View Full Version : Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19
  1. 2000 Catera Interior
  2. Your Catera experience!!! good, bad, ugly??
  3. 98 Red Catera for Sale
  4. what's "enough" horsepower for a catera-sized car?
  5. New Mod very simple
  6. So - Is it the Heater Control Valve?
  7. Transmission Info *sticky* Info Only Please
  8. Europe Ebay chips
  9. Europe Ebay chips
  10. Does Dexcool turn green when it leaks?
  11. Torque specs for intake manifold
  12. Catera & Omega Parts
  13. quotation light
  14. GM Warranty?
  15. Ideal filter location?
  16. Head light question
  17. Ac In 1997 Cadillac Cetera
  18. Catera Production/Sales figures
  19. Antifreeze leak, back of engine
  20. Foglights...again
  21. ebay catera sport 99 for sale
  22. Which engine cover is this?
  23. Air Schoop? Who has this?
  24. 2000 + Cateras
  25. ECM Replacement
  26. What next?
  27. Trunk lid liner removal
  28. aftermarket radiators
  29. Timing belt and head gasket $ estimate
  30. car won't start
  31. how to read Catara trouble codes
  32. Heater Control Valve question
  33. Parting out Catera!! What do you need!!!
  34. Coolight Warning Light On
  35. Missing Parts
  36. Answer to Front Cover question
  37. catera lift-points for a non-factory jack?
  38. Oil Warning Light...
  39. 2001 Cat Steering ?
  40. coolant leak?
  41. 1998 Catera Problems (HELP)
  42. 98 Catera rear end change.
  43. ScanGauge II (Installed) Pics
  44. Inquiry for Elvin315 Regarding Rotors
  45. did any recalls affect 2001 catera sports?
  46. 97 Catera oil in coolant
  47. Body Kit for '99 Cat
  48. is this a stock wing?
  49. A cheaper alternative Camshaft lock tool!
  50. Stabilzer links? Quick Question
  51. Timing Setting/Locking Kit
  52. Front Bumper Cover
  53. "platinum" silver touch-up paint?
  54. Question For Searayjba, Guardian & Anyone Else W/Knowledge Of The New Catera Ebay Eng
  55. Oil Pressure Light
  56. Alarm system Lights wont stop flashing
  57. Bad Dent - What to do?
  58. Stains on my rims!? I hope not!
  59. PossibleSupercharger for the Catera??
  60. a/c compressor noise engine noise?
  61. Catera Question
  62. Strut Spring
  63. Just Bought CPS, Still Won't Crank.
  64. What Do Ya Think? Just cleaned & waxed
  65. Just Wondering...
  66. Just my luck...
  67. Daytime Running Light burned out
  68. check engine?
  69. newb with 98 Cat
  70. Pulled her out of storage, Washed and Cleaned.
  71. Sport Mode
  72. *BLOWER MOTOR* - Help!
  73. Fog light question for Todd
  74. Vacuum Line Question
  75. Its Timing belt thread time
  76. Squeaky Gearshift
  77. Timing Belt Service
  78. 01 Catera Sport Tire Wear/Alignment Issue
  79. coil pack problem?
  80. Remove driver's side door panel?
  81. She just shuts down????
  82. Possible air ride suspension question
  83. This may help everyone!!!!!
  84. Cross-drilled rotors worth the hype?
  85. This must be a scam or is it? Performance Adder
  86. Wanted: Silver Dash Trim for 01 Catera
  87. Best Brand for HIDs
  88. GPS navigation system for '99 Catera?
  89. 02 Sensor
  90. Flashing CEL and rough idle for appx 20 seconds
  91. Cat on the Race Trac
  92. New Member with Question
  93. Need driver's side fog lamp...
  94. low coolant = low oil pressure??
  95. Starting car problem - Have to wait now
  96. Sunroof dosen't work????
  97. Has anyone seen this awsome muffler?
  98. Just got a OBll Scanner/Reader and love it
  99. Todd2fast4u and other cold air kit owners
  100. transmission just started "whining"...ideas?
  101. Where is the multifunction module on 99 Cat
  102. Radiator repair or replacement?
  103. Need lifters,
  104. looking for another rear differential
  105. ebay cold air intake, any good? worthwhile?
  106. Anyone need a 97 catera?
  107. 98 Catera Oil Pressure
  108. Catera Sport & Lowering Springs
  109. Nice lips and headers from Germany
  110. whining noise in rear end
  111. Sticky slimey controls buttons and panels!!??
  112. Where did this broken bolt come from?
  113. Hood lift supports
  114. Catera Parts from Germany!
  115. Vacuum Tubes?
  116. 1997 catera exhaust manifolds
  117. Car Vibrating
  118. cleaning the breathers!?
  119. 98 Catera Won't Start
  120. Stock speaker size for 97 cat
  121. Engine Shakes and Loss of Power
  122. grinding noise in rear while turning
  123. A simple test and easy fix...
  124. Dead Batt....Bye Auto Down
  125. Catera exhaust & sound
  126. When the timing belt goes...
  127. EuroMax 5 Spoke Wheels 18x7.5 -42mm
  128. No heat across the front dash..in My 99 Catera
  129. Would it be useful/interesting?
  130. 1998 Catera Heating and Defroster
  131. Timing belt noise Ewill3 ,Mark DTM and the A team
  132. Spark Plugs Replace
  133. J 42069 Timing Belt Alignment Kit
  134. Climate Control Air Sampling Fan
  135. Well,.. it's official...
  136. opel/vauxhall omega-B owners: was there ever a 5-spd auto tranny available?
  137. changing oil pump 98 catera
  138. Goodbye
  139. Timing Belt & Tensioner Change
  140. Weird Noise=Hesitation=Few Days Later Will Not Start??
  141. Foggy Headlight?????
  142. CTS 3.2L, Updated Timing Parts?
  143. 98 Catera Grille
  144. Loads of problems. What should I do
  145. front plate removal
  146. HID Upgrade
  147. My first car a Cadillac Catera, my next one another one?
  148. catera won't start when hot
  149. head replacement
  150. Used '00 Driver's Headlight
  151. No High Beams
  152. motor sounds like small turbine on startup
  153. Denver Cat
  154. OBDII Scanner Recommendations???
  155. Strange noise coming from '99 Cat
  156. Wouldnt start
  157. Amazing! Get better MPG! Gurranteed!
  158. replacment emergency brake boot
  159. Strange noise coming from '99 Cat
  160. 2001 Catera Won't Start
  161. can catera solar glass be polished?
  162. catera solar glass??
  163. airbag missing??
  164. Heat problem
  165. Gm Parts Direct.com Reliable???
  166. What do you think of the rims?
  167. Need Help Misfire issue causing spark plug wire feilure
  168. Battery Indicator Light
  169. Really, Really Smokey & Losing Lots Of Oil!
  170. 98 Catera Headlight Aiming
  171. 01 catera headlight lense
  172. new cat owner 2001
  173. Question for Marks DTM Calib or anyone who may know lol
  174. Vibrations at 50 mph
  175. quick question
  176. Spark knock,
  177. Coolant Light
  178. Value of my Catera???
  179. Pics for fog light fix
  180. 2000 Catrea has an oil leak
  181. Crankshaft Sensor just replaced, same problem again. Won't start.
  182. Scared to let go
  183. One last Load Leveling question(I found the leak)
  184. Security System
  185. Radio Connections
  186. Calling the A team, re;engine noise
  187. Marks DTM Calib cylinder #1
  188. More Power!!! Check This Out! Cam adds 20hp
  189. Anybody Recognize This Part??
  190. Wonder what the insurance outcome will be
  191. Downstream And Upstream Sensor
  192. Consumer Reports Recommended Catera
  193. Upgrading all audio in 98 catera
  194. Rough engine idle
  195. Jeff Po135 Bank 1 Sensor 1
  196. Suspension Question
  197. what part is this???
  198. 2000 Catera starts fine, then shuts right off?
  199. Cel Light 2000 Cat
  200. RADIO CLICKS ON & OFF 2000 cat
  201. Can I wash the engine?
  202. 98 cadillac catera leveling very bad.
  203. Got a Saab & selling my re-badged Vauxhall Omega!!
  204. Front engine noise,
  205. wood dash kit
  206. 1999 Catera Alarm System
  207. Ebay Headlights Revisited
  208. tramlining/darting update -> confirmed wider tires make it worse!
  209. New member with 5 speed swap question...
  210. Engine Performance Parts Question
  211. Just wonderin'
  212. Oil Pump Gasket leak?
  213. vortex generators?
  214. dashboard lights
  215. ~1qt oil consumed every ~5k miles...ok for a '01 cat w/ 58k miles?
  216. camshaft panel seals
  217. custom cat-back exhaust
  218. Hooking up Sub to BOSE amp
  219. Wheels Are Rare for Cateras...?
  220. Any body kits found?
  221. P0440 Evaporative Emission Control System Malfunction (Not Gas CAP !!!)
  222. 2001 Catera sport hid left low beam out how to fix?
  223. Thermostat question
  224. The Verdict Is In: Blown Head Gasket; Now What?
  225. Air Bag Light
  226. part number locator.....how do i find a part number?
  227. clusters need help
  228. Any experience with ELM323 scan tool?
  229. Low to non existent Heat
  230. Lean Bank
  231. Help with Suspension/alignment issues
  232. Noise when heater on
  233. Cruise Control Photos
  234. Remote Keyless Entry & CAT keys
  235. 2000 Catera with many problems!
  236. Center armrest cup holder
  237. shut the door and then the car starts
  238. Battery draining for past 8 months
  239. Trunk problems
  240. 60K Service....Need Advice
  241. Levelling Flashing
  242. Back to Basics - P0500 Vehicle Speed Sensor
  243. to woody69
  244. Hook up to twilight sentinel?
  245. 98 Catera oil leak
  246. opinions
  247. Cadillac Mechanics, Supremo's, Forum Owners and psychics - help plz
  248. Heater Water Pump & Radio
  249. Before I have a breakdown - HELP - Trac/Speedo and whats this?
  250. Electric water pumps. Need help locating.
