Jeannie
03-24-07, 09:25 PM
I am looking for information on the 368 engine that came in the 1981 devilles the wiring diagram is what I want right now and I would like to find a factory manual if I could.
| View Full Version : Please Help if you can 368 8-6-4 Jeannie 03-24-07, 09:25 PM I am looking for information on the 368 engine that came in the 1981 devilles the wiring diagram is what I want right now and I would like to find a factory manual if I could. Jeannie 03-24-07, 09:58 PM Please help if you know firing order for 1981 368 8-6-4 engine, thanks arnauts 03-25-07, 04:08 AM It's 15634278, I think. You can find it on the right side of your intake manifold. Jeannie 03-26-07, 08:57 PM Thanks did that and now i guess its down to a fuel problem not getting any it seems. The Ape Man 03-26-07, 09:38 PM not getting any it seems. It happens to the best of us. lostDTS 03-28-07, 12:58 PM check your fuel pump relay. Just switch it with the rear window defog relay. If that dosnt work, most likely the fuel pump. Either check fuel pressure, or if its original, change the pump, strainer, and fuel pump filter. eldorado99 03-29-07, 02:39 AM It happens to the best of us. Hahaha! :thumbsup: It sure does... danomac 03-29-07, 05:44 PM Have you checked the rubber fuel lines? Mine rotted and fell off, so I got no fuel... but it did go all over the ground. ;) | |
