View Full Version : Cadillac STS Forum - 2005 through 2012
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44
  1. 1994 STS loses power up hills
  2. Help with reoccuring misfire in cylinder 6 ... ???
  3. Tires Tires Tires
  4. Pin out
  5. Questions about 2005 STS performance parts
  6. 05 facelift
  7. Sts 2007
  8. 2006 STS 3.6 Oil Consumption
  9. 2010 18" CTS wheels on a 2005 STS, it work?
  10. Problems with rear wheel alignment on 2006 STS 6 cyl rwd
  11. Anyone help with pricing for this 05 STS?
  12. 08 3.6 engine noise
  13. IPM picture needed
  14. 2006 gps antenna
  15. Rear MRC Shocks
  16. 06 STS W/Black Grill
  17. Am I the only person in the world with these wheels????
  18. Replace rear MRC struts, today
  19. Service Steering Sys / Stability Secure Mode
  20. Remote transmission filter, anyone?
  21. 2007 STS Audio and Video inputs
  22. Daytime running lights
  23. GAH!!!! I have to do my headlight sealing over
  24. Do I need a new battery
  25. Rust on chrome rims?
  26. Navigation System Busted
  27. Rough Idle with no Codes 2005 V8 STS
  28. Sits Too Low
  29. Dome light removal
  30. Front strut torque 2008 STS V6
  31. Front bumper removal (HID)
  32. Possible group buy on D3 lowering springs????
  33. Navi install
  34. 40K Miles 8 Years Old Not bad.
  35. Plastidip on rims?
  36. ipod hook- up...again
  37. 2009 sts 64 cadillac convertible
  38. Light In Glove Box
  39. Acceleration Noise
  40. 190,000 Miles
  41. Help Removing Key From FOB
  42. I love the smell of Continentals in the morning...
  43. Can I put a 2006 STS 4.6l N* in my 2005 STS w/o any issues with ecm or install?
  44. Weird knocking when coasting 20-30mph with light pedal; almost like car is "slurring"
  45. (new here) 2005 STS rear suspension
  46. South east region meet
  47. Strut Tower Brace install
  48. Tpms
  49. 07 Non Nav to Nav
  50. Driver Awareness Package on 2008+
  51. People with the 2005+ Northstars: Do you have problems with oil leaks?
  52. Removing dash
  53. Just hit 150,000 Miles
  54. will 2005 CTS V6 parts fit on a 2005 STS V6?
  55. Brake Pedal
  56. Soft Trunk Release Button Not Working / 2006 Cadillac STS
  57. Alarm just went off...possible break in or issue with my alarm?
  58. 2005 Sts does out after throttle body cleaning and spark plug change
  59. What does your interior look like?
  60. Part #'s for headlight assembly gaskets?
  61. Advice or tips on trans install
  62. 06 STS rotors and brakes replacement cost
  63. MAF sensor needs replaced every 6-9 months?
  64. Wth!!!!!!! Driveshaft? Need help quick!!!
  65. Aux radio input options?
  66. stuck on ipod hookup
  67. 2006 STS V6 3.6 Water Pump Seal Replacement - Torq to Yield Bolts?
  68. STS not starting. Did everything possible. Its driving me crazy.
  69. Dealer unable to diagnose problem!
  70. Throttle position sensor
  71. Front wheel hub
  72. Headlights
  73. Tune up
  74. Bought a 2007 sts REPO without a key
  75. 2008 STS V8 exhaust system
  76. 1993 sts Shifting problems. Cadillac Family I need your help
  77. Window Regulators
  78. Nothing working in instrument cluster on a 1999 STS I bought last week.
  79. Anyone have a driver side taillight?
  80. 2007 STS-4, V6, 30 days CPO left, what should I have checked out?
  81. How to manually read CEL?
  82. 2008 STS base V8 exhaust system
  83. o6 sts vin runout. or build sheet?
  84. lowering my 2005 cadillac sts
  85. 2005 STS 1SE RWD 4.6L Engine swap VIN A
  86. Disable TPMS?
  87. Dripping under car---not oil or gas...possibly condensation from A/C?
  88. Advice from northstar DR??
  89. Rear suspension actuator?
  90. will cts parts work on sts????
  91. Passenger Side View Mirror (Motor) Replacement
  92. Bluetooth?
  93. STS Seat wiring
  94. Free s&h coupon code - cadillac merchandise, allarel, accessories, custom floor mats
  95. STS Lower springs (YES! cts stuff fits)
  96. Is this a fair price for this vehicle?
  97. Cruising RPM Seems high
  98. could my 07 sts V8 1sg be tuned?
  99. Re water inside headlights solved.
  100. 08 STS stereo?
  101. 2006 STS, timing chains and catalytic converters
  102. ECM and TCM locations? 2005 STS v8
  103. Free s&h coupon code - cadillac merchandise, allarel, accessories, custom floor mats
  104. 2006 Cadillac STS HELP with disabling auto door lock in gear
  105. Motor Mounts V8 from Rock Auto
  106. Orlando Cadillac Meet July 27!
  107. 05 sts stero
  108. Lost power brakes, rough idle
  109. 2000 STS Stalling
  110. Adding Satellite Radio to a 2005 non navi STS
  111. 2008 STS 3.6 Black Soot build up in tailpipe
  112. New to forum & Help!!!
  113. Proud New Owner of a 2008 Black STS
  114. smoke out tail pipes.
  115. cadillac sts
  116. need part numbers on wheel hubs
  117. 2005 STS Front Grille
  118. Sunroof Problems
  119. STS buying advice
  120. Leaking Coolant Somewhere
  121. 05 3.6 STS. engine noise
  122. Hood ajar warning
  123. Alarm!
  124. Stuck on side of road. Need ideas asap please
  125. Aux audio (again) - A2DP Bluetooth / HD Radio Tuner
  126. If timing chain breaks, would it.....
  127. 2005 STS Fuel Pump going bad?
  128. Tires...
  129. VIN doesn't match up with car description
  130. How many of you want coilovers for the 05+ STS?
  131. 08 STS V6 with 149,000 km: what problems to expect
  132. Excessive headlight condensation
  133. axle nut size?
  134. Cats need replacement, anyone know exhaust manifold torque values?
  135. XM Antenna Connection
  136. RX Throttle Body & V-Max Ice-olator review for 3.6 DI
  137. 2005 STS V6 Bose deluxe 8 speaker sound
  138. STS N* v8 MPG
  139. 2005 STS Rear Spoiler options
  140. I need helpful hints on changing oil on 3.6 STS
  141. Cadillac sts 1994 going into limp mode help please
  142. changing a steering wheel on the 08 STS replacing it with a 2011 sts is that possible
  143. Body Parts??
  144. higher stall converter????
  145. Intermittent Temp Gauge Issue
  146. Getting the transmission fill plug off is just about impossible
  147. 2012 & later STS Nav Discs - Version 8.0, 9.0 worthwhile?
  148. Chrome Wheel Horror Story
  149. awesome pinging sound coming from engine area
  150. 2005 STS oil problem
  151. Transmission issues?
  152. Work Commute
  153. #2 Key FOB Memory
  154. Wheels for 2005 STS V-8
  155. 2005 STS - V8 knocking
  156. 2007 STS will not start battery/starter/altenator good
  157. batter saver active
  158. Traction Indicator
  159. 06 STS V-6 engine issues....
  160. 05 sts wont start v8
  161. 2006 fuel reading low
  162. Hood
  163. Trying to replace starter
  164. 2005 sts v- hood
  165. 2006 STS Audio System vs. 2000 SLS Audio System
  166. Door handle issues, wondering about this
  167. 2008 STS sun visors
  168. 2006 to 2008 Transformation!
  169. Delay when turning car off and opening door
  170. 2005 STS Theft System
  171. Replacing 08 Lower Grill
  172. battery replacement question?
  173. 2008 STS Grill Replacment
  174. installing Camshaft Position Actuator Housing Assembly
  175. Cadillac customer service
  176. 07 STS Radio "Theft Mode"
  177. 17 Inch Stock Wheels
  178. Ugh... SERVICE CHARGING SYS
  179. 2008 STS - TPMS sensor problems
  180. Loose Window Control
  181. missing rear side marker socket?
  182. 05 STS system personalization error
  183. 2005stsApp sensor
  184. Headlight out; tried ballast, bulb and fuse... now what???
  185. 2011 STS Front Passenger Door Handle
  186. Had my trans fluid changed
  187. 2008 STS headlights
  188. Proud Owner of 2008 STS Grey
  189. looking for a 08-11 front oem grill. Need it shipped to canada!
  190. Can I change the Seat Settings without the stock stereo?
  191. dirty power steering fluid?
  192. 2005 STS Shocks
  193. valve cover torque specs
  194. Water created tallight issues
  195. 05 sts V8 wont start after changing starter
  196. 2006 STS timing chain issue
  197. My Cd changer has eaten my cds
  198. Is the deck lid spoiler a factory item?
  199. Bluetooth Pairing/Functionality...
  200. Parrot Bluetooth install
  201. My Older Dog Doesn't like My Tires, Or is it the Car?
  202. Just bought E&G mesh grille.. Need help
  203. difference between STS4 1sg and Platinum Edition STS?
  204. Speed Limiter
  205. Suspension question?!?!?!?!?!?!?!?!?!?!
  206. Rear Suspension
  207. scanner linking issue
  208. Tires
  209. front Driver Side ebony seal new
  210. STS Rear Diff Bushing
  211. 2006 Cadillac sts v8 N* rear air compressor
  212. Aftermarket HID problems, Auto Headlight feature not working properly
  213. tires for sts
  214. Will two compact spares fit in the trunk spare tire well?
  215. Rear Strut/Air bag leak
  216. 2008 STS brakes pulsating (?)
  217. 20" Tire Sizes?
  218. Bad Karma
  219. Climate Control Actuator
  220. Rear leveling
  221. Just bought a two owner 2007 Cadillac STS with 58,000 miles.
  222. Vogues Finally Came
  223. What signs do i need to be on the look out for when it comes to my GM 3.6 engine oil?
  224. Oil cap V6 2006 STS
  225. Resetting oil life on 05 sts v6 transmission
  226. 2005 STS - Burning MP3 discs ?
  227. caliper
  228. NAV System problem
  229. I'm about to buy a 2006 STS V6 with 77k mi.
  230. About to buy my first Cadillac!
  231. Rear Right Window Regulator
  232. Performance Chip?
  233. Motor surging and stalled out
  234. Custom cadillac logo floor mats
  235. I bought the 06 STS 2 days ago
  236. External Trans Cooler lines
  237. Warranty options for 07 with 65k miles
  238. NAV Updates
  239. Headlight Installation Nightmare
  240. Anyone added a second hood strut?
  241. Check Power Steering System Warning
  242. Spare Tire Question
  243. Installing Factory TPMS
  244. K&N Air filter
  245. help spark plugs and a few questions
  246. Gas Octane
  247. reset engine code?
  248. Oil eating V6
  249. Does the 5L50 have a temperature sender?
  250. Just a little note
