View Full Version : 5.0 and 5.7
Pages : [1] 2
  1. 1990 Cadillac Brougham 5.7 L (350 in³) L05/LLO FI V8, 175 to
  2. Rebuilt 5.7: Pinging and Piston Slap
  3. Where to get AC Delco DEXRONIII?
  4. What motors will fit my caddy
  5. 1995 Fleetwood Brougham 112.000 miles
  6. Cruise Control Vacuum Routing
  7. Want to transplant from 4.1 to 5.7
  8. 89 Brougham gas smell...
  9. Olds 307 Heater lines.
  10. Car doesn't turn off. (Olds 307)
  11. hearing a whine on my cts-v.
  12. Going with 1.6 full roller rockers
  13. Anyone Interested in ENGINE DECALS?
  14. 1992 Cadillac Brougham Starting Issues??????????
  15. 89 307 Cadillac Beats 318 Dodge!
  16. 2000 STS Blowing Oil but Can't Find It
  17. 307 Belt diagram?
  18. For those with the 305 Broughams
  19. 5.0L intake manifold (gasket) leak / heal-a-seal feedback & opinions
  20. Tcc
  21. Carburettor Spacer
  22. 93 Fleetwood stalls after idling
  23. Anyone looking for a Olds 350 (72-73, "8" heads) for a swap?
  24. $450 to R2 92 FW Distributor?
  25. check timing
  26. Rare find, 307 Olds rebuilt ready to go
  27. ACDelco Spark Plug Wires...which set?
  28. Fast idle control valve or switching to carberator
  29. 1990 Cadillac Brougham 5.7L V8 Engine Question
  30. Stock rocker arm ration
  31. 1987 Brougham 5.0 vs. 1991 Lincoln Town Car 4.6
  32. 5.7 liter TBI 1991 Brougham. What is this part?
  33. 1989 Cadillac Brougham D'Elegance hesitation
  34. Replacing Spark Plugs
  35. Pulstar spark plugs
  36. Trouble Starting...
  37. Mystery Vacuum hose
  38. Please tell me the fuse location
  39. my 93 cadillac fleetwood turns on for a few seconds and truns right off need advice
  40. LT1 Header Recmndations
  41. How hard is it to change valve seals on a 5.0 brougham
  42. Question about the TBI 305/350.
  43. Thinking of 96 Fleetwood
  44. 1990 Brougham 307 V8
  45. 79 Seville 5.7 EFI Cal Emissions Equipment.
  46. 79 Seville - weird problem?? PCV Line.
  47. signs of transmission failure?
  48. LT1 to LO5
  49. 2000 escalade
  50. K&N air filters/ opinions invited
  51. cooling fan
  52. Trouble code 149?
  53. 5.0 skip... Out of luck?
  54. '91 Bro. 5.0 spak plug strategy???
  55. Help with radiator leak
  56. 1990 Brougham
  57. Did some performance mods, now she won't idle...
  58. Cost of a 5.7 rebuild.
  59. High compression Small Block or LT1?
  60. cooling pressure problems
  61. Failed emisions test
  62. Tweaking the LT1 for better use on E85
  63. Engine size clues in VIN?
  64. throttle/choke springs???
  65. anouther chevy 305 prblem
  66. Has anyone here built up a 91 Chevy 350?
  67. 95 fleetwood VIN P engine swap
  68. not a cadillac 1990 chevy caprice with305 problems
  69. wtb 5.7 vortec
  70. 86 brougham pre ignition after warmup
  71. Fuel pushing out of spark plug holes?!?!
  72. 1992 d'Elegance 5.7 liter coolant smell
  73. whereis the timing indicator on and 86 brougham?
  74. 1989 Brougham water leak...
  75. Old 350 engine build
  76. Odometer reads "ERROR" most of the time
  77. 1990 307 hard cold starts
  78. Intake Manifold Torque specs and order?
  79. 1989 brougham need help ASAP!
  80. Is 5.0 really that bad?
  81. 90 Brougham w/ Olds 350
  82. 1990 Brougham: motor is toast
  83. Q-jet carb for sale
  84. 307 VIN 9: Need help
  85. Need some Vacuum help
  86. 1990 Brougham-Chevy Crate Motor replacement
  87. codes 44+45 1988 Brougham w. 307
  88. 90 Brougham Motor Swap: LT1 or 455 Rocket
  89. Two simple questions about a LT1 Road Master
  90. Engine ping/knock/miss at all RPM ranges.
  91. Q-Jet ID Help
  92. Testing a MAP sensor
  93. Obsolesence of the 307.
  94. Fair warning to anyone looking to rebuild a quadrajet.
  95. Eldorado cutting out
  96. Ht4100 to 350 tbi swap
  97. Fan Clutch Dilemma
  98. Torque convertor keeps unlocking
  99. word of coution for K&N filter owners
  100. 86 Fleetwood Engine Swap
  101. high idle - 89 307
  102. momentary slip at highway speed
  103. ~Need timing directions~1989 Brougham 307
  104. Loose Wire Help- Blue single pin with oval connector?? top of manifold
  105. LS6 v motor into a LT1 F body HELP!
  106. 5A heads on my 307
  107. Dual radiator outlets?
  108. 4 bolt main or 2 bolt main???
  109. Funny noises comming from 1980 Cadillac Eldorado
  110. stumbling LT1
  111. Fuel pump life expectancy
  112. 88 Brougham fuel problem
  113. Optispark
  114. Temp Sending unit mystery
  115. I need a Alternator Bracket
  116. LT1 Intake Replacement
  117. engine colour
  118. 89 Brougham carb needs rebuild...
  119. What's the difference between the LT1 and Vortec 350?
  120. LT1 help!!!
  121. Buildup a V8 like a high revving 4 popper?
  122. LT1 Ignition Module reliability improvement?
  123. Corvette Cam
  124. Engine Rattle.
  125. My Car Runs Crappy....
  126. 403 Swap?
  127. Dexron VI is now 100% all factory fill for GM
  128. Convert that Olds V8 to EFI?
  129. [Link] Carbuerator Rebuild/parts lists manuals for 1986-1988 quadrajets.
  130. Tune up time...89 Brougham (W/ Olds 5.0)
  131. EFE system wierdness on an 88 Brougham/307
  132. High idle???
  133. Performance Air Intake?
  134. More on oils....
  135. 1993 fleetwood performance
  136. pushrod and hydraulic lifters
  137. 5.7 lt1 VS. FORD 4.6 which is more durable
  138. 96 Fleetwood Brougham Exhaust Manifold Bolts
  139. 1988 Brougham (307) carb issue
  140. rough idle
  141. 1994 cadillac fleetwood
  142. code 12,41,42
  143. Occasional vibration/stumble
  144. headers for my 1990 brougham 5.7
  145. LS1 in 88 brougham?
  146. missing, LT1
  147. Ping
  148. Amsoil...
  149. Where does this go on my 307
  150. exhaust bolts
  151. Last minute....hurry...Is this carb a good buy?
  152. 1987-1990 Carburator...replace?
  153. Choke
  154. Motor Going..going..not gone yet but soon im sure..
  155. 1989 Brougham check engine light?
  156. Emissions Test Failure! Please help!
  157. Extension housing bushing, THM 2004R
  158. repost: Oil pressure light
  159. 89 Brougham Acceleration Issue
  160. 307-occasional (oil) smoke from tailpipe
  161. Headers for a 92 TBI 350
  162. chevy 350 in 80's flerrtwood broughm
  163. Technical help 307
  164. performance upgrades for 1990-92 5.7l brougham
  165. Car Won't Run...
  166. Need Headers for a 94 FW
  167. I need some help shaking down a fuel delivery problem!
  168. Difference bethween L05 and LT1
  169. Forget rebuilding a 307! Get a 350!
  170. Optispark?! What the hell?!
  171. Carburetor question
  172. EGRrrrg...
  173. Replacing front crank oil seal on LT1
  174. slight bogging, check engine ligt & I can smell gas
  175. 93 fleetwood surges
  176. Water Pump Done!
  177. Distributor turning
  178. Stalling when making a turn
  179. 1992 305 Poor Start.
  180. Chevy 350 and 200R4
  181. LT1 Throttle Body Cleaning
  182. replacement of engine...where to go
  183. 1992 Brougham 305 Intake Manifold.
  184. Hop of that L05!!! Come on guys!! 330 hp is not that far away!!!
  185. Water Pump
  186. 307 Rebuild!
  187. PCV Valve?
  188. Sounds Crazy
  189. Stalled out
  190. Carb Is A'Poppin
  191. odd knock
  192. getting rid of the 307!
  193. Belt Idler Pulley Question
  194. 87Brougham Ignition Timing
  195. Coolant Leak at Intake Manifold.
  196. Heater control valve is missing on my 84 307.
  197. NOx test failure
  198. Tuning DFCO?
  199. Replacing the Optispark with a N* Ignition?
  200. Custom 'RAISS/SSRI' style intakes & headlight covers!
  201. 1990 Brougham Running Rich
  202. 1992 fleetwood brougham 5.7
  203. Timing set 88 rwd 307 Y
  204. idle problem
  205. Switching to synthetic @ 100k+ miles?
  206. 307 runs bad
  207. Running LS6 injectors on the LT1!
  208. Who runs a K&N or other "high flow" filter on the LT1?
  209. fast idle??
  210. Any Mods Out There For My 93 Fleet?
  211. TPS Code 21 88 5.0 RWD
  212. Oil Disappearing Act in the 307
  213. Dvd
  214. vacuum hoses
  215. failed emissions
  216. Running lean?
  217. What is this?
  218. Baro
  219. map sensor under dash
  220. chevy 350 tbi misfires/backfires
  221. 307 wont start now
  222. 307, 7a Heads Help
  223. master control solenoid problems
  224. 307 V8 Knock
  225. Which LT1 Timing Set?
  226. Gas Leak 84 Electra
  227. Fuel pump on a 1987 307, swapped into a '80 deville
  228. LT1 BiPolar Idle
  229. Edelbrock Power Package for LT1
  230. 89 brougham vacuum problems
  231. my car is running rich
  232. 1979 Seville fuel injection?
  233. Carb problems: Rochester Quadrajet
  234. High Speed Code 45
  235. Im losing coolant, and dont know how, or where its going.Help!
  236. Comparing the 5.0's ( 307 / 305 ).
  237. TBI vs Carburation - 1987 to 1992.
  238. 1993 fleetwood misses while stopped at light
  239. sudden power loss
  240. 92 cadillac fleetwood help!
  241. Help me out here
  242. Need a tune up.... 90 Brougham 307
  243. Muffler
  244. 90' fwb 350 help
  245. Intake Manifold Gasket Replacement Completed.
  246. 307 vin y cam
  247. Vss
  248. '93 FWB missing BADLY
  249. cold air induction
  250. help with oil leaks!
