View Full Version : 500, 472, 425, 368
Pages : 1 2 [3] 4 5 6 7 8
  1. 1967-70 Eldorado exhaust manifold interchangability
  2. Parts needed for a 1971 472 CDV
  3. Parts availability
  4. How do i go from an external regulator type alt to an internally regulated alt
  5. 1971 472 runs rich until warmed up
  6. Pics needed!
  7. new carb but still hesitates any ideas?
  8. how to tune a 4bbl quadrajet
  9. Name that fluid! (please?)
  10. EGR Transducer HELP!!
  11. 425 engine with a 501 intake vacuum routing
  12. 1971 472 Vacuum Line Diagram
  13. 1971 472 problems
  14. Anyone who has a kickdown switch for sale ?
  15. OVER HEATING Engine pressure/Water pump,Therm,Heater
  16. Turbo 400 rebuild price check...
  17. 472 runability problem
  18. Help with engine id....
  19. 1971 472 Ignition swap to HEI
  20. Summertime - Back to work on my 70 Eldo
  21. 1976 Sedan Deville 500ci oil capacity
  22. 1984 fleetwood 500
  23. 71 Eldo w/425 exchange from 500 VIBRATTING
  24. eldorado injector size
  25. Continuation of the water pump saga
  26. 472 waterpump/serpentine belt problem
  27. GM engine oil supplement vs EOS assy lube vs STP oil treatment
  28. Horrible Squeking
  29. 500 ci firing order? 76 FWB
  30. Broken Stud bolt
  31. 70 Eldo Timing, and Hot Hard Start
  32. Resistance wire >>?
  33. 1971 Eldo 500 to 425 engine swap
  34. 500 motor in chevy truck
  35. Alternator Ground Wire Melts
  36. Technical question. Please help
  37. 1968 engine overhaul
  38. Valve seals
  39. HELP! 1970 Eldo - drive shaft boot seal tearing
  40. Changing water pump, any tips or advice?
  41. Dwell Setting 1970cdv
  42. Using a 350-C Trans behind a 425
  43. 500 into A-Body
  44. Hood stuck, help!
  45. 71 Cad Eld and previous owners of vehicle in US
  46. Transmission shifting vibrations
  47. Timing Out by 180 Degrees?
  48. Gap setting for 472 points
  49. Grade of oil
  50. WTB: 472/500 Rear Sump Oil Pan
  51. 1971 Eldorado Front Drive shaft bearings
  52. Proper Idle RPMS in park???
  53. I might get shot for this.
  54. Parts Catalogue
  55. "Lazy" transmission
  56. Keeping a tired 472 happy
  57. Exaust manifold
  58. It's Alive
  59. 71 Eldorado Gas Gauge
  60. HEI Upgrade
  61. 71Eldo/472
  62. setting up timing on TDC
  63. Oil filters
  64. Timing/dwell/idle speed questions on a 73 CDV (472)
  65. 425 not running
  66. prefabricated exhaust system
  67. Do 390 and 500 have same block??
  68. Please Help if you can 368 8-6-4
  69. 1968 Sedan DeVille
  70. Dip Stick length/ how much oil??? 472 motor
  71. Does the 500 really NEED shaft mount rockers?
  72. motor identification #
  73. Please help NEED 500 block heater plug???
  74. Part number Quadrajet
  75. inherited 1965 sedan deville
  76. 472 72 Cdv
  77. sick 425
  78. reliable 472?
  79. 368 engine swap for '62 pickup ???s
  80. Distributor Stuck!
  81. Engine keeps turning over after shut off, please help!
  82. How to flush Radiator
  83. Power Loss in heavy traffic ??? !! Please HELP !!
  84. Block hugger vs mid length header in a 70 deville
  85. 472 strange knocking
  86. Stick shift
  87. Cadillac Big Block Engine Assembly Guide
  88. 500 for parts
  89. Stroker Kit for 500
  90. Cadillac Seville with problems - one restoration.
  91. Exhaust Ticking on 472
  92. I need a engine pic of a '73 Eldorado please.
  93. 69 caddie deville
  94. Erratic Timing on 472
  95. '82, '83, '84 368 6.0 liter engines
  96. 1973 472 Ignition Conversion HEI
  97. Help - Engine Cadillac Seville V8, 6 L, 368 CID
  98. 425 Timing
  99. rough running
  100. motor swap ?
  101. Info on 425 motor and 400 transmission
  102. Constant Velocity Joint?
  103. spark plug mystery
  104. 1970 Cdv 472 Idle?
  105. Will Eldorado 500cid engines fit in RWD Fleetwoods?
  106. 472 high pitched whine. Help!
  107. V8-6-4
  108. My First
  109. THM 425 Ring and Pinion
  110. new question on 500ci timing and vacuum
  111. Turbo 400 trans question and rear end gears
  112. 425 heads
  113. 1969 DeVille Thermal Vacuum Switch?
  114. Oil in valve covers (500)
  115. My first Cadillac...and its dead
  116. HELP!! 472 Running Bad
  117. 500 Rebuild
  118. Kick-down switch
  119. 500 Engine Rebuild Problem-HELP
  120. I just got a 1973 CDV (472) and have questions
  121. 78 HEI into 69 472
  122. quick question
  123. oil pump primer
  124. 472 upgrades
  125. 500ci vacuum routing
  126. Ready to switch to Caddy 500
  127. 425 upgrades
  128. Engine Swap
  129. Pcv?
  130. valve seals
  131. Military guy back from overseas. Need help with motor mounts :)
  132. 500 into a '79 CDV. How easy?
  133. Twin Turbo 472
  134. Fast Idle
  135. website
  136. 368 V-8-6-4 No Start
  137. Can't get her into gear, im lost
  138. Stock valve covers needed
  139. Quadrajet Coil Choke
  140. 1969 Deville idle
  141. 500ci Identification. Casting #'s, etc.
  142. Driving in Low...
  143. 500 Fuel Injection
  144. F/S 472 parts
  145. connecting rods
  146. 368 TBI Rebuild
  147. 500 head swap question
  148. 500 Fuel injection parts car
  149. Camshaft
  150. Flywheel for a 1977 425
  151. 368 8-6-4 Woes.
  152. Today is the big day
  153. Swapin' a 500 into a HT4100
  154. 472 transmission bolt pattern
  155. How can I get this beauty running sweet again??
  156. 1970 Eldorado System Conversions?
  157. My HEI swap is almost done. Just one small problem...
  158. Blown 472?
  159. New Caddy lover with a few questions guys...
  160. Ford 460 intake adapter
  161. Engine coolant was leaking from the driver side
  162. Replace transmission spark control module with T-junction?
  163. Help me make a 472 purchase.
  164. Choke Stove
  165. I have a 425 but where do I post about the car?
  166. Headers
  167. Fledgling Caddy Owner
  168. Getting Confused
  169. Need some of those V8-6-4 solenoids...
  170. ahhhh i need help with this ticking!!!!!
  171. Newbie w/Oil Leak
  172. 500ci Gas Mileage Survey
  173. TH 400 swap
  174. What type of carburetor can I use to replace my old one?
  175. Problem Converting To Hei On 69 Fleetwood
  176. Carb time - replace or rebuild?
  177. Whats a highly desired normally aspirated INTAKE ?
  178. Ring Gap?
  179. radiator source
  180. problem with carbies
  181. v864 hp upgrades?
  182. I Can't Believe It!
  183. Commercial vs non-commercial 500
  184. New guy searching for some answers
  185. More Compression
  186. Introduce myself, and I have a few ???
  187. 68 starter / ignition
  188. Tranny Swop out?
  189. 73 500 Heads on a 74 Block
  190. I'm happpppy!
  191. Supercharger on a 500?
  192. 500 block parts
  193. Rear Ends
  194. 1981 TBI problems, toooo rich
  195. give me a hand with setting the timing on my 73?
  196. Will a 472 bolt up to a 1958 transmission?
  197. look at this 500 big block motor for sale
  198. Shifter Issues
  199. Cadillac 472/500 swap questions
  200. Just a heads up for 500 cu.in. DFI owners.
  201. special engines
  202. 1968 Deville Convertible Died
  203. 368 8-6-4 disable
  204. 429 help
  205. mileage
  206. Timing adjustment '72 472cui
  207. Edelbrock intake
  208. Headers for a '72 CDV?
  209. Q-Jet to edelbrock manifold
  210. A few questions about using a 500 in a tow rig
  211. knfuzd51 motor or at least the owner is
  212. Replacing seals in 425
  213. What is it?
  214. anti-freeze
  215. Preferred 425 timing procedure
  216. It"s Stuck!!!
  217. 779HP, 507 cu in CADDY
  218. 425 Carb Problems Caused by Charcoal
  219. Any advice on this?
  220. 1971 Hearse a/c problem
  221. oil galley plugs/ removing valves
  222. Couple questions about 425 performance upgrading / exhaust.
  223. Another 429 A/C Question
  224. How to adjust air screws?
  225. Transmission
  226. Sanden a/c upgrade
  227. Engine Bolt Kit
  228. 500 Question
  229. NEED a 472 INTAKE MANIFOLD IN OHIO
  230. 425 hesitation
  231. How much slack is alot!!!
  232. 472 finished here the pics
  233. 425 Remanufactured Heads
  234. 6.0 368 pros and cons
  235. dipstick blowby
  236. LongBlock 472
  237. 425 to 500 conversion
  238. hot stude
  239. Fuel injection questions
  240. Vacuum leak
  241. This may upset some Folks Sorry
  242. Tranny fluid, Mercon V question
  243. 70 472 dieseling...
  244. Transmission Suggestions for 500
  245. Is a ONE PEICE Oil Pan Gasket Available?
  246. Rockers
  247. Question..
  248. need a 500
  249. Steel Timing Set,*Check*
  250. 368 heads
