TOM HARMON
03-18-07, 09:53 PM
I have looked at lots of messages in the forum and probably missed this. My '98 Deville trunk will not open with the remote or the button on the dash - only with the key. Dealer says this is a $200 fix. On my meter there is no power coming through the solenoid so I assume that is the problem. Is there a good source, other than the dealer, for a replacement and what should it cost? Thanx
THH
http://www.gmotors.com
and maybe
http://www.rockauto.com
TOM HARMON
03-18-07, 11:25 PM
Thanks I will check that out. THH
rugbeee
08-21-07, 04:04 PM
Any update on this issue, I have the same problem with my 2000 STS, button inside and key fob don't work (doesn't pop up, doesn't even unlock), I can only open the trunk with the key
Valet switch in the glove box?
z06bigbird
08-21-07, 09:46 PM
If it is not switched off, then a wrecking yard would also be a good source for the part. Off the top of my head, I suspect that solenoid has a very low failure rate.
rugbeee
08-22-07, 09:52 AM
I sent this message in the middle of my search, and I later found the valet switch check, and sure enough, I am an idiot - my brother flicked the switch over as he was looking through my glovebox this weekend, I feel much better now! Thanks guys
Permetheus
09-27-07, 12:10 AM
You learn something new everyday.:dance:I had the same prob with my '95 DeVille, & the thought of the valet switch never entered my mind until I started reading this thread. Much Appreciated!!!:D
