View Full Version : V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT
  1. Runs for three or four minutes and dies...
  2. Lots of oil in plug wells
  3. Reading 3.2L ECM for knock retard
  4. 05 CTS 3.6 Engine or Transmission problem
  5. 03 CTS Throttle Body
  6. new guy ?
  7. Forced Induction for 3.6L
  8. How to force 2.8 (LP1) engine
  9. Wheel shake when braking
  10. 3.6 CTS engine in a Catera
  11. 04 CTS 3.6 Throttle losing it's mind
  12. fuel dilution issues with DI engine?
  13. HF 2.8 turbo & HF 3.6L similarities
  14. CTS will not start
  15. 2003 CTS 3.6L Engine replacement...
  16. newbie here, change spark plugs, 04 CTS?
  17. 3.6L vvt pcv ???
  18. 98 vs 99 head catera
  19. 3.6L Longevity
  20. P0101 Question
  21. no oil to lifters
  22. 2008 CTS with 12K miles--CYLINDER HEAD REPLACEMENT!
  23. can this motor be rebuilt ? with PICS of damage
  24. Cadillac cimmaron
  25. backfiring on 3.0 catera
  26. Fyi guys
  27. Black Mobil 1 in 3.6 Engine
  28. HFV6 3.6L Crankshaft Reluctor problem - known issue?
  29. Alloytec in my Jet Boat
  30. My 2004 SRX will not start, help!
  31. CTS 3.6L engine FS
  32. 2003 cts rough/slow idle
  33. Catera - Mustang Engine Swap, Possible?
  34. 3.6L Info
  35. 3.6 and oil fill up
  36. window position sensor
  37. ? about my 2000 catera, please read! aux pump
  38. 98 catera 3.2 or 3.6 swap help / info
  39. Do these 3.2 Liter engines tick?
  40. 99 Catera wont start
  41. Engine cover; STS V-6
  42. Filling cooling system
  43. 1999 Catera: Help with Fuel Filter replacement
  44. Oil Pump on on replacement engine
  45. Engine gasket kit ?
  46. only starts on 3rd try?
  47. Rebuilding the 3.0 V6 for more power
  48. interchangable
  49. 3.6 VVT Have Similar Issues to N*??
  50. theromstat on a 03 cts
  51. Rough Idle: Please Help
  52. High Oil Pressure Reading
  53. 1997 catera oil mixing with coolant
  54. 3.6L Loosing Coolant
  55. 3.2 bottom Want to try 3.6 heads on top
  56. 3.6L missing oil
  57. Any 2.8 engine parts?
  58. GM recall 02041 cam belt info
  59. Where to get banjo bolt for water crossover
  60. whats the difference?
  61. 3.6 Liter headers
  62. 97 Catera oil in coolant
  63. cadillac cts 3.2L timing belt diagram HELP!
  64. Help blown 3.2 engine
  65. breathing system on the 3.0 and 3.2?
  66. 2003 CTS PCM Wiring diagram and Terminal description
  67. 3.6l VVT to Direct injection conversion?
  68. 1998 cad sls seville
  69. Intermidate Problem , Won't Idle
  70. Overseas tuning options 3.2L CTS.
  71. Posible to change Idle RPMs?
  72. Crankshaft Position Sensor - How hard to replace?
  73. did the short star ever come in a m/t?
  74. 2.8L vs 3.6L
  75. CTS vs. STS
  76. Performance Mods For 3.6 LY7??
  77. Possible Tuning Solution for 3.6 VVT
  78. LY-7 Bluprints / Dimensions / Measurements?
  79. Programming for 3.2L CTS
  80. Overheating issue
  81. 3.2 liter 5-speed into a Catera
  82. Aussie LY7 turbo project
  83. engine needed
  84. How To Change Catera Engine?
  85. 3.2 + Turbonator
  86. How hard would it be to
  87. 3.6 swap info
  88. 3.2
  89. Any thoughts on inconsistant idle?
  90. crank shaft positioning sensor...
  91. Could Sensors Be The Problem
  92. Aftermarket Air-Filter Upgrade
  93. Rough idling 3.6? Loud valve noise?
  94. Need Vacuum Hose diagram
  95. Volant Q - How get MAFS Connector Off?
  96. shifting problem
  97. '05 V6 Engine Changes
  98. on a 97 catera do no# 3 & 6 cylinder share the same coil?
  99. Online Source for Volant for 3.6?
  100. Another Tensioner Question
  101. Is Oil Filter Same
  102. Catera Oil Filter Adapter
  103. Cylinder head problem...
  104. Bent valve on '97 Catera
  105. Bent valve on '97 Catera
  106. 180 degree performance thermostat
  107. engine mods
  108. 2004 CTS 3.6L VVT Engine Info.
  109. oil filter
  110. help
  111. Misfiring In 1 And 6 / Brownish Coolant
  112. 2000 Catera Mixing Oil in Coolant
  113. Valve seal gaskets
  114. Synthetic Oil For Cts 3.6l
  115. headers for 3.6L
  116. Help! 99 Catera valve cover gasket replacement
  117. Where can i buy volant intake for my 3.6l?
  118. 04 CTS supercharger 3.6L
  119. 2004 CTS 3.6L rough idle
  120. Lund supercharger for 3.6L
  121. Major 2003 CTS Engine Problem
  122. Our Engine
  123. 04 CTS 3.6 Oil Filter
  124. I Want My Turbo!
