- here is a good one
- rocker arm pivot support
- new engine
- valve lifter?
- please dont be head gasket!!
- Starter Removal
- module needs ground?
- 4.1 vs 4.9
- well damn
- 4.9 Misfire
- P012 bad hall sensor or pick up coil?
- Rebuilt Ht4100 With Less Power
- Coolant drain locations for a 4.9 (93 SDV)
- Metal hose running into side of cat, what is it?
- Pulled plugs and compression test *pics*
- rip of cat conv and egr??
- 4100 coolant capacity
- 4.5L A.I.R. Error Code
- Increasing Horsepower in 1992 Deville
- 4100 Help!!!
- Just craps out when I give it gas
- He said my cams were out of time....
- 4.9 bearing thump
- Final Choice: Dynomax SuperTurbos VS. Summit Turbos
- Knocking when I give gas to the engine Any one know?!!!
- 1991 Cadillac Deville Misfiring
- 4.1 engine weight and application ?
- Timing advance and still run on MidGrade??
- 1990 Eldorado water pump removal help
- junkyard ht4100
- 1989 4.5L no start when cold. At witts end
- Engine runs poorly
- 4.5 Engine Woes
- Do it right once ....Never see it again
- 84Eldo 4.1 won't start
- 4.9 Died Again
- 4.9L Volcano!!!!
- Now I'm getting code 38! What gives?
- '84 4.1 running VERY rich, PLEASE HELP!!!!
- E30 on Fleetwood 1990
- Need Some Help
- What's this coming or going out of my cat. converter?
- Draining ALL the coolant!!
- What's the name of the device (?pump?) under on my 86 deville
- car running rich messing up oxygen sensor!
- no oil pressure
- 90 4.5 Runs Great till it warms up then brakes up.
- 4100 tuneing
- Engine has a hard time running
- i had it out with the cooling system today
- temperature erratic
- 95 4.9L #7 Cylinder dead, Injector?
- 4.9 Cylinder head removal questions
- Coolant change.Time or mileage dependant?
- Anti-Freeze Coming out of Heater?(fogging up windows)
- i changed everything almost ugghh
- 4.9L build-up
- stuck valve?
- I Need a bolt can you help me?
- update on my '82
- E39 Vcc
- WTF is going on!!!(engine runnin crazy!)
- 4.1 Low compression
- OBD code
- popping from carb..
- 1984 Having Coooold Start Problems.
- won't start when hot
- 4100 Heads For Sale
- [B][U]4.9 L Performance, 10" Round Air Cleaner[/B][/U]
- Head Gaskets or Complete Valve Job
- 4100 head bolts
- Now this is really weird to me!
- 84' seville timing
- 4.9 no longer starts
- ht4100 loosing power and e codes
- 4.1 running rich
- Car surges when accelerating
- 4.9 HEI ignition
- 93 eldorado vs. 92 coupe deville
- 4.5 Pinging
- Air Mix Door problem code F40
- Caddi still not starting
- 95 Deville 4.9, Low oil pressure warning
- im so cold
- Fuel lines
- '93 DeVille Gas Mileage Questions
- Question for Kcnewell
- my '85 FWB died on the interstate...fuel pump?
- throttle body cleaning????
- another sickening creation of mine!
- Coolant supplement
- backfiring in park
- 4.5 oil pan-bolts gone pan stays on
- Crazy overheating problem
- Weird Problem
- Need to find honest and expert mechanic in Saint Louis Help
- 84 Eldorado engine overheating problem
- Resurection of a '94 4.9--Advice please!
- Jr Shift kit 1-2 rpm shift? but my rebuilt transmission seems great :)
- 4.9 low oil pressure warning after head gaskets
- Backfiring from the start
- I really need help on this.... engine overall performs better, gas millage bad...
- 4.9l Engine Knocks when Started
- MYSTERY 94'deville water pump
- Rattling Rattling Rattling !!
- 89 Fleetwood no problems with overheating then 3 days ago leaking antifreeze......
- 90-92 350 TBI into 80's Fleetwood Brougham ?
- Possible northstar upgrade?
- Ignition module failing?
- plug wire confusion
- please help 4100 problem
- advice
- 4.5 no heat
- 4.1 Runnin a Little Hot at Idle
- I hope it's not too late!
- 4.1 Cad. Fleetwood Brougham [Tranny Question]
- Just installed new M.A.P. sensor now car doesn't even start!
- Help With 4100
- Help Please Va (engine Problem)
- ATF Generic or Name brand???
- 1985 deville, coolant in my oil, help
- help me bbobynski 4.5 lack of power
- '92 4.9 torque converter problem
- Car Stall when u hit brake at the stop light sometime
- Oil Leaking
- smog problems with 84 el dorado timing marks
- Help
- Quick question: Cradle to cradle / Rear engine/trans mount bolts
- Rare Cadillac Options? NM8
- 4.5 Fuel Filter replacement
- Swap 4.1 out 368 in. Can it be done?
- fuel filter location
- 93 deville water pump
- main bearing seel
- 4.9 off idle knocking?
- How many mile u got out of your 4.1 engine
- hard time starting car
- Needed help on 4.1 engine system
- 4.9 Idle Learn - Is this honestly it?
- 4.5 bad gas mileage and lack of power
- Flush at 20k ?Break in proceedure?
- 4.9 rpm bounce & bad mpg
- 91 4.9 hesitation EGR?
- power to fuel injector
- HT4100, no power uphill
- fuel regulator
- Inner wheel tire is spliting
- HT4100 Damper Bolt
- My car runs the same with or without the egr hooked up
- Superchip VS Timing advance
- mph limiter
- Highway millage.... bad....
- 88 Eldorado - rough idle, intermittent miss
- 4.1vs4.9
- Tranny Blew out
- Transmission wiring diag.
- Car not starting, please help
- So what do you like about your 4.9?
- 4.9 EGR system....
- Th 350
- problems removing oil pan - Please Help!
- 4.1 to 307 swap question
- Exhaust question once again
- BBob and anyone else, whats the say on synthetic?
- HEI In-cap Coil - What our the differences?
- tranny warmup?
- These 4.9s have some power!
- water pump, water pump, water pump,
- 1990 DeVille has" the shakes" and revs on its own
- 4.9 pinging not under a load
- Barometric Pressure Sensor location
- Exhaust leak in engine compartment?
- 5W-30 Vs 10W30 for the cold winter?
- trans delays shift
- Rebuilt motor for an 85
- 87 Eldo w 35,000 mi, Change tran fluid?
- Fuel Injector Impedance - High/Low
- How to make a wooden Engine Support Fixture J-28467
- 4.1 Coolant Leak from block-PLEASE HELP!
- 84 coupe deville fan shroud
- Mileage and Power loss, again.
- 4.9 valve cover gasket
- C-v joint
- 82' couple 4100 - accelerating by itslef - HELP
- Do I have to change coolant?
- 1990 4.5L Eldroado Engine running rough
- 4.9 speed limiter...
- Is this the right stuff, going to attempt this weekend
- TPS setting
- Tune up on a 89 Deville w/ 4.5
- Quick Question
- 92 eldorado E0085 dtc help pls
- Engine Rattle
- 4.1 chrome?!
- WHat Buttons Do I hit to CHeck the Error COdes On My 93 4.9?
- 4.9 off idle stumble
- HELP! Would a bad EGR valve cause my car to run rough on the highway?
- White Smoke
- Radiator Leak
- 4.5 Vs 4.9... Compairable?
- ROUGH idle , strange code .
- 85 Fleetwood FWD Engine Trouble
- WTB: ASAP 4.9L Front Exhaust Manifold
- 91 Deville 4.9 rough idle
- My 86 SedanDeville is running rough above 55mph
- Has anyone converted to the electrocruise?
- '86 DeVille HT4100 knock - please help :-(
- Engine noise while in park?
- 4.9 with poor gas mileage. just changed o2
- Low Oil Pressure
- Changing oil pan gasket
- Looking for a couple of VSS wires - '91 Deville
- the return of E48/E49
- 84' seville is a mess!
- EGR Vavle
- engine swap
- 92deville, idle(rough) Injector service??
- CAM sensor
- supercharging the 4.9
- Please help me with my 4.1..or give me a mechanic who can
- How to remove/replace rattling CAT
- pellets and 4.5 engine
- ohm reading for injectors on 4.5
- ? acceptable ohm resistance for injectors
- Intermittent Stalling
- 4.5 EGR vs. 4.9 EGR
- 4.5 engine
- Pushrod?
- Got new codes today.
- 90 Deville Dies while driving
- 84 4.1 Swap To 305/350 ?
- new to the forum, need a little help (90 4.5l pfi)
- Air Pump Seized (4.1 engine)
- OBD I codes for 4.x Engines
- junked 4.1 installed chevy 5.0 runs great
- I replaced my tps and isc but it stall every now an then
- Engine running rough
- 85 cadillac seville
- '93 4.9L Spark Plugs and Wires
- TCC location, please Help!!
- White smoke still coming from exhaust?
- Starter Disabled "Anti-Theft"
- need source for 99 cadillac service manuals
- HT4100 coolant issue.
- 92 (4.9L) stalling
- Cars starting to run a little better!
- Oil Overfill Cause Engine Damage?
- 4T60E Trans Sport Mode???
- can't advance computer beyond PCM?
- Turbocharge the 4.9L?
