- ECM software
- 130 mph in a 4.9!
- Frozen Pulley
- Ignition Module issue
- Removing EGR valve - 4100
- Bad alternator in 93 Deville, need help
- Restore Lubricants
- Bad Head Gasket 92 DeVille 4.9- Need opinion
- Throttle Position Sensor Misadjusted
- A.I.R. Pump 4.5l '89 Deville
- temp sensor
- Don't ask oil questions on this site.
- 1985 deville died
- where do i go from here
- Need Help On Two More Things
- serious help needed
- 1983 Caddy transmission
- Strange Timing Issues
- Mobil 1 10W30
- 1985 Deville with a 4100 and it will not crank
- Code E48 diagnosis
- codes ???please help
- 4.5 Allante intake on 93 4.9 deville
- New Trouble Code
- 1989 Caddy Deville......
- Throttle Body Plate issue
- Code and Coolant Prob.
- Low oil pressure!
- Oil Cooler Lines Leaking
- 1989 Caddy Deville......help!!!
- Stallling at idle
- gas pedal
- 4.5 TBI rough idle
- 94 Deville has almost no power from start
- 84 eldo conv't - 70 weight oil - yes or no?
- E012,E053 Won't run
- 1990 Seville Timing chain?
- 4.9 groaning
- '84 Eldo Code 44
- HT-4500 Starting trouble
- Speedometer Sensor issue ?
- The Ultimate FWD Cadillac Engine Swap
- Sticky Gas Pedal...4.5L
- Underhood smoking... need help with a diagnosis
- Fixed EGR now MPG is lower
- engin and trany swap for an 85 coupe deville
- Favorite things about the 4.9?
- 86 EGR Valve
- 4.5 TBI smoking
- Fuel pump on 4.9 92 Deville
- Fleetwood/DeVille Speedometer
- 4.1 Knock?? Or Tap??
- 1990 deville 4.5 air pump noisy
- 4.5L TBI Grumbling
- HT4500 and 4900 series Performance
- 4.1L injector
- how to get more hp from a 4100
- Intermittent Lurch—91 DeVille 4.9
- MAP Problems
- Oil Level
- How to start when very cold (less than 0 F)
- Need Help Please
- Engine surges at slow speed
- Stop Engine, Low Oil Pressure
- 1988 Fleetwood 4.5 Distributor order
- 1985 Seville Power Steering Pulley bolt
- Installing oil pump in 4.9 engine.
- 1985 deville ht4100 jump start
- GM Top End Cleaner Has Been Discontinued
- Makes Me Happy!
- HT4100 Question
- HT 4100 knock, 83 Eldorado (I know, another thread on this)
- Makes me nervous!
- 4.9 E55 code. TPS?
- Thoughts on the 4.5
- power steering leakk
- The SEA FOAM experience thread.
- Oh just great, a collapsed lifter in #1 cylinder!!
- 94 4.9 bypass siezed A/C compressor
- 85 Deville Still Has Poor Performance
- Need exhaust manifolds 4.1 HT4100
- 93 Deville stalls after car warms up
- New Caddy Owner, Need Some Help
- Rattle Under Car
- What kind of ISC motor should i get?
- 84 eldorado fuse panel pictures?
- Crack in my Block
- 93 DeVille AC converter clutch bypass ???
- Cooling System - Water Pump Conditioner/Anti-Rust
- Stock Exhaust dimensions on 93 Devilles
- Campaign 95-C-72 (recall)
- fuel pressure????
- Just finished my 4.9 Water pump repair pics inside
- 4.9L Rear Oil Leak
- Quick question: Ignition Control Module
- Disaster
- EGR Valve
- 4.1 main bearing thump
- Tranny problems, E39!! Please help, dont want to rebuild...
- 95 Deville 4.9 need help
- OMG water pump problem!
- Bypass Catalytic Converter on 1993 Deville?
- Starter motor gone on 87 deville 4.1
- Need help 4.9 L Fuel Delivery problem
- 92 4.9 DeVille runs horrible, sets codes
- Roller Lifters On The 4.9?
- water pump change on 4.1ltr
- 93 deville
- 1993 Cadillac Seville: Please Help starting problem
- Bad coil?
- Rebuilding a tbi on 89 deville
- I Broke it
- 4.9 Surges After Hot Start
- Poor mileage and slighly high HC levels
- engine oil cooler lines
- Smoke out of exhaust
- Cleaned out my EGR tubes today, my E.4.8 code is gone!
- code help
- Low mileage 4.9 Idling Rough Engine Sputters and quits
- First time Caddy owner needs some advice please
- Trouble with diagnostics
- changing oil pump in 90 deville 4.5
- Help I dont want to get rid of my car BUT!
- Has anyone changed their catalytic converter?
- 4.9 Liter idle
- Removing hydraulic fittings
- How many miles on the 4.9? ?
- 88 Sedan Deville not liking the winter
- Coolant hose to blower motor
- Timing Question
- '84 Eldorado blown head gasket?
- Oil pan heater?
- 4.9 Deville 95 whining noise like supercharger..
- Location of the CAM Position Sensor on the 95 4.9L deville?
- YES, i did it!!! All went well!
- 92 Eldo 4.9 for sale
- 4.5 water pump
- 93 4.9 STS wont start
- DESPERATELY Need Help!!! 85 CDV
- Trying to find good price on Allante gear reduction to use on my 4.9
- How to clean out EGR valves and throttle body?
- time for engine replacement soon-- help!
- Heater
- Hard starting
- 4.5 differences
- E98 rectification
- 87 fleetwood new ignition problem
- 1985 deville 4.1 Injector fuse keeps blowing
- PCM override, PS10
- EGR solenoid, is it normal?
- Get a LARGER capacity, 3 row radiator?
- Smoky when at full throttle!
- What does the code F.8.5 mean?
- 87 fleetwood 4.1 three problems,advice please!
- Removed Distributor--Question Before I Restart
- Changed the oil pump, lifter still taps on occasion warmed up..
- 87 deville, E48, EGR system problem
- Additive for newly remaned 86 DeVille Trans??
- Is it possible for a 4.9 main bearing thump to get progressively worse?
- 1989 Sedandeville issues
- 15W-40 Oil .....
- Fuel
- 82 eldorado alternator bracket
- 85 Deville ISC Problem--Might Have the Answer
- Help me Please!!!
- Weird idea
- Engine miss
- Pulled a thread
- E12 - No Distributor Signal???
- computer interchange, '90 Seville?
- Where Can I get some chips......
- Oil leak source...?
- well, i did it but...
- HT4100 ECM/BCM Problem?!
- #$$%^%@#$% damn .....floods on hot restart
- can't flush out "rubber glue type" coolant additive... what to do?
- Transmission Shift cable
- HT4100 ISC Help
- 4t60-E going out
- Fuel Issues - Please Help!
- 4t60-E FDR and the computer
- Fixed my car! Need help on one more thing...
- What's wrong with my car? The mystery continues...
- When i go to replace the mains....
- 4t60-E Shudder?
- last year
- All 4.x engine service parts are discontinued?
- Does anybody have a spare 4.9?
- Knock, Knock, Knock, 4.9L
- Alright, i'm going in!! I need a few parts and info please.
- 90 4.5L Idle Learn Procedure?
- I have a slight problem,,, HT4100
- Fuel Pressure Test Fitting
- 1985 Seville code e15
- Cooling Fan Module--Where can I get one?
- Bars Leaks Head Gasket Repair
- Code E30 on 85 Deville and Vacuum Pumps
- Copper Gaskets?
- Battery/ALternator area cracking noise?
- Oil Analysis: Proof is in the results
- 1992 Eldo
- That Funky Emissions Tubing
- Hey Guys long time no chat, and long time not wanting to start either.
- The once a year survival kit for the 4.X series
- 4.9 runs rough black exhaust from tail pipe
- 1985 Seville harsh shifting tranny
- Odd brief buzzing noise from undercarriage
- i need a 4t60e guru; i am hating mine
- what is up with my car
- Early vs. Late 1985 FWD 4100
- Strange ISC
- 1994 cadillac deville engine knocks when warm
- 4.5 --> 4.9
- Getting ready for water pump removal
- 1988 Eldorado 4.5
- 1985 FWD HT4100 Running rough
- Question about spark plugs!
- TPS problem?
- 4100 Mpg
- 87 deville 4100 shift problems
- 1991 DeVille Speedometer/Transmission Trouble.
- Starter solenoid replacement
- 4.9 Injector Replacement Questions
- 92 STS error code A048 what does that mean?
- 1994 Deville 4.9 Idler pulleys
- Please Help!!! Rough running 4.9 , Help!!
- 1994 Deville 4.9 spark knock
- 85 Sedan Deville Stalls after 20 Miles
- 4.9 Potential? (Split from "4.9 to a 5.0?")
- 94 Deville 4.9 switching complete sending/fuel pumps
- 4.9 to a 5.0?
- Fan Runs all the time on 4.9, engine runs real cold
- AHHH HELP!!! Keep overheating
- 4.5 Vs. 4.9
- Fuel Mileage vs. Data Center
- 92 4.9 flat cam?
- Does twitchy tach mean misfire?
- ht 4100 Hesitation
- 1987 SDV 4.1 L V-8 Available
- 89 4.5 TPS installations
- 89 Fleetword code (30) ISC Circuit
- Boiling coolant, fans not running, ...
- no start after warm engine
- 1989 4.5 Idle Speed Motor
- 1989 Fleetwood Idle Speed Motor
- Valve Adjustment 4.9 Engine
- remaned 4.1/4.5 short block
- 4100 to LT1 swap 83 Coupe Deville
- Cylinder head removal
