- Help with identifying a GM Goodwrench replacement block.
- Where is the MAP sensor located ???? 84 Seville
- 89 Deville engine pinging under load when warm
- new isc and tps
- Code Triggered: E66
- Low oil pressure at idle
- 4.x starter interchange list
- 4.9 91' coupe suspension level
- 4100 timing question
- Where do these fuel lines run??
- 1990 Sedan Deville 4.5L A Few Questions
- Uneven idle
- Teardown set for friday ...
- Ac Compressor
- Is this repair worth it?
- How Hot is too hot, Ouchi Hottie story inside.
- 89 cadillac 4.5 oxygen sensors
- Bore spacing
- 87 Deville NO FUEL!!!!
- FWD HT4100 air pump pupose?
- pinhole in block, leaks coolant, what should I do?
- 4.9 Just started running rough at idle
- Repair cost too high?
- 1990 Cadillac Sedan DeVille - Idling Too High
- HT4100 valve train pics
- Thermosat Question
- Am I stuck having to use an 80 series muffler?
- Strange COOLANT SENSOR readings--And engine cuts out while driving!!!
- water pump
- Oil Pan Gasket replacement on a 4.5L
- Error Code E41 — Camshaft Position Sensor
- 4.9 starter problems
- 94 deville runs rough at cold start
- So Even After $700 dollars it still leaks!
- Swap ?'s
- Emission test failure
- How do I get my 4.5L to coast down to the "70 mpg" benchmark?
- A question about the Rotella Motor Oil
- Pls Help 4.9 ac compressor froze
- Deville shakes violently .. Please help!
- 1993 Deville ODB Codes Tripped, Idle Motor
- EGR valve replacement fixed the knocking problem!
- water pump leaking after i change it
- How to enter override E.5.3 on a '90 DeVille
- Hose question & error code 30 and 34
- 87 Deville Intake
- 4.9 intake manifold
- Feels like mis-fire. 85 fleetwood 4.1
- Engine replacement on an 88 Coupe
- fuel pump?????
- wot's and front oil seal
- oil pan gaskets
- emissions failed
- Crossover pipe
- I got into my diagnostics w/o a clue
- Code P039 Current?
- error code
- Pump thingy :/ 4.1 HT
- Programers???
- first service on my 89 deville
- stumbling, hesitation under load only
- 4.9 acceleration? ? ?
- Head or Intake?
- Are 1990 Throttle bodies obsolete?
- 91 DeVille Stalls Repeatedly
- Engine Soon EGR code
- Motor mounts/CV Joint
- Deville Acclerating
- need help
- i need help
- 4.5 to 4.9?
- HT4100 MSD IGNITON, should I ?
- Cooling Pipe Crack
- HT4100 Question
- 4.9l bolt on mods??
- I hate this car.
- Stumbling, hesitation, backfiring 89 Deville 4.5
- Distributor cap wiring help!!! 4.5 litre 89 deville
- HT4100 vacuum pump
- Yet another head gasket question
- Fuel injection question
- Fuel tank baffles or pump?
- 88 Coupe Deville Intake Manifold or Head gasket
- Help required !!
- Crazy Cadillacs
- This is a weird one
- Ok Guys, So what parts break? Engine Wise.
- 91 deville runs a little hot
- Fuel Pump Revisited
- 4.9 knocking
- WTF? Why won't this thing just blow up...
- 95 deville idle problem...2
- Deville 4.1 fwd rear main oil seal leak :(
- water pumps
- Nasty squeal - water pump?
- what EXACTLY do I need...?!
- 1988 Cadillac Coupe Deville Head Gasket
- Thermostat housing torque specs
- Engine compartment revisions!
- 1990 fleetwood engine miss please help
- I think I need a distributor 89 Deville 4.5
- A blog for Caddy fans
- MGB 4.5 project
- E52 code
- spark wires cover - removal help
- 1990 deville 4.5 won't even turn over
- water pump replacement
- Wheel Bearing installation - help....
- Remeber where those vac lines go.....
- E Codes on my 4.5 HELP
- E39 and E48 codes could I get some advice?
- Can anything go wrong/Flushing coolant?
- Another way to pull codes?
- Camshaft lifter questions
- exhaust manifold
- 4.5L ECM inputs
- Why I hate NTK Oxy Sensors from Now ON.
- Coolant pellets/conditoner
- Prob with 86 deville sedan with 4.9L *HELP*
- Ported vacuum switch--supposed to have a wire connected to it?
- 4.9L Aluminum Head project?
- Stoneage_caddy I had my car's fuel preasure checked today,have a couple of questions
- Anyone running an Auto meter Air/Fuel Ratio meter.
- What O2 sensor(s) are you using.
- antifreeze for my 85 fleetwoods ht4100
- Antifreeze for my HT4100
- 1989 Eldorado Biarritz MPG
- 1991 deville engine dies when coasting
- The Homemade 5 Liter PFI Project .....
- 85 seville valve lifters
- Blown 4.1 ht in 83 eldorado ?? how to tell ?
- Bogging problem
- Throttle body problem, help please
- I knew I saw it someplace, now where did it go, no not my sanity but close?
- 4.5......which sensor is bad?
- 4.9 bearing part number or TSB?
- Help with HT4100 water pump
- which is the better motor
- Nitrous Question
- 1995 DeVille Idle Fluctuation
- issues w/ back pressure?!?
- Well the pump is on, but my serpentine belt...what?
- 83 Sedan Deville 4100
- Its an Invasion 4.9, 5spd Stick Fiero
- why I love my 4.5...
- 1985 deville coolant and heater core questions.
- New member here, and I need some '93 Deville help (water pump installation)
- 1990 Allante Bosch fuel injectors/FiveOMotorsports
- Cleaning '90 EGR 4.5
- Groll Polluter FIXED??????????????????
- Where does this fuel line run?
- 88 Deville.Tensioner Pulley.
- 85 4100 is running rough and hesitating
- car will not go past 35mph 82 with a 4.1
- Does anyone have a picture or info on the Negative block ground?
- EGR Cleaning
- Cheap quality Rebuilt transmissions
- 4.5 Fast Idle problem
- I need a no Yo-Yo shift-kit immediately!! '84 RWD DeVille
- 93 Runs rough & loud when wet
- Spark Plug Replacement
- Fuel Injector Compatiblity
- Oil pan gasket
- No Spark/ No Start Problem/ Pulling what hair I have left out!
- oil change
- Accel fuel injectors
- Alldata (autozone)????????????????????
- A/C Compressor
- Help ECM E85
- Fuel Pumps on '82-85 HT4100 -- Life span??
- Analyzing Fuel Economy
- Difference between '82 vs '85 Fuel Injectors on the HT4100????
- Oil Theories
- Got Injectors? 4.9/4.5
- E048
- Why Wont This Car Start After I Put In A New Alternator.
- '85 Throttle Body in an 82 Eldo???
- 4.9 knocking
- Hole In Muffler(Recommended Replacement)
- 91 DeVille
- In reguard to my deville's rough idleing,could it just need an induction service?
- Code question.
- Plugs for 4.9
- 1994 Deville 4.9 (Serpentine Belt) - Save Me From the Junk Yard
- Inaccurate gas readout?
- 1990 Allante fuel injectors
- 4.9 with sleeves?
- 4.9 Air Cleaner
- Stoneage_caddy my deville is stuttering when idleing,any ideas?
- 92 4.9 fleetwood high idle
- 1994 4.9L won't pass emissions HCs too high How to fix?
- HELLO - I'm seeing an error code 52 - any idea what that means?
- 4100 Reliability
- 1982 eldorado low oiil pressure light on immediately after oil change??
- 82 deville VIBE SOLVED
- let the thing blow up??
- Low Oil Pressure Light 1982 eldorado
- engins problem
- radiator blew apart
- new to the forum - big problem
- Whats the best place to find a replacment 4.9
- RE: 82 deville
- 4.1 ELDO Hesitation and Stall
- 84 4.1 Eldo
- Fuel Injectors
- Regular gas vs. premium gas
- used injectors
- 82 deville vibration
- '84 Eldo Failed NOx
- Wow...26+ MPG in a 3900# vehicle with over 700 lbs of cargo/passengers
- Collapsed UPPER Rad Hose!
- injectors
- 4.9 Froze
- 4.1 Giving 3 codes...Need help
- Is the 4.9 Under Rated?
- I need a water pump have a couple of questions.
- 4.1 v6, 4.1 v8-- What's the differance?
- Dip Stick Tube
- 85 Fleetwood Brougham W/ 4100 -- No Start...
- Open or closed deck block
- Emission Results fine in set timing mode?
- A new problem...
- 4.9 Dead - How easy to swap in a 4.5?
- need some help
- What are common issues with the 4.9?
- injector part number
- Overheating not block or head 83 Brougham anyone know whats wrong?
- changing spark plugs
- A few qestions regarding timing, etc.
- 1990 feleetwood codes on air control panel
- 93 seville sls idle problems
- 86 Cadillac Deville Timing
- 85 FWB W/ 4100 Hesitation...
- 89 Deville, What would cause this?
- THROTTLE PROBLEMS 95 DeVILLE 4.9
- Can't seem to fond the answer.
- Anyone tested 4.9's fwhp?
- Could a catalytic convertor go bad in 2 years?
- Switched Oil and now it clatters!!!!!
- Fuel Injectors help!!!
- 1990 Allante Engine
- ISC motor ratchets after shutoff
- BBOB or ANYONE---A LITTLE HELP!!
- Need help with fuel system
- Got a VSS code on my 1990 Deville!!
- fuel injection parts
- Does the 4.9 really need 91 octane????
- When do u change the O2 sensors?
