- 1968 472/500 Quadrajet EGR crossover Baffle?
- 472 ticking sound
- slight knock---425 engine
- Odd sound ?
- Real quick valve cover question!
- Cadillac 472 emissions removal
- Need 500 ci trans cooler lines
- v8-6-4 not working motor runs a bit rich
- Overheated 472... turns slowly
- idler- arm moog k5209
- engine conversion
- Freeze plugs
- Looking at a '70 Coupe DeVille, anything I need to look out for?
- sup dudes just picked up a 1970 coupe deville
- Headers don't fit my eldo
- Need Heads for 472
- Few questions on 472 q-jet
- Anybody ever used AIS Ram Air Box on a 425?
- Holley Q-Jet replacement carb.
- Exhaustpipe for my 1968 DeVille...
- Need to get engine and tranny out of shed---free stuff
- Canister Purge Hose !?!?
- 500 Cid For Sale
- '80 368 Spun Rod Bearing....Advice?
- 472 fuel injection
- Anyone ever see one of these?
- 1972 Deville 472 tranny failed
- water pump problem
- transmission choices.....
- 472 motor and trans out of 69 devile for sale
- Help to identify type of tranny in Deville
- pullin a switch
- Cork or Rubber Valve Cover Gaskets
- 500 with holley 750 and performer.
- 1974 500 in Pontiac Trans Am.
- switching engine fans
- Air cleaner lid
- 500 ci with q-jet
- 472 oiling system problem
- intake manifold 425 efi 1979
- 425 Project Underway . . .
- interchangeable parts...
- 8.2 not kicking down gears
- Timing Issues?
- Help identify my engine
- Temperature gauge
- Cloyes...?
- 425 intake and pulleys
- Electric choke (1975 SDV 500)
- Caddy 425?
- Looking for engine near nc
- In need of a new carb
- 425 bad stumble rich, timing? distributor?
- 472 in a 67 caddy?
- Engine bay warmth
- shaft rocker system
- Where is the Alternator Regulator on a 76 Eldorado?
- 500 Engine ID number
- How the heck do you remove the hub at the crankshaft
- need a motor
- How much should I pay
- thrown timing chain, 79 cdv
- '65 Sedan de Ville Carb
- HEI conversion questions
- 1970 deville wiring diagram
- What amp alternator for a '69 Fleetwood?
- New 472-song on MySpace !
- '79 425 need premium fuel?
- calling drmenard
- which route should I go?
- ??1981 Deville V8/6/4??
- 472 distributor
- first caddy build 425 in a model T
- New exhaust manifolds for 1975 500?
- 1970 Deville 472 Starter Bracket Picture
- Heater Core Replacement
- might buy 72 472 deville
- I....am an idiot....i think....472 water probe
- Exhaust kit questions
- 1968 Cadillac transmission questions
- pics kick down 1976 500 cid intake
- Oil pan sumps: Eldorado vs. stock Deville 368
- 1976 Deville, Cold Starting Problems
- Part #'s for CV joints in rear driveshaft
- 368 into truck swap (oil pan queastion)
- Cadillac with glasspacks?
- To wrap or not to wrap??
- Right Q Jet. Wrong Q Jet
- Cranky starter, 472
- Willington Cadillac?
- Needs Lifters/Carb work...Asking for Suggestions
- 76 Eldorado w/Fuel Injection Won't Start When Hot
- anyone want to guess whats wrong with my engine?
- Best motor oil for 425 engine ('79 CDV)
- 1965 Coupe Deville needs a new motor.
- Engine shake
- perfomance mods for 368
- WANTED: 500 engine
- 70 Deville, Neutral/Backup switch
- Trannie swap
- swapping parts from 472 onto 500
- Question Rochester quadra-jet
- Seeking advice on my '68 472
- Is it worth it!!!
- differences between 472 and 500
- 425 in a 84 Coupe DeVille
- Unleaded...
- Ford FI for 500 c.i. Caddi?
- coolant not circulating - help
- Charcoal Canister?
- 79 Dual Exhaust Conversion: 1 More Time!
- Engine dilemma
- vac advance / vac questions
- Throw me a frickin carb here people. Need the info. (Austin Powers)
- 472 Vomited
- In need of 69 and 77 Coupe Wiring Diagram
- 472 or 500 for '69 coupe?
- 1972 CDV 472 Vacuum lines????
- TH400 holds on to gear too long
- What size are the exhaust studs on a '74 472?
- 1976 500 fuel injection problems
- (not on a cadillac) engine runs rough/ will stall only in motion
- V-8-6-4 ??
- 472 distributor not turning
- 472 dumping oil and coolant - - -
- carbed 368 in a 1/2 ton truck
- quadra jet
- INTAKE and CARB
- need some help
- 500ci engine heads
- 1968 472 air pump vacuum line?
- 1976 Fuel Injected 500 EGR System
- 368 DEFI Fuel Pump
- Which size muffler wil fit stock exhaust on a 69 Deville
- misc 472/500 questions from a new guy
- Exhaust system for 500 in 67 Eldorado?
- Who Makes This Intake
- Removing the AC
- Rough start and ticking: 425 carb
- new guy here
- Head Identification
- 1970 Sedan Deville Input Needed.
- Can't get my 472 to turn over
- ECC Power Module
- 500/th400 into 62 SDV
- Value of 368/Turbo-400
- 75 CDV with a bad head gasket
- 472/425 intake swap: which gasket set?
- Qjet 4MV Kickdown - PICTURES - Look here
- Octane boost
- Gearbox oil filter
- Fuel filter for the 1968 Caddy
- Cad Company cam specs????
- Intake Manifold Modification
- Dual Exhaust Deville 1979
- 1969 70 vacuum routing?
- 425 Mods
- what air cleaner?
- Compressor seized, please help....
- Replacing Q-Jet with TBI?
- quick help.....like fast like
- Need Help With 74 Devile Oiling Problems
- 500 to 425 Balancing issues
- harmonic balancer 425 cui
- 69 caddy 472 idles high then sits and floods
- 472 500 oil sump swap tip
- Payback, 500 caddy style
- Cad 500 install
- Denice is knocking.
- quick question about engines
- HT4100 swap to a 425 ,help needed
- 368, transverse or not?
- hollander
- Help me diagnose this noise please
- 472 hei?
- Parting 1973 Eldorado.
- Big difference in power between the '67 429 and '68 472?
- where to find 472 rocker arms???
- 1976 Eldo questions
- Who's got a 73 Eldo wiring diagram?
- 1979 deville for sale
- Has anyone swapped in a Chevy 572?
- 79 Deville? Worth it?
- Something you don't see everyday.
- Cadillac Deville 1972
- 1973 472 Points Type Distributor rotor..Possible problem with Pertronix Igniter
- Number one plug wire location on Distributor..
- A few questions..Please help...
- Powersteerin Belt Keeps turning on me
- Need some timing help!!
- just gotta 425.. what bolts up?
- Help
- 472 Dead Timing
- HT4100 swap
- Exhaust Questions
- Wanted : Downshift lever for 1968 DeVille...
- Would this carb fit a 425
- MSD distributor
- 78 Big Block Build Up???
- Who wants my 425???
- Engine Identification
- Air and Coolant temp Sensors
- Timing set replacement
- Cadillac Big Block 368 8-6-4 Information
- 1970 950 Heads Wanted
- 472 swap
- HOFFA JR has trans problems.
- Ebay Item: 500 cubic inch cadillac engine and turbo 400 trans
- 425?
- 1974 Eldorado
- 368 fuel pump help
- What size motor?
- Just a feeler...Interest in a freshly built 425.
- Smog Era 500 c.i.d.
- Wierd question - Bellhousing
- What should I do with my 425???
- Horrible belt NOISE
- 4mv cold air intake flow
- 472 not keeping charged! HELP!!
- Emissions stuff
- Got towed today
- '70 Eldorado FWD Transmission "Clunk"
- Double Belt Over Single?
- Hei?
- 500 engine build up questions
- 500 Engine Specs
- 500 in 83 Fleetwood
- 71 Eldorado Conv Brake lights not working
- 1971 472 Quadrajet question
- FINALLY, got my motor and tranny for my next tbucket.....
- Need Help
- Need an Engine - 1969 DeVille 472
- new to cadillac engines
- Need vacuum diagram for 425
- i fixed my hesitation problem!!!
- "Mourning" sound on 1968 DeVille
- 368 to 500
- 500 crank thread size
- 472 1969 Fuel pump question
- Cheap Gas
- still having rough idel probelms!
- Air Pump Bolt 1973 472
- 71 Eldorado Climate control conversion???
- crankshaft key bolt
- Dual exhaust on a 75 limo?
- Proper timing,Idle,Air/Fuel Mixture for 1972 CDV..
- Dual Exhaust on 78 FWB???
- Snapped head of Power Steering pump bolt
- German Cadillac Driver need your help !!!!!
- got a set of G-Body big block mounts 4 sale
