View Full Version : Cadillac STS Forum - 2005 through 2012
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  1. Should I buy 2006 STS V6 with 145K Miles
  2. Free shipping for forum members ends midnight 05/08/2012 no minimum purchase required
  3. Anyone have a Nav DVD that can help me out, please?
  4. 2005 STS Denso Nav unit, what to do?
  5. V6 or V8?
  6. Just installed new cooling fans??
  7. Northstar Coolant Hose Kit?
  8. Rear Suspension replacement question.
  9. Can't get Nav screen to show Freeway Mode
  10. Ignition Coil Replacement 2005 STS 3.6
  11. Torque Converters
  12. Has anyone ever changed the 17" wheels to 16" to save money?
  13. United Kingdom Nav Disc Update
  14. Code Reader/ Reset Tool
  15. 3rd brake light / spoiler differences STS V / non-V
  16. Does anybody know what wattage the fog lights are.
  17. 2008 STS Trunk Struts
  18. 2008 STS Navigation disk
  19. Rim size for my 2005 STS
  20. Let the mods / tweaks begin...
  21. Restyling Ideas grille
  22. 2011 sts
  23. Slowing Down - Downshifting - Braking
  24. Driver door sometimes doesn't unlock
  25. Wincos Window Tinting?
  26. 2004 STS running rough and making hissing noise
  27. Navdisc Release Month
  28. Onstar Remote Link for 2011 STS
  29. Rough start
  30. ATTENTION: warning: there is a snake amongst us.
  31. How to update Navigation
  32. 2007 STS Harsh ride, struts, air shocks
  33. 2005 3.6 jumping @ WOT
  34. 06sts
  35. Grilles
  36. JE5 Brake Replacement
  37. 08 STS with Blue Tooth wont play music over radio
  38. 2006 sts what stereo with bluetooth and xm will fit
  39. 2005 STS won't start
  40. Forum members: Free u.s. S&h on everything - no minimum purchase required
  41. Help: FOB Not Detected - Locked Out
  42. Lifting up intake manifold help for 05 Cadillac STS V6
  43. Test Drive - 06 STS N*
  44. Underhood plastic panels around engine
  45. BATTERY test
  46. Steering wheel bulbs
  47. Spoiler Install --- Drilling Holes --- Pics
  48. 05 STS Parking Break HELP!!!!
  49. 2007 cadillac sts service
  50. 07 sts head light issue
  51. Are The D/R/1/2/3 Lights On the Center Console Supposed To Light Up? 2005-STS
  52. Hide-away License Plate
  53. Forum Member Coupon Code - Free S&H No Minimum Purchase Amount On Cadillac Merchandis
  54. quiet tires
  55. STS Info cluster color
  56. Problem with window switch.
  57. psst - XM free trial in progress
  58. Pin Stripe Removal ?
  59. STS headlight options HID? Side marker Bulb replacement procedure?
  60. Can CEL codes be accessed without a reader?
  61. How To Remove Bottom Front Seat Cushion - 2005 STS?
  62. Car takes off at end of gear.
  63. Are the links in the STICKY not working for anyone else?
  64. update screwed up site and app on phone
  65. LOUD Beep coming from back seat or trunk
  66. New nav disc for free
  67. Speed limited to 120mph
  68. Where to buy rotors
  69. Looking to buy 2005 STS $13,995.00
  70. 2011 STS Lux RWD
  71. will sts prices drop?
  72. Low rpm whine from rear. Differential?
  73. 2006 sts tires
  74. First Hand Wash!
  75. New Baby!..Just Thought I'd Share
  76. Yay! PO174 fixed
  77. Yay! PO174 fixed
  78. PO174 returns for an encore
  79. while playing around with the code reader...
  80. Special Additional Warranty
  81. E85
  82. Winshield cooker?
  83. Spark Plugs
  84. Engine ticking sound
  85. Oil burn
  86. Service Stability and ABS lights/warning come on
  87. 2008 Tranny Flush?
  88. [Q] Side marker
  89. OIL all overtires/bakes/wheelwell removal?
  90. Program new car key fobs
  91. [Q] after market sub
  92. Differential Flush....Postponed!
  93. stereo install
  94. Cruise Control / Traction Control Problem
  95. 06 sts-v tires and rims on base sts.
  96. STS Navigation Lock pick and iPod interface
  97. AWD to RWD?
  98. Cadillac sts consideration
  99. Navigation screen all lines..radio and nav do NOT work now
  100. big brake kit for sts
  101. Can I stream my music through bluetooth through my phone?
  102. No fob
  103. Radio/Nav Trim Removal
  104. Headlight assembly condensation solutions
  105. Gmpp
  106. 19" chrome 1SG rear wheels.
  107. Air conditioning problems in 2005 STS V8
  108. XM 6 mos for $25
  109. Saying goodbye to my 2005 STS4 1SG :(
  110. Transmission problems with my 2005 STS V8
  111. Adding Aftermarket amp and sub, cant find 12 volt acc wire
  112. Hood to grille gap?
  113. Huge hail storm damage!!!
  114. Disabling or Disconnecting OnStar
  115. UPAC/Isimple and steering wheel controls
  116. timing chains
  117. 2006 sts Coils and plugs Tuneup 3.2v6
  118. 2005 sts brake job
  119. 05 Cadillac STS V6...bucking jerking and rattling
  120. Door rattling
  121. RE: Wrong headlight
  122. to buy or not to buy? 2005 STS
  123. 2005 sts4 v8 catalytic converter warranty
  124. wet n2o shot
  125. Need torque specs
  126. Torque Bolt Specs - 2005 STS V6
  127. Sts driver seat
  128. HomeLink Garage Opener Setup
  129. No A/C Cooling Passenger Side Front Dash Vent
  130. Cadillac merchandise - free shipping offer
  131. Cadillac merchandise - free shipping offer
  132. '05 STS V8 Rattling noise at low speeds
  133. 2006 STS - Issue with excessive brake dust on one Rear wheel - Why?
  134. Need a new passenger lower side skirt, 2008 STS
  135. 2005 STS No More Sound
  136. Now, a little whine likely from the drivetrain?
  137. 05' STS engine shut off while driving!
  138. Whats the best 3rd party extended warranty company available w/ the best services
  139. 05 STS in reduced engine power
  140. audio system - saving stations
  141. 2005 STS Nav issues
  142. catalytic converter 2005 sts4 v8
  143. 07-12 CTS-V Wheels on 98-04 STS
  144. Big News for my car....
  145. Engine Rev
  146. how to change spark plugs on a 2007 STS Northstar V8?
  147. Best way to clean leather seats and headlights?
  148. Traction control light comes on.
  149. coil packs
  150. 2005 STS 4.6l V8 - P0174 and p0171
  151. "Vehicle Personalization Error"
  152. Bought my first STS...What package do I have?
  153. Painting 2006 STS headlight Housing?
  154. two questions about my 2007 STS N*
  155. Turn signal relay
  156. Trans Hot Idle Engine
  157. I just bought a 2009 STS4 Luxury Premium 3.6 black ice w black interior...
  158. JE5 Brake Replacement
  159. Can the wreath & crest be removed from the CTS-V grille?
  160. 08 sts door panel removal?
  161. 2008 STS Ittermittenly won't shift out of park
  162. Want to replace my !7" wheels for 19" or 20"
  163. peanut light replacement?
  164. 05 STS V8 Front end Clunking noise low speed
  165. 05 STS Shifter sloppy between N & D
  166. Transmission differences 6L50, 6L80/6L90 Internal Differences
  167. Need Info on 2010 N* AWD
  168. 2005 sts passinger windows wont go up
  169. 2005 sts passenger windows wont go up
  170. please help with a bulb question
  171. Changing cabin air filter STS 2005
  172. 2005 sts passenger windows wont go up
  173. ... A little hotter than normal...
  174. Want to buy a Lock Pick to unlock DVD Navigation Features for 2006 Cadillac STS 4.6L
  175. Door handle components
  176. Start Button replacement Procedures
  177. 1harleyman
  178. Torque Specs/Wheel Bearing Caliper Bracket
  179. Help...starter issues?
  180. Can i add side mirrors with blind side alert?
  181. My first 3.6L???
  182. 55watt D1S ballast and bulbs?
  183. Tire(s), Wheel Bearing, or Other
  184. check engine light (ON) 06 STS
  185. Entry lights not working after locking or unlocking
  186. 3.6L starter location
  187. DTC P0174 and P0420
  188. Can I replace my Bose stereo with the NAV unit?
  189. 2007 sts4 limping along
  190. Need Climate Control Unit Pin Connector Identification 2005 STS
  191. Old school still apply??
  192. Fob not detected 2006 STS
  193. 2005 STS Climate Control Wire Color Code Or Pin Identification.
  194. rear shocks
  195. 20x8.5 and 20x10.5
  196. '06 STS drivers side rear view
  197. Cost of a paint job
  198. Charcoal Grey Front Bumper replacement?
  199. Bluetooth Issue
  200. what sts package do i have?
  201. 2006 STS "Fob not detected"
  202. STS will not start
  203. Digging back into the 3.6L.
  204. magnetic ride control question?
  205. Thinking of changing my CTS for a 09 STS
  206. Considering buying a 2008 STS
  207. 2007 northstar cold air intake?
  208. Removing Tire Marks Off Cement Driveway
  209. '06 STS Cruise Control not working....Fuse? Does nto have ACC.
  210. Helpful hints?
  211. 07 sts northstar shutting off while driving
  212. Dash
  213. SEVILLE E&G GRILLES & Chrome Stainless Steel Accessories www.usautocustoms.com
  214. Question about LED lights on Vanity mirror
  215. Installed Factory STS Spoiler on my 08 AWD 1SG
  216. Wipers??
  217. don't buy anything from member ITSQUIK ~~scam alert~~~
  218. service air bag light is on
  219. Anyone have a Driver Side Tail Light For Sale?
  220. Customer Satisfaction Program 10287 Question
  221. Chrome pillar posts, should I or not?
  222. Got my new to me 2010 STS....woo hoo!!
  223. 2007 sts v8
  224. sts country club edition
  225. Wheel/Tire question
  226. 09 Cadlillac STS 1SC Reviews Opinions Pros Cons
  227. Is my STS overheating?
  228. Transmission anomaly???
  229. 2005 STS Key question!
  230. Head light bulbs
  231. Trunk proximity
  232. Left mirro
  233. Some Navi Help Please...
  234. stearing wheel lights
  235. Navigation disc
  236. very bad condensation in the headlight assembly:-/
  237. Front Strut replacement
  238. confusion is abundant
  239. HID fog lights?
  240. power steering leaking 2006 sts
  241. Making Horsepower on the LLT v6
  242. Trunk switch replacement
  243. Pairing a IPhone to my 2010 STS
  244. Just a rant / complaint about the features of the SLS that the STS didnt get...
  245. OBD on a 2008 STS?
  246. Vmax Iceolater
  247. Lumbar Control is not functioning properly
  248. 2007 STS phone dialing without OnStar
  249. Fuel level low light
  250. Bluetooth blues
