View Full Version : Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19
  1. Catera Engine
  2. Hoses on back of Plenum
  3. alternative xenon/hid projector bulb? $200 for OEM is STEEP!
  4. Timing Belt Replacement(98 Catera)
  5. Power Steering Pump Replacement (98 Catera)
  6. Catera knocking issues...
  7. Chrome B Pillars
  8. mrduncan2k
  9. Help... dealer stumped
  10. Coolant leak at recharge stem,....
  11. 97 catera parting out
  12. Power steering (PS) issue
  13. Coolant Light
  14. Cabin Air Filter?
  15. Dash Airbag Readiness Light?!
  16. Catera...One Fine Automobile...
  17. Eaton Supercharger on 3.0L
  18. Oil leaks and coolant leaks !!!!!
  19. SAE seal on Taillights?
  20. Weak air flow from vents
  21. gas gauge problem
  22. Rear Window regulator
  23. heater water valve hoses
  24. 98 Catera brake light switch
  25. I actually like my Catera
  26. New member same 'ol questions
  27. 01Catera At the Dealer
  28. coolant bridge
  29. Is this the tensioner?
  30. 1998 Catera High Oil Pressure
  31. Catera Swap
  32. Calling All Cars, Need Help Ref. Engine Swap
  33. Seeking Advice for First-Timer Timing Belt Change
  34. parting 97 cat
  35. motor mount number catera 3.0
  36. Help With Cadillac Catera 98...
  37. CD player for Catera?
  38. looking for a license plate cover for 2000
  39. This Catera gave its all in a crash.
  40. Opel Astra SRi Wheels on my CATERA
  41. Key Ignition
  42. Serpentine or accessories belt and tensionner replacement
  43. cranks but won't start
  44. 2000 Catera brake light problem
  45. Catera transmission rebuild $?
  46. Bushing found in transmission pan of 1997 Catera
  47. how do I chech for exaust in antifreeze?
  48. Timing Belt Change
  49. Daytime Running Lights
  50. 98 Catera Suspension
  51. 1999 Catera Service Manuals for sale
  52. drivetrain mounts
  53. Tie Rod Ends
  54. Throttle Control System, need help...
  55. Low mile catera parts on e bay
  56. Coolent level drops!!
  57. Diagnostic Mode
  58. I've been offered a free '82 Cimarron ...
  59. catera wanted
  60. brake pad sensor
  61. traction control always on????
  62. catera engine options
  63. Noisy Lifters?
  64. Front Bumper Cover Replacement
  65. remove inner door fascias
  66. sporadic "dead" brake pedal?
  67. 2000 catera : sport mode flashing , starting off in 3rd gear
  68. #3 Cylinder misfires,sometimes really bad.
  69. Fuse panel cover!
  70. Looking for a Catera Repair Book
  71. Take Catera to SAAB dealer?
  72. Arming the car and radios in car
  73. What does this error code mean?
  74. Question about oil pressure?
  75. A/C compressor puller
  76. Trunk / gas door release
  77. Transmission leak
  78. FYI: Rock Auto's Timing Belt Component Kit.
  79. 2001 Catera
  80. Well it is at the Dealer
  81. Another Catera Glitch.....
  82. My Cat Lives Again!
  83. 1997 Catera just loses power while driving
  84. Minor Setback
  85. GTO Brake SWAP LOG.
  86. Check Engine Light
  87. is the cateral instrument panel a "sealed" unit
  88. rough idle
  89. estimate for ignition coils
  90. Coolant change
  91. power rear sunshade assembly
  92. Timing Belt Recall kit...
  93. Cat engine over-heating prevents restarting
  94. catera/omega elite ecu managment
  95. Catera blues
  96. Power outlet for catera???
  97. Do you think it was worth the $141.00?
  98. Coolant Crossover Assembly
  99. 19" Chrome Wheels
  100. oil gauge / oil sender
  101. Strange Pop during Braking
  102. How often should a Timing Belt be changed in Cateras?
  103. it's fixed
  104. Catera with 161,000 Miles...how much of a gamble?
  105. 1997 Catera Insturment cluster lights
  106. has anyone here replaced outer Tie Rods or Idler Arm?
  107. Cadillac Catera Steinmetz badly accelerates
  108. I love my Cat but I have 8 codes!!!!!!!!!!!
  109. the steering wheel and shift knob vibrate over 60mph.
  110. After-market Air Intakes (on ebay).
  111. Catera OEM Injectors size+ ECU pinout
  112. is this a normal temp???
  113. Catera outside air temp help
  114. Oil Filters
  115. Ball Joints
  116. Negative camber killing my tires
  117. 98 catera for $600?
  118. Recharging Ac
  119. What is the "snowflake" button I see in my Catera?
  120. 1998 Catera no start w/new cps installed help!!
  121. sounds like a vacume ?
  122. Can I remove the ETBCM and still drive the car?
  123. Hood jammed
  124. AC compressor clutch kicks but dies
  125. Trouble code after head gaskets
  126. frank moran - miss fire
  127. Wanting a second opinion
  128. Taillights
  129. Battery going dead!!! help
  130. Turn Signal Glitch
  131. FS: Catera spoiler
  132. 97 Catera won't start after mechanics worked on a cooling problem...
  133. hazaed switch turns power on
  134. 1997-1999 Catera Fog Lamps - NEW!
  135. 98 Catera, trans shifts firm 2-3 and doesn't want to shift cold
  136. Spark Plugs
  137. Show us your CATERA (OMEGA) !!!
  138. Noisy Glove box
  139. 1997 Catera with Engine Code P1700 Help!!!
  140. Where to buy headlight capsules for 98
  141. Online Parts
  142. tinting the catera
  143. looking at buying one
  144. Turn signals acting weird
  145. Tune up specs & torque specs
  146. Catera Capacities
  147. GM recall 02041 - cam belt info
  148. question???
  149. Aux water pumps
  150. GTO Wing for the Trunk... PICs
  151. Starting Problems
  152. Where to get water crossover Banjo bolt
  153. programming keyless entry
  154. just got ScanGauge 2
  155. 97 Catera Knock Sensor problems
  156. Speedo reads low
  157. Just ordered my hood lift support replacements
  158. Loosening screws from plastic
  159. removal of my car stereo
  160. hvac
  161. Fuel Door Hinge
  162. Spark Plugs
  163. gaskets
  164. confused ....
  165. alc relay
  166. Changing Out Transmission Control Module
  167. white black wall paint
  168. This is where I purchased my Factory Manuals
  169. EURO Conversion Front End Complete
  170. Make your catera look nicer for 7 bucks (Painted Calipers)
  171. 3.0L potential
  172. It's tire time.
  173. '99 Catera Sport Wheel Lock
  174. air
  175. Extra Parts; Fog , Relays , Heater core and Control Valve
  176. a/c blows warmer on driver's side...help?
  177. A/C Compressor
  178. changing valvae coner gaskets
  179. does your catera spin the tires?
  180. AC Performance ?
  181. Muffler Question
  182. Are all Catera engines the same?
  183. Flashing "S" light
  184. trouble with secondary air injection!
  185. I can only look at my Catera
  186. Best Coolant?
  187. Emergency Brake
  188. URGENT need for J42069
  189. Leveling
  190. relays
  191. ticking behind dash
  192. U2106 - Lost Comm with Trans Control System
  193. *Few Good Qs!*
  194. Custom radio installation
  195. Belt Replacement: Your Opinion
  196. Relay Removal
  197. Vibration Problems
  198. Class Action Law Suit against Cadillac for the Catera!
  199. Safe Jacking Locations
  200. power steering problem
  201. Cadillac License Plate Frames - Forum Discount
  202. 1997 Catera AutoTransmission stop working
  203. heat in cat
  204. Coolant leak, for those keeping track
  205. air filter housing clips???
  206. Rearview Mirror Removal
  207. A/C Not Cold have u tried this?
  208. coolant fan test connector fan control for catera
  209. what used to be in my drivers door pocket
  210. Cadillac License Frames - Forum Discount Code
  211. Low oil pressure. ANY IDEA WHY?
  212. cooling fan not running
  213. CD player states "cd error" after warms up
  214. Engine lifters
  215. PO154 Bank 2 sensor 1
  216. Rear air suspension to standard strut conversion
  217. 98 Catera Arm Rest (Console Lid)
  218. auxiliary water heater pump part number
  219. $500 x 4 for O2 sensors from the dealer?
  220. Catera SPORT Wheels 17"x7.5 5x110, PIRELLI P6
  221. Diagnostic mode?
  222. When AC on what makes it eat up rpms
  223. Acetone
  224. What kind of oil does everyone use?
  225. Tire Recommendation
  226. Got a 99' Sports Catera
  227. Shudder in steering wheel while braking
  228. Brake switch replacement, Catera
  229. lost keys!!!????help!!
  230. how imbarassedi would be/?
  231. How much to pay for a 01' Cateria with 50K?
  232. Take an Omega, add a Lexus Turbo V8.........
  233. Resetting Heater
  234. Exhust resonator needed,
  235. recall only for specific VIN ?
  236. Are There Any recalls on the CATERA?
  237. Need Help w/ Catera Recall Fast
  238. In Need Of Some Guidence
  239. Ever tried this product? Engine Restorer
  240. just bought the catera
  241. Thinking about parting out 1997
  242. Any one have
  243. 97 Catera in for a 3.2?
  244. Ball Joint
  245. Replacement Remote for 98 Catera
  246. ABS Failures
  247. Show us those GRILLS!!!
  248. coolent leak
  249. Want Colder Air to your Intake? Try This!!
  250. Greetings, Jalopnik readers!
