View Full Version : Other Cadillac Engines
  1. 96 El Dorado Engine Replacement
  2. Stripped dissy and cam shaft gears!!!
  3. 99 4.6 has a miss
  4. 1964 429 Rebuild
  5. Pulsing '81 v6
  6. Seville SLS 1999 engine starts bad and going first time out
  7. Need Engine Expert in Vegas
  8. Rochester 4GC carb and Intake manifold
  9. Mystery on 390 ci intake manifold
  10. 8.71 Blower manifold for 429????
  11. 2001 DTS Disappearing Oil
  12. 429
  13. 429 Water Pump?
  14. Casting Numbers
  15. 4.5L 88 Eldorado External Coolant Leak
  16. 4.5 L check engine light
  17. Excessive LS2 Head Noise
  18. 1981 DIEsel Eldo
  19. what starter motor
  20. '81 6.0L trans line up with a Pontiac 400?
  21. New Alternator, new regulator, new battery, Battery still not charging? Any ideas?
  22. 1967 cadillac eldorado engine
  23. 1962 Cadillac carb question
  24. 61 Deville 390 Rad
  25. 429 Valve covers??
  26. Stay 429 or go 472/500?
  27. 1967 Fleetwood Limo
  28. Rear sump oil pan for 429?
  29. 390 and 429 engine parts
  30. Help Please with Mystery Part
  31. 1956 Cadillac Distributor Problem
  32. 429 Hei. Distributor Swap.
  33. 4/6/8 from 1981
  34. chevy 350 bolt up to th400 in a 1964 deville???
  35. drove ls7 ....tasty
  36. Timing Chain 4.6 VS 4.9
  37. 1965 Exhaust System
  38. 429: Replace or Repair
  39. Torque? 1965 Cylinder heads bolts.
  40. emissions
  41. coolant crossover leak
  42. How to Change Oil Sump Gasket, 429?
  43. Hey...where's the Chevy 454 thread??
  44. aluminum manifold issues
  45. HEI distributor for 365
  46. 5.7 Liter Diesel trans problem
  47. high mileage
  48. Engine for 67 Deville
  49. 1964 429cid valves and lifters - where to buy
  50. exhaust manifold '67 429cui
  51. 429 Engine
  52. Oil loss on '95 Seville STS
  53. HEI for 429?
  54. vortech for 3800
  55. low oil pressure 98 catera
  56. need answer
  57. help
  58. running model cadi flathead
  59. air cleaner
  60. 67 DeVille 429 Exhaust Manifold Gaskets
  61. I hope this is the right place for this
  62. 429 Performance
  63. What goes here?
