View Full Version : 500, 472, 425, 368
Pages : 1 2 3 4 5 6 [7] 8
  1. max power with 2500
  2. 1968 Deville Oil Light
  3. How do I identify cadillac motor
  4. '72 Eldorado engine "dieseling"
  5. Looking for the firing order of 65 472
  6. Carb Recommendation
  7. Float level
  8. Power?
  9. Troubles!!!
  10. What is normal coolant temp for caddy 500?
  11. Cad data spec sites?
  12. stock rebuild options
  13. Can these wires possibly be wired correctly?
  14. 68 Deville Front window fogging
  15. Noisy Gear drive for a 472?
  16. Tread in 500 crankshaft?
  17. Hot rodding
  18. Camshaft...
  19. how to fix error code 14???
  20. Gear Shift Knob
  21. 79 Cad Engine Stalling. Please Help.
  22. Odd idling...
  23. Hard Start w/ Warm Engine only
  24. Carb flange size on 472
  25. Anyone know a lot about electrical systems?
  26. Change engine...
  27. -70 472 heads on 500 -74 engine?
  28. 500 V864 - is this even theoretically possible?
  29. 500 ci. carb question
  30. 425 vs. 500..... hot-rodding.... need some opinions...
  31. 472 Emblems?
  32. 500 cid year ID?
  33. Headers for 368
  34. 472 Headers?
  35. Are there any easy mods to getting more power from the 368 V864?
  36. thermostat replacement
  37. '70 Coupe - 472 Oil change questions
  38. Rearend question
  39. Replacing air cleaner assembly, K&N?? HELP
  40. '76 Eldorado compression test
  41. Remove oilpan with the engine left in car?
  42. Performance mod recomendations
  43. Need Engine for my 69 Eldorado
  44. How much damage...
  45. mating a manual tranny to the 500?
  46. 500ci block overheating...
  47. 1973 or 1974 cadillac coupe de ville! Read this :D :D :D
  48. Oil pressure in TH425 transmission?
  49. Torque, 700r4, tbi, specs and more noob questions
  50. Which engine?
  51. 429 points to electronic ignition?
  52. RESTORE - ENGINE RESTORER on Cadillac V8?
  53. Parts interchangeabillity and performance
  54. Can a 500cid from a 70's eldorado fit
  55. Oil quantity/dipstick issue - '69 472
  56. 1967 425ci OIL CAPACITY NEEDED
  57. 76 deville 500 upgrades
  58. How much power does the 500 makes?
  59. Header conversion question
  60. Ignition Switchover
  61. Need timing help!!!!
  62. QuadraJet Carb Leaking Plug Location - Fuel Delivery Problem
  63. Spedo gear part needed
  64. 390 tune up specs
  65. 76 Deville Wont Run
  66. 79 Deville - Air intake hose
  67. Another fuel delivery problem
  68. carburetor fuel filter thread damaged
  69. 472 Color combo...
  70. miles per gallon
  71. New Here, Need Info
  72. Need your help
  73. Cat converters?
  74. '77 Deville Parts Or Whole Car For Sale
  75. '81 DeVille Diagnostic test?
  76. Newbie Questions about a 75 Cadillac 500ci
  77. anyone in the dc area
  78. TH325-4L with 368(V468)
  79. billet 472 - 500 caddy parts ? wow
  80. '71 Deville 472 cam and header help
  81. 390 waterpump rebuild/replace
  82. awesome 71 eldorado
  83. "Yeah, but it's a Caddy!"-What movie is this from?
  84. 76 500cid Fuel Injection/starting problems
  85. charging system wiring questions
  86. Point man needed
  87. Smoke coming out of spark plug?????
  88. '78 425 HEI on a '65 427?????
  89. valve seals
  90. Need some help soon. Project at a standstill.
  91. whats a good manifold for a 425
  92. Edelbrock / emmissions
  93. Got a new '81 Sedan DeVille today!
  94. Brake Booster?
  95. Backfire
  96. Oil Light!!!
  97. How rare was the 501?
  98. Question about the 425....
  99. 472 Onion
  100. 79 DeVille Cpe 425 Engine tuning
  101. how much horsepower does the 425 put out
  102. where to find a decent price on a rebuild kit
  103. 472 starting/ smoking problem
  104. Holly street avenger
  105. 1977 v8 425 how to increase horsepower
  106. 425 knocking noise
  107. Electric Choke Hot Wire
  108. 58 cadillac misfire
  109. fuel delievery problem
  110. Electronic Ignition for '68 472
  111. Torqueriffic..
  112. need help with heater core removal!
  113. 472/500 Engine in a 1959/60 Cadillac??
  114. 429 needs help
  115. Newbie, with a few questions
  116. exhaust size ?
  117. Resto-Mod 1970 Fleetwood Anhialator
  118. e.f.i.
  119. Headers
  120. Need technical help with 1978 Eldorado front wheel drive transmission
  121. Master Cylinder
  122. New AC compressor
  123. carb compatability
  124. engine stalls with a big rattle
  125. driving water pump with no smog pump?
  126. Problem locating an ISC
  127. Vibration
  128. CDV transmission problems
  129. 1968 472 HEI SWAP, Big time Problems!
  130. 72 deville knock + pulsating lights
  131. A/c Programmer Rebuild Help
  132. Traveling Pedal
  133. serpentine setup for 500?
  134. Free '74 472 engine parts.
  135. A/C Problem '66 Cad
  136. Eldorado Oil Seal
  137. Crane Cams XRI
  138. 472 compression test
  139. V 8-6-4 problems!
  140. 1979 deville 425
  141. vacuum leak?
  142. New Member 1972 Cadillac Eldorado Convertible
  143. 1970 Eldorado 14,400ORIG miles (TimeCapsule)
  144. 1969 Cadillac Eldorado
  145. '69 472 lead additive?
  146. Carb size question
  147. braking down the brake problem
  148. Fan Clutch Question
  149. 1972 472 quadrajet 4mv carb issues
  150. Just Won't Start
  151. '69 deville 472 'Gen' light stays on
  152. need help with 472 carb removal
  153. 1972 472 tune-up?
  154. Fuel monitor green light not longer working??
  155. What now?
  156. '81 V864 "floods" itself after sitting awhile??
  157. Single vs. Dual plane intake using MPFI
  158. emission help
  159. 472 in pieces...
  160. 472/425 swap??
  161. Help! Cylinder head question
  162. Exhaust-ed optoins.
  163. 4100/8-6-4 Swap- Help!
  164. Cad 500 swap motor mounts ?
  165. Tow dolly for "75 Eldo Conv?
  166. Name this part /or/ should I put it back
  167. Bulldog info please.
  168. 500 crank fit 472?
  169. Shop manual. Cooling system update.
  170. Oil change on my 72 500 - 10W30?
  171. Best performance for dollar
  172. Changing Radiator
  173. 68 DeVille...
  174. 472 cooling problems
  175. new plugs and wires for my 72 Eldorado...need advice.
  176. Eldorado Emptying Water unto Floor
  177. Carb replacement
  178. Just bought my first Caddy - 1972 Eldorado
  179. Heads/manifold Question?
  180. Need For Better Cooling 425 Cad V-8
  181. 500 cid in a 1961 series 62 cadillac deville?
  182. 1967 429 for 500 swap
  183. Help with Smog stuff on 472
  184. 1976 coupe/500cid want to make her scream. jwalker?
  185. A/c Not Working Right 78 Deville
  186. synthetic oil in a 1978 425 coupe deville?
  187. 425 into Chevy Van
  188. 1977 Deville, broken or just slow?
  189. Buying the 472
  190. Ford FE Rockers
  191. Should I buy this 472?
  192. 472 timing set
  193. rear sump oil pans?
  194. 472/500 in a tri five Chevy
  195. 368 4bbl fuel delivery options???
  196. VIN Lookup
  197. Mixed or non Mixed Exhaust??
  198. 368 Rocker Arms
  199. 1971 Coupe DeVille Needs an engine
  200. Catalytic converter/ engine mods
  201. Air Suspension PSI & more
  202. 390 Fuel Pump
  203. getting a face lift
  204. My Update & Popular Engine Dimensions Links
  205. 472 or 500 Superchargers?
  206. Name this engine part ?
  207. What are the 472 or 500 BB crank centerline & deck height measurements?
  208. Dual Exhaust Conversion
  209. ! ! Seat Belt Starter Killer! !
  210. Whats the firing order for a 500 and a 472
  211. sticker says 501 is it a 500 cid
  212. Ignition Upgrade?
  213. 500 mileage?
  214. hello every one- Deville questions
  215. Replacement transmission progress
  216. Compression test
  217. 368 Dipstick Tube Replacement
  218. Will this rearend work?
  219. Junk Yard War
  220. THM 400 transmission tuning questions.
  221. Info For 472 Mods?
  222. Day 1
  223. question about 500 and tranny
  224. For the early V8 guys.
  225. 1979 deville
  226. electrical problems. HELP!!!
  227. Stamped rocker shaft systems
  228. Help Me Plan a Stroked Sleeper
  229. Color Code / Engine Color
  230. layout of the forum.....
  231. TBI on a 472?
  232. 425 CI build options and opinions
  233. Normal Oil Pressure
  234. Lack of fuel
  235. Oil Pressure Numbers
  236. '81 V864 trans switch OK - any other ideas why no 4&6cyl modes?
  237. Transmission downshift switch
  238. Help
  239. New Member
  240. How to tell if my '81 V864 system is disabled?
  241. New Air Cleaner on Hot-Rod 500CID Brougham
  242. 500 Caddy motor in 81 fleetwood?
  243. swaping in a 350?
  244. Anyone put a 472/500 in a GM G body?
  245. Valve covers/ PCV
  246. Caddy 500 questions
  247. Carb spacer
  248. Fuel injected or carbureted 500?
  249. wow
  250. 8-6-4 Motor
