- 87 Seville...Engine problems, knocking, overheating,do I shoot it?
- Can I use a regular fuel filter?
- Where is the fuel filter?
- RWD tranny for 4.9L??
- please help!!!!!!!
- Did I go overboard?
- Fuel: Maladies, Mayhem...Mileage!
- Errr... Map/Baro code. No clue what to do.
- Can a CS144 generator on a 4.9L be opened?
- Newbie here with a stall problem!
- The tricky TV cable...
- Now its knocking and oil light is on!!!
- Uh oh! I think my waterpump finally went!
- Accursed Ignition Timing...
- Whats makes one of your throtte blades wires Loose on one of the throttle blades
- How to gut a cat?
- Cooling Fans
- 90 Seville.. obd codes beginning with R??
- Sometimes she idles at 600-625... sometimes 900
- Oxygen sensor cured startup WOT
- Transmission rough downshifting to 1st
- Power Steering Leak...
- Tranny problem on an 89 eldo!
- If you need scans of service manual.. 1990 Cadillac
- This poor ol' car has been so abused.
- ****!!!! Flat Cam Now!!!!!!
- E53 - Distributor Signal Interrupt
- help
- HT-4100 modified for flex-fuel?
- 94 problem
- 4100 Engine Modified for Flex-Fuel?
- How important is the PCV?
- Replace the alternator or don't do it?
- 82 Hearse Hard Starting Cold - Codes
- Slight tick at idle, '92 Sedan deVille.
- Coolant Hell (and *gulp* headgasket?)
- Inconsistent loud bang from under hood
- mmmm Swisschesse.......ed the airbox :).
- Info on fuel injectors
- God No!!!!!!
- Reduced EGR flow - Detonation
- Fuel Pressure Inquiries
- My 4100 will not go past 50mph
- How come my motor goes full throttle on startup?
- Why are 4.x lifters noisy?
- 4.5 TBI vs 4.1 TBI
- power steering pump
- 93 Deville Loss of Power getting 6-7 MPG !!!
- Need Help Bad!
- 4.9 Exhaust
- 83 Eldorado swapping 4100 motors
- Wikipedia contradicted what I thought I knew
- I bought another HT4100 - a hearse
- Striped 4.9 Head Bolts Please Help
- Quick alternator question
- Please help! #1 service main part#?? 4.9 3545718 no good according to Cadillac?
- changing the distributer cap and rotor on a 91 deville 4.9
- Kill Switch - 1990 Cadillac DeVille
- Advice! My idle has gone nuts!
- SeaFoam Method
- Need Throttle Body Help!
- Shorted Mat sensor signal, E37.
- rhoads lifters?
- Say I buy a new 4.5 and transmission.. give me a rundown of wht it takes to put it in
- YES!!! It RUNS!!!!!
- Plugs and wires..
- Shadetree hall of shame.. I did something STUPID
- 4.9 Cracked Block Leaking Coolant
- How bad is this on the transmission...
- Rattling...
- Questions about replacing 4.5 motor/tranny
- 4.9 is running niiiiiiiiice.....
- Questions on ISC
- 4100 Timing Advance question.
- what causes an e55?
- 92 deville 4.9 timing cover question
- Why Does ?
- Fuel Injector Selection
- No overdrive
- Wobbly pulley
- 4.1 spark plug ????
- How much does 4.1 engine weigh??
- 1990 Cadillac Sedan DeVille
- Here is a video of the 86 fleetwood.
- Who's 4100 sounds like this?
- What is the BEST MOTOR FLUSH out there?
- Collapsed lifter!
- MAT sensor?
- Engine cradle bolts?
- Cam shaft test?...
- Can't get these bolts off...
- GM top end cleaner or seafoam..
- I broke my motor
- What causes a f48 code?
- Need to know ?
- GM Too Expensive Cleaner...
- oil problem
- I Am A Retard
- Engine Miss, (electronic not mechanical)
- Help with Plug Wires and a few other items on 4.9L 93 SDV
- 1985 4.1 Help
- 93' 4.9 Eldorado Heating
- Factory 4.x alternator
- Back firing/stalling/knocking HT-4100
- 88 deville tech question?
- Engine Upgrade?
- Little help with throttle issue...
- Custom Exhaust Manifolds and down pipe... for the 4.9
- 4.9 or 4.6
- FWD 86 Fleetwood For Sale.
- whats the diffrence?
- Help with cold stalling problem
- Misfire and absent fuel
- Timing 4.1L How to loosen dist???
- Tranny fluid frustration
- rough idle and bad miss
- Engine paranoia
- What are the pro's and con's of upgradeing your ignition system on a 4.9?
- remove fuel rail to change fpr on 4.9
- EGR Valve Location
- A question of exhaust theory...
- ecm data
- Fuel Injector Ripoff...
- Diagnostic code ?/EGR Valve
- '85 Deville, HT4100, considerable problems running properly...seeking help
- Looking For More Power From My 4.1
- Serpentine Belt Diagram 4100
- OBDI vs OBDII; AC compressor
- idle problem
- 4.9 distributor bushing wear
- What should I do to fix my bad gas mialage (really bad)
- Does the fpr have to leak to be bad?
- What is this sensor on the back of my 4.9 motor?
- Need help on alighning PRNDL switch.
- P/N for gaskets
- 88 Eldorado wont start
- prndl code
- E046 message
- PCV pipe???
- 10 mpg city and its not even like a city.Can it be my fpr.
- car throwing codes, decypher them please :D
- Fuel Pressure 92 Deville
- performance ??? ht4100
- ht4100 ?????
- Breather on 4T60E, is there and if so where is it?
- 1990 deville low reading
- 1990 deville vacuum
- Throttle body gasket?
- 90 Deville ignition wire, cap, rotor
- 91 deville stumbles after warming up
- 83 cadillac 4.1
- Timing Chain
- Discussion about caddeville's project (split from 4.9 into 88 Eldorado)
- Why Wont It Start?!!!
- 4.9 into 88 eldorado
- 83'Eldorado 2 camshafts later and it wont start
- Northern Indiana Users?
- engine ping,
- Speed limiter...
- Octane and fuel prices vs performance
- Any fresh tips for re-manufactured 4100 seeker?
- 4.5 wont start after head gaskets
- Advancing timing, need help...
- Whistling Sound
- Comparing Dexcool and green stuff
- My Fuel Injectors :(
- Sonofabitch !!!!!!
- 4100 emmissions air pump
- 1990 deville help
- Power improvement... from a carburator?
- Sad Caddy's in the background.
- Water Pump for 89 DeVille
- Heatsoak and Starters. Is this a Caddy problem too or just Cadero's.
- ISC motor problem? '94 Deville
- 88 DeVille Serpentine Belt
- Noise in Transmission?
- Coolant Leak - How to find?
- Good care (ATF) for 4T60E
- 1994 Deville 4.9 fuel pressure
- Please help an old man. (Backfiring voodoo fleetwood)
- Please Help! 4.9 won't shift out of second gear.
- Tranny problems engaging
- 89 deville 4.5 tranny in 93 seville 4.9 will it work?
- Need help asap.I have a draeded p093, is my trans gone?
- Some people just don't want to listen
- 92 Deville Rough Idle Periodic Stallin
- (3 4.9 bad mpg.Can low ac refrigerint cause this?
- Need a good write up for cleaning Tb and EGR valve please (4.9)
- WOT with a high mileage 4.9?
- Is my transmission fluid ok or do I need to change it out?
- 4T60E transmission problem??
- Messed up my transmission
- Simple question, what does the HT stand for
- Emmissions Testing and the 4.9 and BC Canada guys in here
- Knocking
- Knock sensor on HT4100?
- Cold air zapping coil!
- Error code 29
- Replaced everything...stumble is worse.
- 1984 Eldo 4.1 Engine Color Needed
- frontend noise
- Fastchip - Does it work?
- Does everyone have mandrel-bent piping?
- What is the Factory Timing for a 93 Eldorado
- I want a DIC (get your mind out of the gutter) :D
- 4.9 in Brougham??
- engine change
- Ram Air/Cold air intake for 4.9?
- Underdrive pulleys?
- Braking Engine Jump... 1990 DeVille
- engine miss 4.5 ???
- '90 DeVille ISC motor problem SOLVED
- 94 Deville misses backfires & DIES! whats wrong
- Fuel injector problem?
- Can't get my 4.9 to Adjust timing
- Valve Lash Adjustment
- 95 4.9 flywheel breakage?
- Fuel Pump Relay
- Not getting enough spark
- Not again!!
- Oxygen Sensor
- 4.9L Fuel Economy
- HT 4100 - Success stories
- Gurgling Sound In Engine?
- Second generation HT4100
- 1984 Fleetwood Code 52 ECM memory reset problem
- 84 Eldorado No Start
- engine rev's and dies
- Engine revs when I turn the wheel????????
- throddle control
- something happened today with the 90 deville and i don't know what
- unique problem 4.9
- Stoneys Main Bearing Diary
- nees help fast please
- 4.9 timing is hard! Idles rough, stumble on acceleration
- Water Pump Leakage!!!
- Min air ????
- Help with a water pump installation!!
- How to replace water pump on 92 seville?
- Another TPS ?????
- 87 Deville 4.1- No fuel!!!!!
- horsepower for 4.9
- A question for the gurus
- Trans cooler leak!
- 1990 Cadillac Sedan Deville high idle
- new oils verses old oils
- Minimum IDLE SCREW adjustment
- Oil cooler line o-ring
- Is my ISC motor shot? ('90 4.5L)
- Help with identifying a GM Goodwrench replacement block.
