: Fuel Line Tap
john d
03-22-07, 05:50 PM
Anyone have a suggestion about how to install a "T" in the SRX underhood fuel line to add a hose and shut off valve? Want to pump gas into a gas can or fuel tank of a ATV, motorbike, etc.using the SRX electric fuel pump.
03-22-07, 10:41 PM
I haven't had a reason to check but there's probably a fuel pressure tap somewhere near the front of the engine. You might have to remove top engine cover to find it. Generally has a Schrader valve used to attach a pressure gage. You may be able to adapt something using this tap. Of course all the appropriate cautions apply to hot engines and fuel.
