: Sunroof not closing well / indicator out (front left) / oil change
03-07-07, 08:21 PM
Is the bulb for the front indicators hard to change myself? Also, the huge sunroof won't close by itself unless I hold my finger down on the button forcing it to close all the way. Is this just a lube problem? If I push the button once to close it, the mechanism goes to half way then senses resistance and starts to go in the opposite direction (opening up all the way again).
This is a certified 2005 srx with all the toys with 25k miles on it.
03-07-07, 08:33 PM
Had the same problem with my new '06 with the sunroof. Dealer (Lindsay in Alexandria) lubed it up and it works great. It is good that you have a certified vehicle, your dealer should be able to handle the roof. They may even cover replacing the bulb.
Best of luck!
03-09-07, 12:36 AM
My sunroof reverses on the air deflector unless I hold it down with my finger.
