- examine my ignition system
- Rebuilding a 1971 500
- 1972 Caddy 425 Powertrain
- MPG-Crate Engine
- 72 sedan deville update
- 1970 - 472
- 8/6/4 questions
- engine for sale phila area
- boring over displacement
- Bought a 81 coupe deville
- Newbie questions...
- 68 472 passenger-side exhaust leak
- Headers...
- 472/500 exhaust manifolds on a 425
- Second Battery?
- 10:1 500 on pump gas?
- Torque Monster Bit Me!
- taking head off
- hmmmmm......
- hmmmmm......
- new here and need help
- Help! My Truck runs like a Drag car!
- 52 caddy help
- 1976 500 head swap
- Q: where i can find carburetor #
- Info Needed For '79 Coupe DeVille!
- Car starts but wont cut off ahhh
- How to eliminate smog pump
- what holds the tranny on?
- Fuel system? HELP!
- Identify this cadillac engine
- Resetting mileage?
- 368 -5.0 swap advice
- Aftermarket BB Cad support?
- motor for sale Phila area??
- Cad into 82-91 Camaro swap info?????
- Is there a for sale section ?
- 472 1983 DeVille SWAP DONE - Pics/Site
- new carburetor for Eldorado 1973 500cid
- Looking for info on 311ci engine (used in 49-55 Caddies).
- rust in the intake manifold
- radiators
- 472 crank full of water
- What color paint??
- Need Help Quick! 368 4BBL Timing ????
- What were the 472 V8's making for power?
- Cool Cad 472/500 engine swaps
- 500 engine overheating
- '82 368/parts from 472
- 79 CDV 425ci - TPS
- Best Suspension
- Valve covers
- Does the '74 Eldorado w/500cid need premium?
- Carb Kickdown
- UPDATE, '76 eldorado project
- th 350 oil dipstick
- fuel pump outlets
- 81' 368..Need parts, any ideas?
- '77 425 motor question..
- 68 Flywheel Cover
- 1966 Deville Restoration
- Cad 472/500 intake on EBAY
- i bought a 472
- What are these holes??????
- Which temp is normal for a 500?
- HEI conversion, what benifits are there?
- 472 street rod
- Convert 472 to 500. What parts do I need?
- Light Malfunction 81 Seville 8-6-4
- Did I blow my engine?
- Timing 429
- Water Temp Light 472
- 1970 472 Exhaust Manifold
- Aaaaah, crap.
- 425 really that bad on gas?
- diagrams?
- intro
- Code 25 on 81Cadillac Seville 8-6-4 V-8
- I Give up !!!
- Which 472/500 engine to use? Need your opinion.
- Removing divider from 472/500 intake, power gain?
- HELP! Stuck in the desert and need a part! Call me!
- 472/500 Eldebrock intake vs stock
- At least it can roll!
- build a 70 472 or look for a 500?
- 500 Crate Engine...
- Fuel Deprived Engine?
- Firing order
- a few questions
- Spark plug gap
- 472 Radiator Q
- 472 Radiator Q
- Synthetic or bust...?
- Where can I install an oil pressure sensor?
- Which engine 65 Fleetwood Brougham
- Header gaskets...
- Engine temp light/buzzer
- Have oil recommendations changed?
- better MPG
- Where to purchase Q-Jet jets, metering rods, etc.
- 429 cyl, heads
- pollution control pump?
- car will not start
- Auto trans shifting questions
- 425 manifold vaccum question
- Electric choke...
- valve covers and headers
- hot wiring
- Broken Manifold
- Adding a second alternator?
- Anyone know where I can send my headers...
- Need 500cid for project car...
- Burnouts?
- Carb question....
- 1978 caddy 425
- Air cleaner sizes, differences
- Wanted: 500cid
- Fabricating gas tank mounting straps... Dimensions?
- 69 472 "dieseling" on shutdown
- 425 rocker retaining bolt problem
- Removing intake manifold
- mods for '78 Eldorado 425V8
- Custom exhaust setup/question about the hole burnt thorugh my floor (lol)
- Distributer/plug wires
- Cold weather starting using headers?????
- fuel gauge problem
- 368 oil pan on a 472
- Anybody heard of this guy
- Aftermarket Fuel Injection
- Distributor/breakdown syptoms?
- 68 wont start
- transmission fluid refill....
- My cadillac is total Crap
- storage / transmission leak
- 472 vacuum diagram
- 81 D'elegance sedan
- Transmissions (?)
- '68, 472 HEI Conversion?
- Newbie with Engine question
- 425 missing on one cylinder
- Decoding VIN plate
- Quick timing question.
- Carburetor Help - 1967 Deville
- my 425 is pretty dirty inside.....
- Souping up the 500
- Body work on a 77-79 caddy
- Cad 500 in a Jag
- 69 472 Q-Jet not getting enought fuel
- Electric fans
- ocasional puff of smoke
- Air cleaner?????
- 68 472 Timing Question
- Carb (?) newbie needs help
- What have i got, 429 or 472?
- number 1 cylinder is...
- looking for Custom air cleaner ideas
- 500 tranny matching
- New Owner
- exhaust help?
- Chrome Engine Bolt Kit
- New 500 owner
- is the 425 strong enough?
- Help: 429 Fuel Pump Pushrod
- Code 25 on 81 Eldorado V-8-6-4
- Code 25 on a 81 Eldorado V-8-6-4
- Caddy 500 Carb Questions
- 500 Timing Chain
- "GEN" Light,, Gasoline Meter not working
- Help!!! Fuel Question!!!
- oil capacity for the 425 engine
- Quick 500 Story (kinda!)
- My first Post
- Cadillac Exhaust
- Cadillac Grill
- New Member
- please identify this please for me...
- 472 for sale on eBAY
- looking for 500 heads
- Starter and Distributor Notes
- '76 Coupe de Ville..Engine clatter
- Trouble with 6.0 liter 1980 engine
- 1970 Deville Project
- Need Engine Oil Dipstick tube
- 472 build up question
- 65 429----Big Block or Small?????
- some questions
- air cleaner flex duct on 425
- Motor Mounts
- Needs some help in Arizona-69 Coupe with a 472
- Looking for a set of 500 open chamber heads
- Help!! 500 FWD Motor
- Need Help Setting Idle on a '76 500
- V8-6-4 findings
- 1979 gas mileage
- Stirring up a hornet's nest.
- Best price on header flanges for my 72' 472?
- Top End O'Haul
- 425 power gains?
- Finally back, same old problems
- 425 help
- 425 Stalls Uphill
- Marvel Mystery Oil
- new owner needs help
- Can a 1969 or 1972 Cadillac 472 block fit in a 1966 Cadillac Deville?
- Firing Order
- plug gap size
- opinion on R.V project using caddy drivetrain
- Time Of Services
- 4-barrel 368
- coolant? how? noob to old cars..
- 368 6.0Litre...
- 472 cylinder heads
- where can i purchase an engine temperature switch
- 500 running hot-sometimes
- 76 Eldo 500 Rebuild specs PLEASE
- My 472 needs a rebuild now, advice on upgrades?
- How to diagnose an overheating situation?
- Blowing Smoke
- I'm back
- 500ci makes 718HP in Car Craft magg (1400hp with blower)
- '76 Fuel Injected 500 CI Eldo for sale.
- '68 Rebuild Project, advice...?
- 425 Spark Plugs
- 4-6-8 368 Running to rich
- 425 cat remove?
- V8-6-4 stuff.....
- got a 1968 472 now what
- wanted 472 in ky,or oh,ind,ortenn
- Why do I need new retainers?
- 76 coupe tranny not shifting right
- Any blower kits made for the 472?
- A.I.R. Pump causing backfire?
- 1968 472 vacuum diagrams or pictures PLEASE
- Info needed on 88 Fleetwood Engine swap from 307 to 500
- A bit puzzled, any help?
- tranny for a 472
- rear end vibration
- Somebody help !
- Rebuild Engine or Crate Engine?
- 81 Seville V-8-6-4 Deactivation
- serpentine belt system?
- 472/500 Application Questions
- vacuum lines
- V 8-6-4 info
- New Carb?
- 472/500 Intake MIA
- knocking sound?
- choke help
- Spark & Fuel Timing
- '81 DeVille - Last Questions for a While
