: 4 bolt main or 2 bolt main???
92cadbro
03-18-07, 04:59 PM
Hi everyone, I have a 92 Brougham with the 5.7L 350ci. Is this motor a 4 bolt main or a 2 bolt main?
Thanks in advance
soxx35
03-18-07, 09:02 PM
2 bolt
92cadbro
03-19-07, 09:10 AM
How come I have heard that all 350ci engines are 4 bolt main?? This isn't true??????
90Brougham350
03-19-07, 11:02 AM
Nope, truck engines are 4-bolt, passenger car engines are 2-bolt. There's exceptions, but that's an easy way to think of it, at least as far as the TBI motors are concerned.
92cadbro
03-19-07, 02:58 PM
90Brougham350, yould u know what are these exeptions?? I swear i've always known that 350's are all 4 bolt. This is new info to me!!
It kinda sucks not having it though......unless mine is a "exeption"...
90Brougham350
03-19-07, 08:36 PM
Unfortunately I can't be of much help more on this. N0DIH can certainly chime in though, he would know more about this than I would.
bigbluebrougham
03-21-07, 03:11 PM
My 1993 Chevy Silverado must have been an exception. Right before I got rid of it, I replaced the oil pan gasket on it (PITA!) and it was a 2 bolt main. Got rid of it because when I started it, there was a nice main bearing clatter for about a 1/2 a second. It had 200k on it when I got rid of it. Anyway, don't mean to ramble on and jack your thread...just my .02 cents.
If you can find your block number, I can tell you if it is a four bolt or two bolt.
BBB
92cadbro
03-21-07, 03:19 PM
bigbluebrougham, where can i get my block number? im guessing it's on the block, but where?? Can you find out if its a 4 or a 2 with the vin number?
Thanks
bigbluebrougham
03-21-07, 03:52 PM
I can't. There are vin decoder websites out there. I don't know if it will tell you 2 or 4 bolt with the vin decoders. The casting number is located on the driver's side, top rear of the engine block. It is right behind the head. This should be a 7 or 8 digit number. I am going to throw a wrench in here though...some blocks have the same casting number but may have 2 or 4 bolt mains. If you find the casting (starts with a 140... I think for 92's) number, I can tell you what it should have though.
BBB
boatman
04-11-07, 03:54 PM
Nooooooooo, not al all!!
90Brougham350
04-17-07, 11:03 PM
2-bolt motors can still take quite a beating, I believe at least 450 horses without a problem.
