View Full Version : 5-w30 in 99 N* ??
Elmer Fudd
03-13-07, 08:45 AM
Mine is a 99 N*, Concours (the 300 hp). The manual clearly says 10w-30 PERIOD. I have heard that starting in 2000 they went to 5w-30 as ok. I know there were some small changes in the engine that year too.
Question is, I have a slight lifter tick that is not bad,but enough to really IRRATATE :mad: me....... I have tried various snake oils...no luck. Some have suggested lighter oil to get in the blocked ports (assuming that is the culprit). My 98 Buick (3.1) ticked and tapped a little until it got real warm on 10w-30, but it was much better on 5w-30.
Did Caddy switch to saying 5w-30 was ok due to simply re-thinking, or was the change in the engine the reason.
In short, what do you think about a crankcase with 5w-30 in the 99??????
jadcock
03-13-07, 09:14 AM
Did Caddy switch to saying 5w-30 was ok due to simply re-thinking, or was the change in the engine the reason?
The change is in the engine itself. The valvetrain went from flat tappet (1999 and previous) to roller tappet (2000 and beyond). The roller tappets provide a huge reduction in friction, and don't require the same "level" of lubrication that the flat tappets do. The flat tappets act directly on the valves, and that's a fairly major friction point, and proper lubrication there is critical.
That said above, the difference in 5W-30 and 10W-30 is relatively minor, and should be non-existant once the oil is warm. But if you have a lifter tick cold, and you're sure it's not piston slap or combustion chamber deposits, I don't think it would hurt to try a 5W-30 for one oil change and see. I personally doubt you'll see a difference, but I don't think you'd hurt anything by trying.
JimD
03-13-07, 09:19 AM
Mine is a 99 N*, Concours (the 300 hp). The manual clearly says 10w-30 PERIOD. I have heard that starting in 2000 they went to 5w-30 as ok. I know there were some small changes in the engine that year too.Trust your manual. The engine changes in 2000 were more extensive than "small".
Did Caddy switch to saying 5w-30 was ok due to simply re-thinking, or was the change in the engine the reason.Engine differences is your answer. And roller cam followers is the main reason.
In short, what do you think about a crankcase with 5w-30 in the 99??????Not for me.
Elmer Fudd
03-13-07, 09:54 AM
Thanks Jim aand Jad...sounds like I had better stay with 10w-30 or better. The lifter tick is not just when cold, it comes and goes at all temps. Most of the time you cannot even hear it from inside the car.....I am just a perfectionist I guess.....
Didn't understand about the tappets, thanks again......:rolleyes:
jadcock
03-13-07, 09:58 AM
I would investigate a little more, if you already haven't, to ensure that it's a true lifter tick, and not something else, like combustion chamber deposits, a loud fuel injector, etc. Lifter noise (and valvetrain noise in general) is very uncommon on the Northstar engine. I haven't heard a lifter noise in either of my Northstars (the '97 has 157k miles, the '01 has 57k miles).
Ranger
03-13-07, 04:05 PM
I still use 10W30 in my '03 DHS, my daughters '02 SLS & '04 Grand Am. In talking to the Guru about this once I got the distinct impression that GM went to 5W30 to satisfy CAFE and tree huggers, but left to their own choices, they would have stayed with 10W30. That said. I would think a thinner oil would make it worse, not better.
Elmer Fudd
03-14-07, 10:35 AM
It has been diagnosed as such both by the Caddy dealership and an independant mechanic. It has the classic rise and fall in volume over about a 6 second period (would an injector do that??). Plus ius actually seems to be less when the engine is cold.
The Caddy dealer did a upper engine cleanout anyway....no difference.
clarkz71
03-14-07, 12:37 PM
What brand of oil are you using ?? :stirpot:
Elmer Fudd
03-14-07, 02:58 PM
hehe, tried Mobile 1 10w-30, Castrol 10-w30 dino, and Rotella T 15-w40 Dino
No significant difference.
It is really hard to judge. It is not constant. Some days it is really noticable, others you cannot hear it from inside the car at all.
Have tried cleaners (Cd2, Risolene, MMO, and MOA) in the various oils too. Again, no difference substantial enough to say for sure. This started before I got the car according to the dealers records at about 95 k. Their diagnosis was harmless lifter noise, and ignore it. Now at 118k and it hasn't changed at all.....
I suspect an actual mechanical problem...spring maybe??? I say this cause the dealer had records on this car and it had 3000 mi oil chages with Mobile 1 since the day it was born.
hehe, naturally the day I test drove it was one of the days it wasn't noticable.....
Otherwise it runs great....super gas milage, more power than I really need, oil consumption about right (1 qt. every 1000 - 1500 mi.) no coolant useage...etc.
Just standing outside the car at idle it ticks like a gift from Bin Laden.......
Ranger
03-14-07, 06:25 PM
:hide:
clarkz71
03-14-07, 06:34 PM
:hide:
I'm trying.:lol: I like a good oil thread.
AlBundy
03-14-07, 08:34 PM
Are you trying to piss you know who(the hater of oil threads) off? Whats wrong with you?
Ranger
03-14-07, 08:43 PM
Don't you mean oil war?
clarkz71
03-15-07, 04:56 AM
Who is that?
War/discussion/debate. Fudd took it as I meant it, a joke.
codewize
03-15-07, 11:48 AM
I put 10W-30 in everything, cars new and old, trucks, lawn mowers, weed whackers, everything. 10W-30 is the universal answer. Unless you live in Alaska or some other part of the world where it's below 0 for extended periods of time.
clarkz71
03-15-07, 11:58 AM
I agree, 10W-30 seems to be the best compromise. I've been using Mobil 1 10W-30 but the price for this oil is getting crazy ($30) for 5 qt jug. I just bought 12 one gal jugs (2 cases) of Rotella 10W-30 for $9.99 a gal. I think $2.50 a qt is more reasonable then the $6.00 for Mobil 1. My research shows Rotella has as much if not more ZDDP then Mobil 1, even with the CJ-4 rating.
AlBundy
03-15-07, 12:26 PM
Quote:clarkz71
Who is that?
The notorious MUGSANDLUKE.
clarkz71
03-15-07, 12:28 PM
Yeah, that's right. He's fun to get going. He got cranked up on the Havoline thread.
Ranger
03-15-07, 03:51 PM
Who is that?
Oh, I new it was a joke Clark. Just pulling your leg.
clarkz71
03-15-07, 03:55 PM
:lol:, cool . Now where's MUGSANDLUKE, he's always good for a laugh.
JohnnyO
03-19-07, 10:25 AM
A lot of people on the oil board report that their engine sounds louder with Mobil 1. My decrepit old work van wouldn't know how to run on such good stuff, but the engine is quieter when I have Valvoline Max Life in it. I put Max Life 10w-30 in my mother's '99 last year also, it didn't make noise to begin with but the oil consumption was lessened somewhat.
10w has greater film strength than 5w, which is important to minimize cam and lifter wear on the flat tappets, or so I was told by the guru.
5w should only be used in a pre-2000 N* if the weather is going to be real cold for a long time.
wydopnthrtl
03-19-07, 11:54 AM
I've ran mobil 1 for a number of years now. Been using 5w-30 in the eldo and IMO it's too loud. I switched to 10w-30 and it's definately better. But all in all I'm not too happy with mobil one anymore. There are so many other good products now..
This next oil change I'm going to go with...?
btw: If it's truely a lifter tic. Fill the crank case with a 50/50 mix of kerosene and high detergent straight 30weight. New filter. Let it idle for 15-20 minutes (do NOT drive it) Change the oil/filter and drive for about 100 miles. If there is no change.. then really ought to repair it. If it's gone or mostly gone.. change the oil and filter again and call it good. Sounds a little old school (which it is). But it works. :thumbsup:
Rich
JohnnyO
03-19-07, 04:18 PM
It's only one UOA of one oil in one vehicle and not a Cadillac, but I got a used oil analysis of Mobil 1 Truck & SUV oil after 5000 miles in my Sport Trac and it was awful. Critical wear metals were way, WAY too high. UOA's with Pennzoil Platinum and even Motorcraft Synthetic Blend were much better.
