View Full Version : 500, 472, 425, 368
Pages : [1] 2 3 4 5 6 7 8
  1. Cadillac performance parts
  2. Cadillac 500 picture
  3. Caddy 472 and 500 Mods
  4. Jeff Schwartz' Caddy Modifications
  5. which headers?
  6. Sanden A/C compressor?
  7. Gas Engine Tune Up Specs
  8. Not familiar with the Caddy Big Blocks?
  9. Cad motor into non Cad car?
  10. Engine Cradle
  11. Show Us Your... Cad
  12. Hot Rod Magizine's Cad build up
  13. 78 Caddy 425 info please
  14. New aluminum heads for Cadillac 472/500’s !!!
  15. "Big Inch Cadillac" book
  16. Headers
  17. 425 heads on 472
  18. Torque
  19. '75 caddy 500
  20. Edelbrock Intake
  21. New BDS Blower!!
  22. tranny adapter
  23. 390 go fast stuff?
  24. 472/500 pictures
  25. ´67 429cid engine
  26. "Torque Pig" and "Cadoo" magazine articles
  27. 76 Caddy Calais
  28. 1976 Cadillac Calais maintenance history
  29. Help!?!?!?!?!?!?!?!
  30. Eldo Pan
  31. coolant leak
  32. Anyone ever build a Caddy Big Block?
  33. new guy on this board
  34. 472 part number question
  35. Transmission problems
  36. 1969 Cadillac-Fuel pump
  37. Will a 500 engine fit a 77 Coupe Deville?
  38. Fuel Filter
  39. Best place to find a rebuild kit?
  40. What would you do?
  41. Spec -o- fuel pump
  42. Engine ideas
  43. Road Racing 82 Fleetwood
  44. 70 500cid on 87 octane?
  45. Took the 500 to the machine shop today
  46. headers
  47. what engine is in the 81 coupe deville
  48. oil pressure sending unit
  49. Headers on a 425
  50. 500 in a '77 Eldorado?
  51. 425 & 500 Exhaust question
  52. Power per dollar
  53. Pulley for 74 Elodrado
  54. Acdelco Filter Change
  55. QJet Secondaries
  56. 84 coupe deville 472-500 swap ??
  57. 425s PCV system, smoke comes out the filter hole
  58. Roller Rockers.....Big Cad?
  59. Pre 1982 section (because they haven't made it yet)
  60. Swap Time!
  61. V8-6-4 Engine Code 44
  62. Soot and water in exhaust
  63. Need help on 76 Eldo 500 c.i. fuelie
  64. V8-6-4 Hesitation problem
  65. 8-6-4 Motor
  66. wow
  67. Fuel injected or carbureted 500?
  68. Carb spacer
  69. Caddy 500 questions
  70. Valve covers/ PCV
  71. Anyone put a 472/500 in a GM G body?
  72. swaping in a 350?
  73. 500 Caddy motor in 81 fleetwood?
  74. New Air Cleaner on Hot-Rod 500CID Brougham
  75. How to tell if my '81 V864 system is disabled?
  76. New Member
  77. Help
  78. Transmission downshift switch
  79. '81 V864 trans switch OK - any other ideas why no 4&6cyl modes?
  80. Oil Pressure Numbers
  81. Lack of fuel
  82. Normal Oil Pressure
  83. 425 CI build options and opinions
  84. TBI on a 472?
  85. layout of the forum.....
  86. Color Code / Engine Color
  87. Help Me Plan a Stroked Sleeper
  88. Stamped rocker shaft systems
  89. electrical problems. HELP!!!
  90. 1979 deville
  91. For the early V8 guys.
  92. question about 500 and tranny
  93. Day 1
  94. Info For 472 Mods?
  95. THM 400 transmission tuning questions.
  96. Junk Yard War
  97. Will this rearend work?
  98. 368 Dipstick Tube Replacement
  99. Compression test
  100. Replacement transmission progress
  101. hello every one- Deville questions
  102. 500 mileage?
  103. Ignition Upgrade?
  104. sticker says 501 is it a 500 cid
  105. Whats the firing order for a 500 and a 472
  106. ! ! Seat Belt Starter Killer! !
  107. Dual Exhaust Conversion
  108. What are the 472 or 500 BB crank centerline & deck height measurements?
  109. Name this engine part ?
  110. 472 or 500 Superchargers?
  111. My Update & Popular Engine Dimensions Links
  112. getting a face lift
  113. 390 Fuel Pump
  114. Air Suspension PSI & more
  115. Catalytic converter/ engine mods
  116. 1971 Coupe DeVille Needs an engine
  117. 368 Rocker Arms
  118. Mixed or non Mixed Exhaust??
  119. VIN Lookup
  120. 368 4bbl fuel delivery options???
  121. 472/500 in a tri five Chevy
  122. rear sump oil pans?
  123. 472 timing set
  124. Should I buy this 472?
  125. Ford FE Rockers
  126. Buying the 472
  127. 1977 Deville, broken or just slow?
  128. 425 into Chevy Van
  129. synthetic oil in a 1978 425 coupe deville?
  130. A/c Not Working Right 78 Deville
  131. 1976 coupe/500cid want to make her scream. jwalker?
  132. Help with Smog stuff on 472
  133. 1967 429 for 500 swap
  134. 500 cid in a 1961 series 62 cadillac deville?
  135. Need For Better Cooling 425 Cad V-8
  136. Heads/manifold Question?
  137. Just bought my first Caddy - 1972 Eldorado
  138. Carb replacement
  139. Eldorado Emptying Water unto Floor
  140. new plugs and wires for my 72 Eldorado...need advice.
  141. 472 cooling problems
  142. 68 DeVille...
  143. Changing Radiator
  144. Best performance for dollar
  145. Oil change on my 72 500 - 10W30?
  146. Shop manual. Cooling system update.
  147. 500 crank fit 472?
  148. Bulldog info please.
  149. Name this part /or/ should I put it back
  150. Tow dolly for "75 Eldo Conv?
  151. Cad 500 swap motor mounts ?
  152. 4100/8-6-4 Swap- Help!
  153. Exhaust-ed optoins.
  154. Help! Cylinder head question
  155. 472/425 swap??
  156. 472 in pieces...
  157. emission help
  158. Single vs. Dual plane intake using MPFI
  159. '81 V864 "floods" itself after sitting awhile??
  160. What now?
  161. Fuel monitor green light not longer working??
  162. 1972 472 tune-up?
  163. need help with 472 carb removal
  164. '69 deville 472 'Gen' light stays on
  165. Just Won't Start
  166. 1972 472 quadrajet 4mv carb issues
  167. Fan Clutch Question
  168. braking down the brake problem
  169. Carb size question
  170. '69 472 lead additive?
  171. 1969 Cadillac Eldorado
  172. 1970 Eldorado 14,400ORIG miles (TimeCapsule)
  173. New Member 1972 Cadillac Eldorado Convertible
  174. vacuum leak?
  175. 1979 deville 425
  176. V 8-6-4 problems!
  177. 472 compression test
  178. Crane Cams XRI
  179. Eldorado Oil Seal
  180. A/C Problem '66 Cad
  181. Free '74 472 engine parts.
  182. serpentine setup for 500?
  183. Traveling Pedal
  184. A/c Programmer Rebuild Help
  185. 72 deville knock + pulsating lights
  186. 1968 472 HEI SWAP, Big time Problems!
  187. CDV transmission problems
  188. Vibration
  189. Problem locating an ISC
  190. driving water pump with no smog pump?
  191. engine stalls with a big rattle
  192. carb compatability
  193. New AC compressor
  194. Master Cylinder
  195. Need technical help with 1978 Eldorado front wheel drive transmission
  196. Headers
  197. e.f.i.
  198. Resto-Mod 1970 Fleetwood Anhialator
  199. exhaust size ?
  200. Newbie, with a few questions
  201. 429 needs help
  202. 472/500 Engine in a 1959/60 Cadillac??
  203. need help with heater core removal!
  204. Torqueriffic..
  205. Electronic Ignition for '68 472
  206. fuel delievery problem
  207. 58 cadillac misfire
  208. Electric Choke Hot Wire
  209. 425 knocking noise
  210. 1977 v8 425 how to increase horsepower
  211. Holly street avenger
  212. 472 starting/ smoking problem
  213. where to find a decent price on a rebuild kit
  214. how much horsepower does the 425 put out
  215. 79 DeVille Cpe 425 Engine tuning
  216. 472 Onion
  217. Question about the 425....
  218. How rare was the 501?
  219. Oil Light!!!
  220. Backfire
  221. Brake Booster?
  222. Got a new '81 Sedan DeVille today!
  223. Edelbrock / emmissions
  224. whats a good manifold for a 425
  225. Need some help soon. Project at a standstill.
  226. valve seals
  227. '78 425 HEI on a '65 427?????
  228. Smoke coming out of spark plug?????
  229. Point man needed
  230. charging system wiring questions
  231. 76 500cid Fuel Injection/starting problems
  232. "Yeah, but it's a Caddy!"-What movie is this from?
  233. awesome 71 eldorado
  234. 390 waterpump rebuild/replace
  235. '71 Deville 472 cam and header help
  236. billet 472 - 500 caddy parts ? wow
  237. TH325-4L with 368(V468)
  238. anyone in the dc area
  239. Newbie Questions about a 75 Cadillac 500ci
  240. '81 DeVille Diagnostic test?
  241. '77 Deville Parts Or Whole Car For Sale
  242. Cat converters?
  243. Need your help
  244. New Here, Need Info
  245. miles per gallon
  246. 472 Color combo...
  247. carburetor fuel filter thread damaged
  248. Another fuel delivery problem
  249. 79 Deville - Air intake hose
  250. 76 Deville Wont Run
