- Transmission Issue
- Is this bad? (Oil In Overflow)
- Compressor for rear shocks
- (97 catera) New crankshaft sensor installed now won't rev above ~2700 rpm
- 00-01 front door panel remove
- Fresh Air Intake Hose/Tube
- Primary Radiator Fan Failure
- Ac not cold
- 2nd set of keys
- Frozen Strut
- Radio spontaneously won't turn on?
- Free shipping for forum members ends midnight 05/08/2012 no minimum purchase required
- Sagging Headliner
- New Front Struts Install 1999 Catera
- 2002 Catera Oil Leak
- new to me 01 cat. head gasket, want 5 speed
- Cadillac Catera Engine
- 2007. Remote link app
- 2001 catera engine light P0411
- 2001 catera transmission gear shakes when going over bumps
- 2001 catera slight knock once warms up goes away.
- 2001 catera engine intake metal clamp needed?
- New 2003 Deville owner engine jerking question.
- Cold weather is the DEVIL
- 2001 Catera EBTCM removal and replaacement question?
- Some misc parts for sale
- Chilton manuals
- Crazy Coolant Leak
- Coolant leaking
- Head Gasket Replacement... ANY HELP FROM KNOWLEDGEABLE ENTHUSIASTS PLEASE
- misfiring
- Coolant Water Transfer Unit
- Coolant looks like muddy chocolate milk.
- Transmission Fluid Change
- Is there an Accessory mode?
- 1999 Catera problems
- 97 Catera Speaker Help!
- Timing Belt Tensioners
- Oil burning 1978 with 425
- 2000 Catera Stalls a couple times when cold
- 2000 Catera Coil Packs
- 2000 catera overheating issues
- P0135 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
- 2000 Catera Problems
- Will a passenger side Coil pack work on the drivers side?
- Multi Function Relay
- car backfires, no start.
- Complete coolant flush help
- 2001 Catera Flashing "S" Transmission Issues. TCS?
- Head gasket? ? ?
- 98 cater dash lights, licence plates and rear lights
- Help with heater core hoses
- 2000 Catera disable trani check "S" light flashing sometimes
- about 10 different codes... please help!
- 86 Cimarron Digital Dash Odometer is stuck at 000,000
- Yikes
- Engine knock
- Rear seat center armrest with cup holder
- Would Not Start
- Where is the oil cooler located
- Alternator cooling
- Little Problems Adding Up
- Video: 1982 Cadillac Cimarron Dealership Promotional Video
- Body and sunroof drains on 2001 catera sport
- Muddy coolant
- 2000 Catera wont shift, 1st and reverse only
- K134 Multifunction Module
- 1998 catera smells hot. 50k miles
- I've noticed things are slow here
- Looking for special interior parts - Catera up to MY00
- Cleaning My K&N Air Filter
- ls1 catera
- Mountain Dancing in the Catskills
- 2001 cadillac catera only starts when i remove/replace battery terminal
- headlamp assembly pair
- Need help with matching a 4L30E to my Catera. Need some info!What does R96 and TCM 10
- What is this part called 2001 catera
- Coolant leaking on cold only, behind the engine, tranny area. Need advice, please!
- brake booster connects to the manifold? PLEASE ASSIST
- Key lock cylinder
- Catera EBTCM /Power steering issue
- My '99 Cat needs engine rebuild; I don't want it anymore. Options?
- No Front Breaks: HOW TO bleed Front Brakes? no fluid comes out line, reservior full
- Another Catera EBCTM Question
- Intermittant no brakes
- different kind if radio problem, already replaced K134
- Front Brakes
- Opinions Appreciated on 1999 Catera Damaged in car accident
- CTS timing belt breaking
- 2001 Sport "S" flashing on panel & all gear modes (P, R, D, 3, 2, 1) light up
- Head scratcher
- A.C. parts catera
- 2001 Catera ABS/TC/Check Lights On, No Speedometer
- control arms..dorman or raybestos.
- Shakes or vibrates violently
- catera sluggish on acceleration
- Oil Catch Tank
- P0301 OBD code
- HELP!! abs-traction control-engine light on. I need some serious help!!
- Multiple Misfiring
- 98 cat still going strong
- Engine shaking with RPM drop
- 1998 catera, power steering issue
- 97 catera. pulls when i brake
- Free Shipping Offer Cadillac Merchandise - Floor mats & Custom Cadillac Car Covers
- Tie Rod Adjusting Sleeve
- If anyone here is interested
- Vogue Center Caps
- 97 Catera with random misfire at idle only???
- Well its been fun.
- New Catera Owner (2000)
- '99 Catera // Sub + amp questions
- Dirty Coolant and Coolant in Oil
- 1981 coupe deville trunk lift support issue
- 2000 Catera valve cover gasket replacement
- ignition coil 1997 labor hours
- 2001 Catera Bose Stereo Aux Input
- Does this happen to anyone after they wash their vehicle?
- IAT/MAF Sensor location
- Catera car cover
- how to jump pins 12 & 14 on multifunction module
- This is creepy
- Rough Idle
- Omega Limited Slip Diff into a Catera??
- Cylinder 4 Misfire 1997 Cadillac catera (or might be 1999)
- Clunk when shifting P/R/D..... PLEASE HELP ASAP!!
- Suspension Evaluation Log
- intermittant no start...please help
- replacing instrument panel lights.. need help!
- 99' Catera starts, runs for 15 sec then dies ...every time
- 2001 ebtcm
- Universal Transmitter
- The Dream
- Thermometer out of whack?
- Hvac questions....
- need Part # Model List for Disc Changer
- PCV location?
- replaced fuel pump, still no start
- 200,000mi OVERHAUL
- 97 Catera Oil cooler re-assembly milky oil in intake
- Radiator
- Blind Re-Assembly of Catera, Few Questions, Please help!!
- Funny Read about our cars
- 97 Catera oil cooler re-assembly question!! Stuck!
- Buyers remorse after reading this forum
- Potential Catera Owner
- MV6 Alignment problem
- Free Shipping Offer Cadillac Floor Mats & Custom Cadillac Car Covers
- HVAC Vacuum Chart
- Aftermarket Tire Shake 45-60 mph Help!!!
- Lighting question
- Catera heater control valve
- Fuel System Issues
- 2000 Catera no heat on drivers side....
- Brake problems
- irmscher
- heater core
- Timing belt Tensioner
- Replaced Crank position sensor a couple weeks ago. Having intermitt starting problems
- Door frozen , coolant leak ect.
- Help !! I seem to have a heating issue with my Catera!!!!
- Cadillac merchandise - free shipping offer
- Help with Weird Vacuum / Check Engine / Fuel Cap Light
- 97 catera can't get heat
- P1220 & p1890
- Question for elvin315
- Selling my catera ....sadly
- 99 Catera Transmission Range Sensor Code P0705/P1700
- Brake Line Kits for 2004–2006 GTO
- Question about; Battery, Alternator and / or Voltage Regulator
- oil leaks 99 Catera
- Rough idle fixed
- Saab 9-5 Arc V-6 Turbo retrofit into Catera
- door check
- security
- 1998 catera wont start/turnover
- Full set of black interiour door handles wanted
- Oil in spark plug wells
- Windshield washer nozzle
- Low coolant light won't turn off
- Tires - T rated vs H rated
- Noisy sway bar links?
- dumping coolant out under head
- Finally Upgrading My 2001 Catera Sport Front Suspension
- Traction Control 99 Catera
- Coolant leak & heat not working after replacing oil cooler/radiator
- Steering- idler arm bracket attachment?
- Rear inner tire wear and trim height
- Can I use a 1997 Catera Radiator on a 2001?
- Oil leak, upper oil pan gasket?
- How do I flush the water system/radiator??
- small inlet pipe ontop of water pipe
- bypass heater core in 1998 Cadillac Catera
- Serpentine Replacement
- I need a PVC vent tube adapter for my 99 Catera....
- Please!
- Is the trunk lid supposed to fully open automatically after releasing?
- Road Trip in first Catera
- BCM Reprogram
- Electrical Help needed please
- CD changer
- searching for post #221 from10-10_09
- 2001 Catera Coolant Leak
- Misfire code, replaced spark plugs, now car will not start (but cranks) & P0340 code.
- Mis-fires, did spark plugs, now P0340 and no start. Help
- 1997 Catera parts: new, used, aftermarket, custom etc.
- 98 Catera windows don't work
- 1998 Catera TC light on, RPM tack stopped.
- Oil cooler replacement???
- 1998 Cadillac Catera Oil Pressure prob. - Need clarification on "Oil pressure switch"
- Fuze Keeps Blowing
- 1998 Catera Interior lights won't shut off
- HELP! My radiator Blew and I have coffee colored gunk all over... need advice asap.
- AC vacuum pump?
- 98 Timing Belt Cover Bolts
- Dallas Cars and Coffee October 1, 2011
- 12V LEDs - Success and help.
- special tools for timing belt-2000 catera-do you need them to replace head gasket?
- Which one I should choose?
- 98 Timing Belt Alignment Problem
- Front (or rear) crank seal leak?
- 99 Cat Engine Power Loss?
- 99 Catera , Auto windows / Interior lights Quit
- Overheating problems??? head gaskets??? oil cooler???
- 98 Catera driver's side front door problem
- Catera Temperature Sensor & coolant leak
- It is obvious that the Catera is a repair prone vehicle.
- my 98 cetera wont start
- Any thoughts about going turbo?
- Your rims...
- 2001 Catera Aux pump part #
- 1998 catera major transmission fluid leak! - please assist.
- Mass air flow replaced
- Banging noise on suspension & creaking steering...
- Catera 98...............
- Is there a connection between trouble codes 301, 1100, and a sudden downpour?
- major vaccume leak ..
- 1999 catera not starting
- Brake lights
- 2000 cadillac catrea
- EBTCM part number? 1998 Catera
- Any idea's on how to fix a stripped wiper arm motor post?
- Still looking for these parts.
- At what PSI should the cooling system be tested?
- 1998 catera trans problems and gauges not working
- Part Needed
- Does 2001 Catera Have a Diagnostic Mode?
- Pulled the Front Seats From a Catera Transplanting Them Need Help
- Now THIS is a Cadillac!!!
- Crossover bridge seals, shouldn't they be rubber?
