View Full Version : 500, 472, 425, 368
Pages : 1 2 3 4 5 [6] 7 8
  1. Hydraulic Pump?
  2. Sitting 68 wont start
  3. electric water pump
  4. what is "ACROMAT" ?
  5. 500 vacuum ?
  6. Replacing fusible links - what amperage?
  7. Even more problems with the '81 DeVille - Idgit needs more help
  8. need power how do i do it???
  9. Rebuild Tha Throttle Body?
  10. 472 4 Core Radiator into '77
  11. jalopy caddy
  12. 472 Smog
  13. 500 in a 50 chevy truck?
  14. 472 Air Filter Decal
  15. just bought a 500!!!
  16. '81 DeVille Cat Gutting - Is it Possible?
  17. Caddys in other vehicles
  18. Carb rebuild
  19. two problems killing the newbie!
  20. stupidest question ever, involves 67 stang
  21. Trasmission HELP!!
  22. Ignition conversion
  23. I'm going crazy!
  24. Odd Problem With 425
  25. Oh so tempting...
  26. Coolant Temp. Sensor wire melting on 368
  27. quadrajet fuel mixture setting
  28. wood carburetor spacer?
  29. 472 manifold
  30. Hei INSTALLED!
  31. how hot
  32. 1968 / 472 factory advance setting
  33. Eldorado '68 Engine Mounts Replacement
  34. 429 to 472 swap question
  35. Are 472/500 really only 50lb heavier then a SBC?
  36. Need some answers :)
  37. Replacement Of A Cv Joint
  38. Question about 1961 390cid. journal diameters.
  39. Is the 429 a good replacement for the 472
  40. Exhaust headers for 425
  41. Wow... somone else has the big block Cad bug :)
  42. 76 cadillac puttering 500 c.i.
  43. Overheating 500 - please help!!
  44. 368 Fan Belt Blues
  45. spark plug fouling on 425
  46. 472 parts to a 425
  47. 69 472 Wont Start.. Need firing order and location of #1 on Dist. Cap
  48. Aftermarket altenators for a 368
  49. Radiator cooling capacity for a 71 500
  50. electronic distributor on a 472 ?
  51. 94 amp alternator
  52. bbob mod displ 500cid What would it take?
  53. '77 425 into an '86 Olds Cutlass Supreme
  54. MPG with a well tuned 472 ?
  55. Leaded Or Unleaded Fuel In A 472 ? (1968)
  56. 472 vs 429
  57. What part?? (500cid engine)
  58. noisy exhaust system (muffler) = carbon deposit ?
  59. '71 500: Will a Flex fan cause me cooling problems?
  60. Sitting 1968 Eldorado Lacks Power
  61. Sitting 1968 Elorado Lacks Power
  62. what would you do?
  63. Reverse cooling on a '71 500: Questions
  64. Why the 4-6-8 hate?
  65. ´73 Eldorado - 5 & 8 cylinder doesnt work.
  66. Need a change In the Transmission
  67. 500 distributor question
  68. 425 timing question
  69. High compr. vs low compr. 472 engine
  70. Performance of a 1973 Deville
  71. Oil pressure sender weeping oil: why?
  72. Started out simple... now getting involved... help me out...
  73. '74 Sedan Deville 472 questions
  74. Predator carb...
  75. Benefits of installing a lower temp thermostat on a 500?
  76. Generator light won't go out
  77. 75 Eldo conv runs rough when getting going
  78. question about sitting '77
  79. '74 Coupe de Ville Burning Rubber
  80. smoke?
  81. difference between the Big Block..... blocks...
  82. Raising compression ratio on a 472 engine modifiying the zylinderhead
  83. What would be my better choice?
  84. Removing the A/C off 500ci
  85. Modify stock intake on a 472? How to do?
  86. Getting it together help!
  87. 368 chaos
  88. Hydraulic Valve Lifter change (Deville 1973)
  89. How many hp with performer intake an headers (Deville 73)
  90. 79 Eldorado engine needs replacing
  91. 76 Eldorado starting problem
  92. What kind of horsepower gain am I looking at?
  93. How much of a pain is it to change the starter on a '72 Eldo?
  94. 1972 eldorado 500 runs on 7 cilinders?
  95. Increasing 500ci power
  96. Sorry for OffTopic. 350thm tranny
  97. Can PCV (positive crankcase ventilation system) be removed from 472?
  98. How can I tunt the 472CID engine?
  99. 472 power worth the trouble
  100. In addition to my previos 'identification' question...
  101. What OTHER vehicles used the 368-500?
  102. 368 8-6-4 in Pontiac Parisienne. Identification help needed!
  103. Water inlet, please help!
  104. 500 CID Motor
  105. Where is all the LPG conversion info in North America?
  106. Modified A/C bracket for use with Edelbrock intake?
  107. '72 Eldorado Exhaust
  108. 390? whats the deal
  109. Installing '70 472 heads on later engines..?
  110. i need pictures of a 472 in your cadillac
  111. Carb problem
  112. 472 intake modification
  113. Neibors new ride .....472 ?
  114. timing problem
  115. I picked up the '70 CDV on Wednesday...
  116. Carburetor Set Up
  117. new member 425 info
  118. 1980/1 Caddy Seville Throttle Position Sensor
  119. Valves Won't Stop Rattling !!!!
  120. Cruise contoll removal...
  121. Any help killing the critical drive?
  122. Caddy Bragging Rights?
  123. No gas coming out injectors on '81 V864?
  124. BOP bell housing
  125. 472 + 500 performance parts found!
  126. How far can I go without removing the heads?
  127. Swap 368 w/ 500??
  128. Picked up my 472
  129. engine specialist help!
  130. A/C idel speed-up solenoid adjustment
  131. Where to get an LPG Conversion Kit or D.I.Y. info?
  132. coolant change before winter?
  133. Extreme timing problems, please help!
  134. '77-'79 upgardes list
  135. 1970 AND 1979 Interchange of engine/tranny?
  136. HEI upgrading
  137. Distributor question
  138. Need info for/on "MTS"
  139. starting your 425 101.....
  140. Need some help about my stalling car
  141. Need info for Chevy engine swap into '70 Coupe
  142. how about some info?
  143. Need Help
  144. Placeholder engine for '70 Couple DeVille?
  145. Suggestions on Dynomax/Flowmaster/Glasspacks to replace stock exhaust on the '70 CDV?
  146. stock cam specs?
  147. New Cad owner
  148. throtle linkage?
  149. Carburetor needed
  150. Rebuild '76 500 w/ '70 472
  151. 65 Sedan Deville--wore out or no?
  152. possible 425 lifter
  153. 472 Engine Swap
  154. cad company??
  155. '67 Deville Starting Problem
  156. lack of 425 parts
  157. explain the V-8-6-4 please!
  158. Oh Crap (Leakage)
  159. carb to fuel injection 500ci
  160. Something I heard about the a/c bolts
  161. Engine spec for 72 Fleetwood?
  162. Qudrajet: easy to rebuild?
  163. 368?
  164. 472 or 500 wanted
  165. Now i have really done it...
  166. Cam Replacement Procedure: 472/500
  167. '72 Eldorado Tranmission
  168. cheap power improvements to the 425...
  169. WHat the heck is this called and where do I get one (Heater part)
  170. plug gap??
  171. Where could i find a steering column
  172. Whats the value on this engine?
  173. nitrous on a 500???
  174. backfiring
  175. 500 powered
  176. diesleing?
  177. overheating!!!
  178. Injector size
  179. Intake manifold for the 425
  180. Shaky Idle
  181. Need 1968 Vacuum diagram
  182. Identifying which lifter is making noise
  183. '72 500 Cam Identification
  184. 500 and 472: Are the main bearings the same?
  185. Heater Core, 68' Fleetwood
  186. all bolt toruqe specs?
  187. Need Complete 500 Cadillac Engine
  188. 472 or 500 how can I tell?
  189. electric fan
  190. What is this thing??
  191. Power Steering
  192. sitting caddie
  193. HEI swap into 68' fleetwood
  194. stock 425/edelbrock performer intake
  195. New or rebuilt 472 parts
  196. 425ci vacuum routing diagram
  197. noise from my 500
  198. Fuel Level Gauge question
  199. Dual exhaust on a 368 w/ DFI
  200. 1st to 2nd Gear noise in a TH400
  201. 425ci oil sender unit
  202. dyno
  203. My 6.0 4bbl and it's new found 14mpg's. wahoo.
  204. Torque buildup
  205. Cam Advice
  206. WANTE - Cadillac 368 Parts
  207. stock 500 camshaft lift/duration?
  208. The new guy
  209. 472 heads on 500
  210. 76 Eldorado problems
  211. 1969-1970 Hearse (prolly 472)
  212. 472 head swap
  213. gm/cadillac?
  214. 69 472 CADDY CAM & REAR END QUESTION
  215. '72 Eldorado Fuel Filter-Engine won't Ignite
  216. 425 Timing help
  217. Carb Spacers??
  218. quadrajet plugs epoxy fix
  219. Definitively Diagnose a Leaking Rear Main
  220. HEI in right position?
  221. Related to "Okie towtruck driver"
  222. 500 in a 85 eldorado ?
  223. Derelict 67-68 Eldorado
  224. More questions about building up a 500....
  225. Valve Cover Breathers
  226. 500cid in 76 seville?
  227. need oil pan any help
  228. A/C vaccume diagram?
  229. What would you do if your dist. was stuck?
  230. Help-need '68 engine pics
  231. Question about connecting rods?
  232. Smoke coming from 368 motor?
  233. Blower motor problems?
  234. would this turbo work on a 500?
  235. Ignition Advice
  236. Please help... car wont start 68 472 sedan devile
  237. 472 Performance
  238. carb linkage adjustments
  239. 500ci questions
  240. how important is head work?
  241. Flash???
  242. manifold swap.
  243. fuel pump bolts didn't want to go to work!
  244. Sway Bars?
  245. good mods for under $1600?
  246. I got another car......might be another 500 project in the works.
  247. newbie question of the day!
  248. PAW, Summit, Jegs?
  249. AC crapped out in 68 Fleetwood
  250. Octane Recommendations
