 PM
I'm back after a very long hiatus and just spent some time under the deville since we finally got to almost 60 degrees and sunshine today! fixed a couple wear and maintenence issues but i had some time to think about a few things...
EXHAUST: -
this "crossover" pipe is dumb. some half-assed retard decided it would be a good idea to screw in the front manifold-to-crossover pipe bolts FROM THE TOP SIDE!!! there is zero to no chance i can wrestle anything up in there to get them out. it makes me wanna kill people
prospects for replacing the pipe are not good either. i would have to make a wide/thin oval/rectangular replacement and it would be going right under the oil pan and trans.
has anyone done this before with pics or a little review? it's the biggest restriction and consequently the hardest to eliminate in a truly easy/effective manner...
The rest of the exhaust after that could be done with an X section and dual pipes easily. there is plenty of room, espectially if you have torches and a welder...
Headers? doesnt look real easy front OR rear bank...i'm not even gonna bother...
What mufflers seem to be the most popular on the board?
INTAKE: -
Not much going on here. totally stock now, but i keep hearing about modifying the airbox itself and going to a k&n panel filter in the process. I've seen a couple people describe this in scattered other posts but could someone detail that here for me? my car for reference is a 1997 Deville...
I see eldorado1 no longer does throttle bodies. Has anyone located a suitable supplier for these parts?
TUNING: -
I see we are making progress on getting a performance tune for OBDII northstars as indicated by the very huge thread near the top of the list here. pricing is going to be close to 400 bucks though for 10-20hp and removal of speed limiters? all i really want is that 112mph limit gone - not that i go that fast on a public highway anyways :halo:
I don't see the tune coming into play till you change motor via port work, cams, intake, exhaust, etc...my 97 already requires premium so i bet there is little to gain for me.
FUEL: -
Balanced injectors...what do you think about sending mine out to be tested and flowed?
just looking to corral all the ideas for simple gains up into one place. makes it easier to reference if you know what i mean
codewize
03-25-07, 11:25 PM
You know I'd like to know, while were here, what does it cost to have a set of injectors flow matched and is it worth the money. I would be doing it on my 01
jadcock
03-26-07, 01:51 PM
I agree that it was pretty dumb threading the exhaust crossover bolts from THE TOP. That would actually make an oil pan gasket change a RELATIVELY easy job if that crossover were even half-way removable.
I didn't have all that much luck with a K&N filter on my '97 Seville, though I used a cone and not a panel filter. I was much happier with a paper air filter.
fubar569
03-26-07, 06:31 PM
i plan on figuring out a way to get that crossover out of there. i just set myself back 4 weeks from accidentally shooting myself in the hand so i got plenty of time to think about it...
fubar569
03-27-07, 03:41 PM
ok, i'd like to start a somewhat technical discussion on exhaust and how to best eliminate the crossover pipe.
i know due to clearance issues running a 2.25 or 2.5" pipe right underneath the pan is out of the question...
the area of a 2.25" single pipe is 3.976"
a 2.5" pipe - about 4.90"
however running that right under the pan would be ludacris and you would have next to no ground clearance.
how is the flow of a rectangular section of pipe compared to a circular section? assuming the transitions were all smooth, would there be any penalty?
lets assume instead the pipe was rectangular in shape...about 4" wide and 1" tall...the area is 4" obviously or equivalent to a 2.25" pipe...would these flow the same amount of gas? or am i missing out on something here?
or would it be even worse of a restriction than the crossover pipe itself?
