: HT4100 4.1, 4.5, 4.9
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17
  1. 4.1 to 4.5 swap
  2. How much for New Head Gaskets?
  3. new mat and coolent sensors
  4. rough idle and sputtering
  5. 4.1 exhaust manifold
  6. 4.9 Head Gasket
  7. problem with "service engine soon"
  8. Advance timing on 4.9
  9. What MPG for 87 Eldorado, 4.1?
  10. E048 EGR fault code how to fix?
  11. 4.9 And The Gas Mileage Sucks!!!
  12. Any way to disable the ses light?
  13. 95 deville tranny question
  14. 92' dies then restarts by its self
  15. ECM pinouts
  16. Dead 89 deville engine
  17. Going to be a long weekend
  18. A few questions for the Caddy Experts 4.9L
  19. old radiator cap problematic?
  20. 4.9 ltr
  21. 4.9 reliability :P
  22. Help With Code
  23. confused
  24. 4.9 Ltr Timing Belt?
  25. Drive ADL switch?
  26. spark plug question
  27. code ro15
  28. 92 Fleetwood 4.9 hesitation/code help
  29. 4.5 no start, no life. sorta familiar
  30. Yea another code ??
  31. 4.1 Operating Temperatures
  32. coolant leak
  33. A few questions regarding the 4.9
  34. code questions please...
  35. Throttle body bolt stripped out of intake manifold
  36. steering wheel will lock up and car cut off
  37. Help with 89 Sedan deVille codes...
  38. how good are the bottom ends on the 4.9?
  39. E98 code - help!!??
  40. 4.9L northstar
  41. Need help ... engine kicks, accelerates/revs itself
  42. '89 DeVille a/c not working
  43. HT4100 Stalling
  44. 4.9 oil consumption
  45. ht 4100 change over to 350 chevy
  46. Will 4.9 heads fit on a 4.1 block?
  47. Thinking about getting a new coil
  48. 87 Cadillac Seville ,4.1 with blown head gasket
  49. Hi. I need lots of help concerning the 4.9L. Thanks.
  50. timing a 4.5
  51. pulley bearing? serpentine belt not moving
  52. Hub on crankshaft
  53. Tackling Motor mount Replacement-92 Seville(4.9)
  54. 1. Diag Codes 2. Engine Stall
  55. squeek squeek .my speedo cable i think
  56. coolant in oil in my new motor
  57. coolant in oil
  58. Reconnecting Spark Plug Wires - 4.9L
  59. rough poor idle on 91 Seville STS 4.9 ideas?
  60. bbob???
  61. Better MPG with 87 Octane
  62. Preliminary tune-up
  63. car from hell
  64. 1988 Coupe Deville 4.5 ECM problem
  65. Please Help!!!
  66. Well, it cranked but...
  67. 4.9 heads on a 4.5
  68. 1990 fleetwood 4.5 fuel filter and thermostat location????
  69. 4.1 V6 and 4.1 V8
  70. Does the bars leak that comes in the gray bottle do the same thing as the tablets?
  71. 93 SDV trans question
  72. can anyone shine some light on me
  73. What's wrong with my 4100?
  74. What are some tricks to make the 4100 last a long time?
  75. hurt caddy
  76. torque specs for belt tensioner pulley
  77. Need trouble codes for '83 HT-4100 Eldo
  78. 93 loud knocking within engine, while in park
  79. ht4100
  80. I bought my muffler
  81. Valve belts?
  82. gas leak
  83. Just got 3 codes, need some help!
  84. Needing help with a few things....
  85. How can I reset codes on '83 Eldo
  86. 4.9 motor buildup pics...
  87. oil light flickers at idle
  88. 83 coupe deville 4100???
  89. 1987 Fleetwood problems, maybe you guys know or been through it?
  90. how do i...
  91. Cracked Manifold
  92. Bad mpg and very throaty problem
  93. Weird ~ I like the 87 4100 growl
  94. How to check codes for A/C unit?
  95. 3 fan fault message in my 88 seville help?
  96. Fuel injector service
  97. starting
  98. flywheel to torque converter bolts
  99. Harmonic balancer 83 Fwd In-Line 4.1
  100. 4100 with 92K
  101. Newbie needs tranny and code help
  102. Deville still will not start...
  103. knocking solved
  104. Almost ready to pull the ht4100
  105. no fuel
  106. Safety Safety Safety !
  107. A Little Different No Start Problem
  108. 95 Deville Wont Start...Boo
  109. 4.9 being weird help!!!
  110. A/C help?????
  111. E67 error, any ideas?
  112. Water in door!
  113. Air Conditioning
  114. A/C Question for '92 STS
  115. ITS DONE....I finally have a smooth QUIET Cadillac
  116. ht4100 mounting to engine stand bolt size?
  117. '94 4.9 won't start!
  118. 1988 Alante will not run
  119. Swap Question 4100 (electronics)
  120. Let me tell you, water pump replacement is a pain in the @$$.
  121. 4T60E slipping
  122. Proper Engine Break In Reman 4.1
  123. Cadillac Coral?
  124. 4.1 Biarritz hesitation and stalling - long with lots of info!
  125. Marked surge at light throttle
  126. 4.1 Saddened
  127. 95 deville 4.9 miss at idle
  128. newbie
  129. Repeated O2 Sensor Problem 91 4.9l
  130. Bars Golden Seal Powder Stop Leak And Other Stuff (Deals?)
  131. Need second opinion 4.1 swap to northstar
  132. gonna replace the 4100 on 83 cadillac deville would it be possible to put a chevy 350
  133. Is my 4.9 on the way out?
  134. Installing Reman Ht 4.1 Oil And Coolant Suggestions
  135. What should I do if I put too much bars leak in?
  136. E-030 + Poor Mileage + Bouncing High Idle At Startup
  137. Transmission Looseing fluid , 1 qt per minute
  138. OMG..Maybe it is the water pump. THIS IS ANNOYING.
  139. can the 4.5 handle and 50-75 shot of nitrous
  140. tps................. help!
  141. Took off the belt and its not the waterpump making noise..need help
  142. EGR Malfunction -- Please Help
  143. Waterpump Replacement
  144. Muffler pictures
  145. Throttle position sensor question
  146. advancing the timing question
  147. Vibrating noise around throttle body
  148. 4.9 spark knock
  149. Muffler
  150. Changed coolant without pellets; what to do??
  151. injectors
  152. 94 sedan deville serpentine belt
  153. How hard to replace radiator out of 92 Deville?
  154. Crack in exhaust manifold
  155. Help Plz
  156. Re:Eldo 403FI swap w/MEGASQUIRT ?
  157. Turns out I have a bad water pump.
  158. replacing 4.1 with chevy 5.0
  159. 4.9 leaking oil?
  160. gaskets, paint, parts cleaner
  161. ht 4100 4.1 swap to a 4.9
  162. Questions About Eldorado Country site/info ---403FI swap
  163. 87 DeVille 36k ori. miles
  164. Codes are back!
  165. HP gains from no cat?
  166. 91 deville oxygen sensor(s) location
  167. 1988 deville fuel pump harness question
  168. 1990 SDV tranny- Please help
  169. 88 eldo Special fuel line tool?
  170. Car make caveman brain hurt
  171. Need help with front main bearing!
  172. Surging/cutting out? 1991 Deville 4.9
  173. Gasket to Oil line connector in Radiator.
  174. OH-NO!! The dreaded 4.1 "knocking".
  175. Bbob - Don't flush trans
  176. 94 deville , distrib will be turned the wrong way soon
  177. 93 Caddy seville 4.9
  178. Octane booster/ fuel saver
  179. Rough running (4.1) and ditrib question
  180. engine almost plucked
  181. Replacing Water Pump Too Often
  182. Like illumina said "or that pesky gm module"
  183. to chip or not to chip???
  184. Rebuilding my '88 THM440-T4 ie 4t60
  185. exhaust sound when it rains
  186. Slight Problem, need help
  187. Timming a '85 RWD 4.1...
  188. My mechanic recommended not using bars leak sealant?
  189. quiet, thoaty exhaust
  190. Do you have to set timing after change distributor and cap?
  191. procharger supercharger?
  192. Oil Adapter Hose Fittings
  193. Car won't start; noticed no spark at plug
  194. 90devilleguy, a question about your Muffler!
  195. smog pump replacement 4.5
  196. 83 Eldo Touring 4.1 Engine HELP
  197. 4.9L seville stall/restart problem
  198. Hot starting idling
  199. 4.9 family no hot start issue fix
  200. New to Forum seeking Info in 83 Eldo 4.1 swap and trans
  201. 1990 Cadillac Fleetwood 4.5 FWD
  202. Car cuts Off
  203. another issue (gas guzzler)
  204. part II to my car starting mystery
  205. Trouble codes
  206. car cut off and didn't start until the next day
  207. 1988 Cad SDV motor mounts
  208. 92 STS Engine Stall at low speed...HELP !
  209. Hey aguthmiller I have a few questions
  210. Water in the Oil ... How can it get there?
  211. Will new distributor cap and rotor make car run better?
  212. 94 Deville 4.9 Part Throttle Ping
  213. 92 4.9L Engine Reassembly - my heads are off and engine is in car.
  214. water in oil - Broke down on trip in Coffee Springs Alabama
  215. stuttering problem at idle
  216. 4.5 for 4.1 swap
  217. Got myself an 82 Coupe Deville, having some probs..
  218. 90 sedan deville right blinker acting up
  219. Will top end cleaning be good or bad for an engine with 130K on it??
  220. ALDL location
  221. Best swap for 4.1?
  222. What should I expect for my 0-60
  223. Fuel Pump circuit problem 84 Brougham
  224. 1984 Sedan DeVille over 200,000 miles?
  225. 90 Seville, Code E041
  226. **TH440 - 4.5 FWD - Trans **
  227. 89 4.5 deville overheated
  228. Flowmaster Muffler Installation Pics
  229. 4T60E Leak , ENOUGH IS ENOUGH !!
  230. 90 deville 4.5 125k doggin on freeway
  231. Aftermarket for 4.9?
  232. 4.1 Driveability Problem
  233. Code 44 on '85 Fleetwood Brougham
  234. What's Wrong with My Cadillac?
  235. 4.1/4.5 pros and cons?
  236. Oil leak from under car!
  237. Still having 4.9 idle down problems
  238. 4.9 Vs Northstar
  239. 4.9 emergency..broke something
  240. How hard is it to change the distributor cap and rotor on the 4.9??
  241. HT 4100 Diagnostic Codes
  242. 1989 Eldo help
  243. 4.1 engine timing!! Help...
  244. Engine Swap thoughts!
  245. '85 Fleetwood Brougham 4100
  246. AC won't blow!!!!
  247. Best Oil For HT 4100
  248. how do i enter set timing mode
  249. how to disable traction control on 92 deville?
  250. Muscle car pancake air filter
