View Full Version : Lowering your Fleetwood AND keeping the air ride leveler !!
XXL-VETE
03-10-07, 03:06 AM
OK guys; I did this on my Fleetwood when I lowered it but didnít take pics.. Did the wifeís car and took pics so this is how you do it!
I went to a local hobby shop and bought this Turnbuckle ..
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0347.jpg
you can use a piece of 8/32 all-thread too..
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0348.jpg
I heated the rod with a small torch and pulled the ends off ..
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0351.jpg
Then I cut the turnbuckle down a little
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0350.jpg
Thread it all together and TADA !!
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0352.jpg
the arm this snaps onto is adjustable and the turnbuckle gives you a fine adjustment so you can get it just the way you want it.
Here they are side by side so you can see how much of a difference there is..
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0353.jpg
And here is the finished product !!!
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0357.jpg
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0359.jpg
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0356.jpg
http://i39.photobucket.com/albums/e153/XXL-VETE/100_0355.jpg
Lowering the Fleetwood just makes all the difference !
Kenny
XXL-VETE
03-14-07, 02:47 PM
To Technical? OK; just flatten the tires .. :bouncy:
96Fleetwood
03-14-07, 04:55 PM
Nice!!
Luckily your rear air shocks are still good! I had to do the alternative and go standard shocks & springs.
ssstealth
03-14-07, 05:38 PM
Another option is to cut the existing adjustment plate. Adjusting the plate all of the way down will yeild about 3/4" drop in the back. Cutting the plate to make the slot effectively longer will get the remaining 3/4".
sweden caddy
03-15-07, 11:58 AM
Thank you XXL-Vete ,but I dont understand,where is this
turnbuckle??
XXL-VETE
03-18-07, 12:20 AM
turnbuckle??
Just crawl under the back of the car and look up at the upper control arms. You will see an arm with this linkage attached to it. This is the self leveler controller; works much like the ball-cock in your toilet. When the car rises to the proper level it shuts the air pump off. Pretty simple really. :)
Kenny
_____________________
93 Fleetwood Brougham and Wifeís 96 Fleetwood Brougham
Kenny Canniff
Both lowered ( http://impalassforum.com/noncgi/ultimatebb.php?ubb=get_topic;f=35;t=001395#000000) 17Ē wheels on mine 18Ē wheels on hers
http://i39.photobucket.com/albums/e153/XXL-VETE/caddysig.jpg
HOME PAGE (http://www.cardomain.com/ride/760486)
ShadowLvr400
03-18-07, 07:24 AM
Too bad my rear shocks are going bad. My rear's already that low.
