- Transmission Wont Shift
- discontinued?
- Replaced Injectors.. Still no action in Cyls 3 and 4?
- Edelbrock engine....
- Rough Idle
- A/c
- Speedometer problems......
- 1985 Seville HELP NEEDED
- Weird A/C air condition problem
- Size of O-rings in fuel line
- Fuel Filter Location.
- 94 Deville Boils Over after Engine Off
- Dexcool in a 4.9L???
- 1992 4.9 goes to open loop at HWY speeds.
- Bad Engines?
- fuel pump location (84 4100)
- car wont start (84 4100)
- Overhauling and Modifying a 1982 HT4100
- 92 deville bad head gasket selling?
- 92 deville please help
- New 4.9 problem, horrific idle, backfiring
- Oil Cooler...
- 83 eldorado with new reman engine and tranny timing / ping probs
- 4.1 to 4.7
- Car giving me fits
- 89 Seville idles at 2200
- help with codes
- 4.5 cranks but no start
- 4.9L Stalling out
- 'Service Engine Soon' Light on my 4.9 DeVille - Any ideas?
- Pistons for a 4.5L and 4.9L the same???
- 4.9 distributor help
- umm...help please!
- 84 coupe deville codes
- engine swap
- 1990 deville starter replacement
- TPS Enhancer
- What kind of spark plugs for the HT4100?
- Vehicle Data List, Can you spot the problem?
- changing belt
- 92 Deville - OIL IN COOLANT
- 94' sedan deville woes Heeellllllp.
- What are the troubleshooting steps for injectors/plugs/wires?
- 4.9 Engine Oil Cooler Line replacement
- INTERMITTANT "Missing" and rough running/idle
- Ppplllleeeeaaassseee Help!!!
- ok so maybe its the alternator
- engine coolant supplement
- Ford SVO Injectors, Can i use them?
- '85 Deville Engine Temp Fan Light
- If I disconnect the battery.....
- 4.9L distributor questions
- How to go into different parts of OBD?
- gas smell?
- 92 Deville Surging during idle!
- symptoms of a bad cat?
- ebay purchase question?
- Flowmaster 80 Series-I LOVE IT!
- Over Heating
- high throttle on start. Code 26
- Fram Air Hog-Test
- 4.9L Roller Rockers?
- '86 Fleetwood 75 FWD
- TPS Adjustment for 85 4.1 (RWD)
- where is the thing???!!!!!!????
- radiator removal and installation
- 92 deville "set timing mode"????
- Ahh!!!
- What to do to make car stop running rich?
- 92 deville clicking after shut off???
- Spark Knock, Continued....
- Throttle Body and Air CLeaner Housing
- Engine Dies...
- Quick PCV question
- reman Ht 4100 is in looking for reman tranny advice, sources, install, fluid etc.
- bogging 4.9 in a Fiero
- Hi - 89 Deville 4.5 Liter V8 in 84 Pontiac Fiero
- Overheat Problem
- '89 DeVille, ISP motor bounces
- How to tell if water pump is going out?
- Overheating Badly
- MAT Sensor location...
- Serpentine belt for 4.9 ('91 Deville)?
- sputtering
- Radiator leak
- 15 Amp ERLS blowing
- 94 deville fuel delivery prob. HELP!
- wtf
- loud tapping noise in the left bank sounds like from top end
- swap engine
- eric
- replacing a broke pulley
- Jrb
- 87 eldorado 4.1L in an 84 fiero - SES light ON
- so many codes!
- 91 Deville 4.9 with no power- Need Help
- 0.07 volts for ground???
- 87 Eldorado 4.1L
- type of oil
- ISC motor idle speed
- how do i remove the throttle body?
- got my 4.1 reman in but it wont fire up
- High RPM on Motor Start - 4.9
- 4.5 V8 Water in Oil
- 88 4.5 V8 Water In Oil
- Aftermarket 4100 Parts?
- coolant leak from timing cover?
- Hammer -vs- Fussy Starter
- bad thermostats, hopefully?
- 4.1 TPS sensor
- Strange engine/ecu problem
- Best motor oil for 4.9?
- 4.5 Coolant Problems, Leaking Fluid - but from where?
- simple 4.9 questions
- 4.9L Firing order + Cylinder location HERE!
- 4.1 Rough Idle
- Best (Worst) Air Filters to Use
- 4.9L performance upgrades?
- 4.1 to 4.5 swap
- How much for New Head Gaskets?
- new mat and coolent sensors
- rough idle and sputtering
- 4.1 exhaust manifold
- 4.9 Head Gasket
- problem with "service engine soon"
- Advance timing on 4.9
- What MPG for 87 Eldorado, 4.1?
- E048 EGR fault code how to fix?
- 4.9 And The Gas Mileage Sucks!!!
- Any way to disable the ses light?
- 95 deville tranny question
- 92' dies then restarts by its self
- ECM pinouts
- Dead 89 deville engine
- Going to be a long weekend
- A few questions for the Caddy Experts 4.9L
- old radiator cap problematic?
- 4.9 ltr
- 4.9 reliability :P
- Help With Code
- confused
- 4.9 Ltr Timing Belt?
- Drive ADL switch?
- spark plug question
- code ro15
- 92 Fleetwood 4.9 hesitation/code help
- 4.5 no start, no life. sorta familiar
- Yea another code ??
- 4.1 Operating Temperatures
- coolant leak
- A few questions regarding the 4.9
- code questions please...
- Throttle body bolt stripped out of intake manifold
- steering wheel will lock up and car cut off
- Help with 89 Sedan deVille codes...
- how good are the bottom ends on the 4.9?
- E98 code - help!!??
- 4.9L northstar
- Need help ... engine kicks, accelerates/revs itself
- '89 DeVille a/c not working
- HT4100 Stalling
- 4.9 oil consumption
- ht 4100 change over to 350 chevy
- Will 4.9 heads fit on a 4.1 block?
- Thinking about getting a new coil
- 87 Cadillac Seville ,4.1 with blown head gasket
- Hi. I need lots of help concerning the 4.9L. Thanks.
- timing a 4.5
- pulley bearing? serpentine belt not moving
- Hub on crankshaft
- Tackling Motor mount Replacement-92 Seville(4.9)
- 1. Diag Codes 2. Engine Stall
- squeek squeek .my speedo cable i think
- coolant in oil in my new motor
- coolant in oil
- Reconnecting Spark Plug Wires - 4.9L
- rough poor idle on 91 Seville STS 4.9 ideas?
- bbob???
- Better MPG with 87 Octane
- Preliminary tune-up
- car from hell
- 1988 Coupe Deville 4.5 ECM problem
- Please Help!!!
- Well, it cranked but...
- 4.9 heads on a 4.5
- 1990 fleetwood 4.5 fuel filter and thermostat location????
- 4.1 V6 and 4.1 V8
- Does the bars leak that comes in the gray bottle do the same thing as the tablets?
- 93 SDV trans question
- can anyone shine some light on me
- What's wrong with my 4100?
- What are some tricks to make the 4100 last a long time?
- hurt caddy
- torque specs for belt tensioner pulley
- Need trouble codes for '83 HT-4100 Eldo
- 93 loud knocking within engine, while in park
- ht4100
- I bought my muffler
- Valve belts?
- gas leak
- Just got 3 codes, need some help!
- Needing help with a few things....
- How can I reset codes on '83 Eldo
- 4.9 motor buildup pics...
- oil light flickers at idle
- 83 coupe deville 4100???
- 1987 Fleetwood problems, maybe you guys know or been through it?
- how do i...
- Cracked Manifold
- Bad mpg and very throaty problem
- Weird ~ I like the 87 4100 growl
- How to check codes for A/C unit?
- 3 fan fault message in my 88 seville help?
- Fuel injector service
- starting
- flywheel to torque converter bolts
- Harmonic balancer 83 Fwd In-Line 4.1
- 4100 with 92K
- Newbie needs tranny and code help
- Deville still will not start...
- knocking solved
- Almost ready to pull the ht4100
- no fuel
- Safety Safety Safety !
- A Little Different No Start Problem
- 95 Deville Wont Start...Boo
- 4.9 being weird help!!!
- A/C help?????
- E67 error, any ideas?
- Water in door!
- Air Conditioning
- A/C Question for '92 STS
- ITS DONE....I finally have a smooth QUIET Cadillac
- ht4100 mounting to engine stand bolt size?
- '94 4.9 won't start!
- 1988 Alante will not run
- Swap Question 4100 (electronics)
- Let me tell you, water pump replacement is a pain in the @$$.
- 4T60E slipping
- Proper Engine Break In Reman 4.1
- Cadillac Coral?
- 4.1 Biarritz hesitation and stalling - long with lots of info!
- Marked surge at light throttle
- 4.1 Saddened
- 95 deville 4.9 miss at idle
- newbie
- Repeated O2 Sensor Problem 91 4.9l
- Bars Golden Seal Powder Stop Leak And Other Stuff (Deals?)
- Need second opinion 4.1 swap to northstar
- gonna replace the 4100 on 83 cadillac deville would it be possible to put a chevy 350
