View Full Version : 500, 472, 425, 368
Pages : 1 2 3 [4] 5 6 7
  1. What are these holes??????
  2. i bought a 472
  3. Cad 472/500 intake on EBAY
  4. 1966 Deville Restoration
  5. 68 Flywheel Cover
  6. '77 425 motor question..
  7. 81' 368..Need parts, any ideas?
  8. fuel pump outlets
  9. th 350 oil dipstick
  10. UPDATE, '76 eldorado project
  11. Carb Kickdown
  12. Does the '74 Eldorado w/500cid need premium?
  13. Valve covers
  14. Best Suspension
  15. 79 CDV 425ci - TPS
  16. '82 368/parts from 472
  17. 500 engine overheating
  18. Cool Cad 472/500 engine swaps
  19. What were the 472 V8's making for power?
  20. Need Help Quick! 368 4BBL Timing ????
  21. What color paint??
  22. 472 crank full of water
  23. radiators
  24. rust in the intake manifold
  25. Looking for info on 311ci engine (used in 49-55 Caddies).
  26. new carburetor for Eldorado 1973 500cid
  27. 472 1983 DeVille SWAP DONE - Pics/Site
  28. Is there a for sale section ?
  29. Cad into 82-91 Camaro swap info?????
  30. motor for sale Phila area??
  31. Aftermarket BB Cad support?
  32. 368 -5.0 swap advice
  33. Resetting mileage?
  34. Identify this cadillac engine
  35. Fuel system? HELP!
  36. what holds the tranny on?
  37. How to eliminate smog pump
  38. Car starts but wont cut off ahhh
  39. Info Needed For '79 Coupe DeVille!
  40. Q: where i can find carburetor #
  41. 1976 500 head swap
  42. 52 caddy help
  43. Help! My Truck runs like a Drag car!
  44. new here and need help
  45. hmmmmm......
  46. hmmmmm......
  47. taking head off
  48. Torque Monster Bit Me!
  49. 10:1 500 on pump gas?
  50. Second Battery?
  51. 472/500 exhaust manifolds on a 425
  52. Headers...
  53. 68 472 passenger-side exhaust leak
  54. Newbie questions...
  55. Bought a 81 coupe deville
  56. boring over displacement
  57. engine for sale phila area
  58. 8/6/4 questions
  59. 1970 - 472
  60. 72 sedan deville update
  61. MPG-Crate Engine
  62. 1972 Caddy 425 Powertrain
  63. Rebuilding a 1971 500
  64. examine my ignition system
  65. broken valve cover bolt
  66. How much to refresh a 472/500?
  67. Seville 81 368 V864 ecm identification
  68. Engine Dimension Needed.
  69. dwell setting from 24 to 31?
  70. Fuel Injected 500
  71. engine for sale phila area
  72. Battery
  73. 368 to ???
  74. Timing Issue 472
  75. Free CD/T Shirt....'76 Coupe De Ville/
  76. dumb mistake regarding timing
  77. 368 performance
  78. 79 deville 425 ticking
  79. Help needed - 61y Cadillac engine intake manifold
  80. This would be an awesome 500 swap
  81. 100hp/liter out of a stroked 500?
  82. Fuel pump on 429
  83. Anybody try these before?
  84. VIN Decoders
  85. Top End Semi O/haul
  86. 1/4 mile times??
  87. Transmission Adapter Plates
  88. 500 Ignition Problems
  89. 500 Crankshaft bolt ??
  90. How to decide which engine?
  91. Tunnel ram intake for 500!!!!
  92. Need help identifying this car...
  93. improve performance on 500 motor on '76 Eldorado
  94. Lets have a vote...
  95. Tune up time for my new (to me) 472
  96. Headers
  97. If you got the money...............
  98. Finally grabbed a 4L80E
  99. Turbo 400 , 89,000 miles
  100. running unleaded in a classic caddy
  101. Timing Gears
  102. Need opinions
  103. Electronic Q-jet
  104. Ported Intake?
  105. 1973 500 Cu. In. Question
  106. K&N Filters
  107. 1976 Eldo 500 vac routing
  108. engine id #'s
  109. V8-6-4 is no 425!
  110. 472 or 425
  111. Clutch or flex fan...
  112. Cadillac 500 Exhaust Manifolds
  113. putting 425 in '76-'79 Seville
  114. Fleetwood Coupe 368 Advice
  115. need help indentifying heads
  116. Need pics of Cad 500 in Cutlass
  117. Shift kit
  118. 472 intake on 425
  119. Manifold bolts 472
  120. 1969 coupe deville problems please help
  121. What would it cost?
  122. Got A V-8-6-4 For My 82 Coupe Now?
  123. Christmas Came Early!
  124. Valve Covers?
  125. 1969-1970 Eldorado "sleeper"
  126. 472 oil pan mods ?
  127. Header Gaskets?
  128. 425 AC compressor interchangeable with 472?
  129. Should I rebuild the carb on my 472?
  130. K&N Open Element Filter Kit for 472?
  131. pre 1974 472 heads on 425ci
  132. Performance build using 2.28 gears....
  133. Group buy?
  134. 1973 472 w/o air
  135. Eldorado Specs
  136. Welcome to the Big Block section...
  137. Ultimate Database/FAQ of the 500 | 472 | 425 | 368
  138. 472 pictures put together out of car
  139. Post HEI conversion questions
  140. Air Intake Mishap...?
  141. My Caddy Is Making An Odd Noise
  142. 1980 deville
  143. Cad. Co. Headers
  144. Top End rebuild
  145. Engine Color and Stand
  146. My Big Block Caddy Project...
  147. Fuel Injection...is it worth switching it over?
  148. Pan Gasket
  149. HELP! Stuck in Atlanta! 69 472 will not stay running and I NEED to leave!
  150. 472 Pistons
  151. Headers for Fleetwood...who makes them?
  152. weight 425ci
  153. Imagine a 500cid with PFI!
  154. 472 NOS build
  155. 2 questions
  156. Gas Mileage of the 500
  157. 67 DeVille won't idle
  158. Computer?
  159. Lost Second, third and speedo on 70 Eldo
  160. Kickdown Switch
  161. 80 dev. fuel filter
  162. New carb
  163. Hey Quadrajet people
  164. videos and sound clips
  165. Removing smog equipment on 68 472
  166. Baffled?
  167. 73 for sale in maryland
  168. Motor Oil for the 500
  169. Help!! Rebuilding 500
  170. 500 Caddy Top End Clatter !
  171. Pictures of 425....
  172. Qudra Bog Problem or Fuel Pump?
  173. engine diagram pic
  174. 472 Featured in Hemmings Classic Cars
  175. Compression test, and now tapping
  176. drop horsepower
  177. new here and need some advice
  178. Go 425!
  179. HP or MPG and what would you do?
  180. Problems with V 8-6-4 ????
  181. A little idea
  182. check out this 82 cad with a 500
  183. how difficult
  184. need help with 472
  185. New Pics and question
  186. 368 non v8-6-3
  187. 368 non v8-6-4
  188. 425 headers
  189. Electrical Dillemma
  190. Check this beauty out!
  191. 500sx
  192. What do ya think
  193. James Bond
  194. Old Caddy--parts in Baltimore?
  195. 500 Build; Assembly Progress (PICS)
  196. how to get to no 7 spark plug
  197. rebuilding engines
  198. 368 exhaust leak
  199. rebuild manual
  200. 69 472 spec's
  201. camshaft kit for 425 engine
  202. Fuel Pressure
  203. $$$ Rebuilding Motor
  204. what is it......?
  205. Early 472 Oiling issue
  206. 1968 472 Oil pump rebuild
  207. Any other engines out there...
  208. caddy 500 motor for sale S.E. WI
  209. Anyone with a 1977 shop manual
  210. Help: specs for a 68 deville
  211. Starting problem
  212. 500 cid head question?
  213. 1970 Eldorado hesitation...
  214. Help with timing on a 500!
  215. How to---------???
  216. 68 deville 472 air pump belt
  217. will a 200r4 tranny survive behind a stock 425 v-8?
  218. rough idel 1978 425 cad cdv?
  219. What engine?
  220. Did a Compression test today.
  221. Carburetor adjustments
  222. Good Cam for my 1970 Eldo
  223. best way
  224. 500 fuel injection intake
  225. Timming on a 472
  226. 500 casting numbers
  227. Parts question
  228. I have a recently rebuilt quadrajet from a 72 Eldorado for sale.
  229. Holley 4175 Rochester replacement in 68 472
  230. Some thing wrong with my caddy help
  231. 472 vacuum diagram
  232. carb question
  233. Has anyone used the Edelbrock intake #2115 for the 472?
  234. 1975 Caddy Needs More Power From 500
  235. Intake manifold
  236. Last pictures of the 425....
  237. Headers to a -68 DeVille
  238. 500 ci parts
  239. It was a good day...
  240. Failed the dollar bill test
  241. finally
  242. crank pulley/balancer
  243. How to remove variable displacement stuff on V8-6-4?
  244. 68 deville/472 water pump questions
  245. 472 or 500?
  246. V8-6-4 ???
  247. 81 Deville 8-6-4 continuous fast idle
  248. Rear Sump Pan/Pickup question
  249. were to get parts for 502
  250. For maximum horsepower and torque.. which motor?
