- What's the difference between ignition modules?
- Very strange engine problem 4.9L =HELP=
- 92 Deville 4.9 miss at idle
- 92 Deville blown headgasket or intake manifold?
- 1995 devile "service engine soon" light comes out , need help
- 91 Sedan DeVille Stall
- 1985 DeVille allternator wire (brown)
- 88 DeVille ELC not functioning
- 1988 DeVille Motor Mount Help
- heater hoses, any tips how to get these out?
- strut/axle/transmisiion problem
- Power Steering Woes
- flushing radiator fluid
- Break Release?
- '83 Eldorado with HT4100 V8, Rebuild or Replace?
- 89 coup deville coolant leak
- removeing crankshaft pulley bolt
- Back to my coolant flow problems
- help needed "no charge" light 83 eldorado 4.1
- Quick, Simple Question.
- 84 coupeD 4.1
- Engine Compartment Diagram Needed
- Re-install distributor
- Where to get a water pump pulley
- Don't deal with Remanufactured.com
- 1982 Cadillac Fleetwood. Code 52 PCM Reset. Dead Alternator. And my friends screw up.
- Vacuum on 4.5 Seville
- Alternator Bracket for Eldorado '85
- Different 4.1s?
- 91 Sedan Deville 4.9L CAR WON'T START
- 1992 Cadillac DeVille FOR SALE!!!!
- Fuel Injector 4.5
- 91 seville suspension dryer
- Voltage discrepancies
- Best way to clean out dead gas residue in tank?
- 4.9 map sensor problem?
- '91 Fleetwood Coupe has demons under the hood
- Replaced Head Gasket
- Looking for online source for TVS Switch for 85 HT4100
- I plan to make more of an appearance here...
- 93 4.9 motor
- intake manifold insides
- ISC pricing?
- coolant leak (pics)
- 91 seville heater control valve?
- 4.1 swap
- replacement valve covers
- 1992 DeVille Tune Up
- surging, only when warm
- 91 seville 4.9l owners manual
- Won't start. E12 .
- 4.9 wont stay running/wont start
- Anybody have a 91 seville 4.9l
- 1990 deville won't stay running
- 4.9L Spark Knock
- seperating engine and transmission
- 4.1 to Olds 403 swap
- 1994 cadillac sedan deville 4.9l please help!!
- ISC plunger question
- weird noise then belt pops off
- 91 seville 4.9 wheels?
- Service soon - refer to owners manual
- 91 seville trunk pull-down motor
- My engine build up
- PO39 and IO39 codes
- Car will not start-Distributor
- wats the MAP sensor
- high side temperature sensor circuit
- wats history after a code mean and how do i refesh list
- 92 deville wont start
- unbolting torque converter from flexplate
- Cracked head or head gasket
- 1983 4.1 Vs. 1985 4.1
- Another Anti Freeze question
- New problem
- Mixed up spark plug wire chaos!!!!!
- 91 seville 4.9 fan problems
- 94 Deville 4.9L
- 94 Cadillac SLS Idle Probelms
- Where to purchase a new ISC motor?
- Relay
- Question
- Head Bolt Torque Specifications?
- gasket question
- How hard it is to remove intake manifold???
- Diagram
- Real problem
- Extra HP & Torque
- How to adjust ISC
- replaced waterpump
- "Sail on" after cleaning throttle body
- Exhaust Gas in Radiator
- 2003 dhs trouble code p0300
- Cadillac trouble
- Cadillac trouble
- 1994 Deville leaking coolant
- 83 4.1 misfiring bad when running cold at constant speed
- Engine (4.1) won't start, stumbling when starting
- Dipstick doesn't match crankcase oil level
- The end is near? The end is here?
- Changing the FDR: What do I need?
- loss of hp?
- 93 eldo 4.9 overheating
- 93 exhaust question
- Prolly a dumb question:
- New Distributor Help
- water drowning out 84 caddy
- is it my spark plugs?
- Finally....Start-Up
- New problem: racing after cold startups now
- Common 4.1L Problems
- 91 deville surging idle
- '85 Fleetwood FWD 140K+ Miles! Hose questions
- Still got a miss at times
- Distributor won't drop.....
- '94 Sedan Deville, Parting out...Complete car
- 4.5 mess
- 4.9 intake gaskets
- Vacuum tube replacement
- Changing belts on 84 deville
- Coolant leak from WP cover
- Distributor Compatiblity 4.9 into a 4.5?
- Heater Core Removal 83 Eldorado
- 91 deville needs head gasket
- Sluggish acceleration
- 93 Eldorado clunking under load
- 4.1 just cuts out then comes back
- Oil pan gasket: Is it worth it?
- 4x engine as boat power?
- Cat converter exhaust flange
- Cooling system sealant
- 1983 4.1, 6 mpg in town driving ????
- 4.9 Headgasket ?
- E13, e44
- Help w/ Temp Fan Light on '85 Deville
- 15w-40 too heavy for a 61k mile 4.5?
- Operating temp: Whats the norm?
- The Last Stretch:Tranny Mods.
- timing marks
- Distributor Wiring Harness Compatability?
- Going from conventional to Synthetic - Good or bad?
- E46 code
- E98?
- 4.9 Lifespan?
- Return Line Pressure?
- 92 seville 4.9L engine problem
- alternator question
- Odd "Cold" Idle
- Rotten 4.1 do they just normally overheat ???
- Starter Change
- 83 Eldorado No power to HVAC controls or Mileage calculator
- Cam position sensor replacement
- A.L.D.L connector, setting timing
- The 93 SDV is dead!
- 1989 Seville Transmission shifts - Vac Modulator?
- thinking about 1994 Sedan deville
- Will there be a mess
- 1990 Eldorado runs ruff
- The 6 flexplate to crankshaft bolts
- Coolant
- Well, found one of my oil leaks...
- 92 Deville Shuts of suddenly
- Exhaust manifold gasket set
- Fuel Pump Cheat?
- 1995 Devile 4.9 Oil Leak
- Found my oil-leak
- Check this guy out: 91 Seville with 'questionable' mods
- Hose substution
- Thermostat
- Which of these?
- New Performance 4.9 Injector Mod. and Adjustable Fuel Pressure Regulator
- 1994 Cadillac Deville High Idle
- 91 deville, dead miss
- heater controls 92 eldo.
- How many tablets or bars leak?
- Distributor Help
- Proper Spark Plug Gap for 4.5
- 1990 Deville 4.5 help
- Yes, I Did It
- Harmonic Balance
- ECM Swap! PASSkey Question...
- Accel Performance Ignition Module: Real or B/S?
- 4100 engine temperature
- '90 4.5 No Cam Sensor Reference Signal Journey Through Hell!
- Ongoing Issues, running rough poor idle
- Trans cooler flush
- screw the whole thing - i hate the 4100... swap ideas?
- oil sender location - 4.1
- code po23??? Any thoughts
- 4.9 exhaust info
- Throttle valve cable '85
- oil pressure light came on - towed home
- clackin noise 4.9 deville
- Oil-leak solved!
- WOW this is a 4.9
- PO48 Current/ EGR Fault
- Oil Pressure
- E98 code on 4.5
- ...the HG gremlin got me
- Help identify 4.9 engine noise (video included)
- Head Gasket 91 caddy
- Once again......no joy
- BCM Location?
- Oil-tube gasket & o-ring
- 84 cdv 4100
- Question on oil leak - 1989 Seville
- No Joy....
- RTV on Oil-Pan gasket
- Block number?
- One problem fixed another shows up. Starter
- 4.9 Software
- How do I bypass PASKEY
- Rough running, bad mileage, unstable idle
- Trouble Starting When Warm
- Clattering noise from engine front area
- What is this hose called???
- 83 Eldorado 4.1 auto OD Trans Model # Please
- 1986 deville 4.1L
- Sedan Deville 4.1 to 4.5 Disaster Swap “This time I got right” part 2
- 89 Seville ignition switch click - VATS?
- Which a/c compressor to buy for round 4...advice please
- Carnut, got it to work, Thanks !
- wont start when warm
- B336 code, 86 seville
- transmission parts and specks
- Transmission advice
- 4.5-4.9 less inclined for h.g. problems
- Transmission Cooler Lines
- Severs Idle Problem
- 83 Eldo 4.1 Hesitation upon accelleration
- Coolant Change and GM Sealant Questions
- 95 DeVille PCM Codes
- Cleaning an ISC motor from a 1989 Seville
- Water in oil - Head/intake maniforld gasket job
- Loud bang, car won't turn over. 4100 '82 Deville
- Coolant Leak
- A/C Compressor Clutch Engagement Issues
- 83 Eldo 4.1 Climate Control only lights sometimes
- 1989 Deville code help
- 83 4.1 overheated, now, an ISC problem !
- car doesn't switch to 3rd gear
- Performance 4.9
- New Life
- 92 Deville 4.9 FPR
- plug wire routing conduit/loom
- Alternator Pulley
- 88 Sedan Deville 4.5L intermittently starts, sometimes dies driving
- gear indicator fault :(
- 4100 Fuel Problem - Advice Please...
