- fix the EBTCM yourself? Is it possible?
- Accident
- Might... be leaving the group
- Drove an 04 6 speed GTO Today!
- What with this car????
- How do I get out of "park" ?
- problems with front suspension
- engine cranks but doesn't start...very random and not CPS
- Ignition Coil Replacement
- Need Help locating AIR valve
- Climate Control all messed up
- does the temp gauge have its own fuse?
- What is the different between suspension in regular cat and the cat sport?
- relocate factory stereo to trunk??
- proceedure for removing the heater core?
- Where to buy
- power windows express up or down does not work
- 1998 catera part number
- Bad Ecm
- 2000 Catera electrical issues
- to Franki Moran, Satse, Peetyz, and everyone that helped.
- Wheel Emblems needed
- drain power steering fluid?
- catera engine replacement pull or drop?
- K&N Air Filter for Catera - Cheap
- coolant problem?
- Bubbling Noise After Coolant Flush
- TCM Question
- Do Catera owners like the Pontiac G8?
- Catera Project... MAJOR ISSUE! HELP!
- Please Name this part/valve
- Sub Frame Bolts --Missing
- Quick crankcase breather ?
- Can SOMEONE Tell me what is wrong?
- Can't wait!!!
- 97 Catera Ashtray
- 98 Catera
- Differences in BRAKES b/n Pre-Post Facelift.
- Brakes: Pads and rotors
- dahboard lights out
- break pads replacement
- 60,000 Miles
- Fuel Door Hinge and Filler (Gas Cap)
- Module Master
- Problems
- Drove my Catera in first snow dump. TC question...??
- catera coolent leak drivers side front?!
- Engine mounts where to buy
- Steering box harness
- Milky Oil Cap
- NEED ADVICE - Should I buy a 2000?
- Cracked caliper What now?
- 99 catera wiper blade replacement
- irmscher body parts shipped to us
- Has anyone experienced an EVAP leak at the Solenoid box?
- 1997 Catera
- Irmscher & Steinmetz on eBay/Germany
- forgot my key in my catera
- Transmission Shift Quality
- WTB: Catera, maybe even one with issues
- 3800 Supercharged V6 in a Catera
- alarm problem
- Check Engine Light! Code Retrieved!
- 1998-2001 Interior
- Crankshaft Position sensor Re-learning By Dealer
- battery "water" frozen?
- Direct injection Catera?
- Catera wont start
- My Engine Is Smoking Helpp
- fuel injector replacements?
- From Catera to Irmscher <OMEGA>
- Catera HID Bulb!??
- 99 Catera Blowing Cold Air on Driver's Side
- GEN III 5.7 V8 Engine Management PDF
- Rebuilt EBTCM still no speedo
- 01 Catera Sport Parts
- 98 catera help
- Alternator removal help, please.
- Control arm bushing question
- need help figuring out what the problem is
- Let the Blasting Begin
- bleeding cooling system?
- I used Bar's leaks
- what is switch under brake light switch-need help fast!
- OIL Leak
- Rebuilt Ebtcm Installed
- Oil Cooler Bypass Information Request
- catera ecm replacement
- I am concidering going with a catera
- Help plz!
- HID Fog DIY/FAQ (BiXenons)
- cooling fan not working
- Third Brake Light Writeup?
- Mechanic in Toronto area
- Catera V8 by Lucky Cowboy
- TCS activates and light flashes while cruising
- Rebuilt EBTCM
- 1999 Catera Starts, Runs For A Couple Minutes And Shuts Down
- Check Engine Light-Evap Code....Help
- 02 Sensor question and problems p0133 p0154
- What Fuses Goes In The Power Distribution Fuse Block
- Crankshaft Position Sensor
- How do you get to lights in dash?
- Wheel center caps?
- does not have any electrical function
- motor oil
- Toronto Area Catera Owners?
- Oil Pump priming
- Catera Questions
- HID kits
- Original Paint
- Idle Arm FIX
- Free rear seat for 1997 Catera
- 1997 Cat Gas Problems Knocking
- 2000 catera on ebay
- for those with CTS's.....
- whats the story w aftermarket cd players?
- Bought a 2000 Catera. Tips?
- 97 Black Catera new grill
- HID Bulbs
- Catera ignition key insight?
- Oil Filter
- Coolant Leak...Suggestions
- Transmission issues
- Just needed to wallow
- Help! All dash lights on and no gauges, Catera
- catera gone saturday
- 98 catera strut for sale
- 98 catera strut on ebay
- Engine gasket kit ?
- Rebuilding the Catera V6 For More Power
- Considering a Catera purchase, soliciting advice
- Craqzy Rear Wheel Camber...
- Supercharged V6
- 20s for sale
- Big Problems...
- 98 Catera "push to shift" and power lock problem
- projector wiring help
- after market cd player install kit
- 22s again
- 150K miles. Time for some repairs.
- scratch on chrome
- 97 Catera
- mass airflow PO101
- coolant leak
- gas tank dent removal, ideas?
- Catera Headlights
- Catera Locking Wheel Bolts
- Hid
- TC and ABS lights
- Merry Christmas
- Catera Broke
- Radio, inside lights only work when car is off
- oil pressure light
- 97 catera ignition problem
- Stupid Dealer
- Help! Problems in DC Area
- aftermarket deck advice
- loosing coolant
- Compilation Video
- WTB cat with bad motor
- GM 4L30-E, Superior Shift Correction Kit (M-S24165E)
- Opel Omega.Catera 2.5DTI DIESEL
- About to purchase 2001 Catera Sport..Thoughts please?
- catera leaks COLD coolant from top rear of engine
- SRS Light on-Never been in accident
- How hard to do valve cover gaskets?
- Might not have seen
- More Steinmetz Details
- help with parts
- EBTCM still not working
- Need part numbers
- cd changer
- 2008 Cadillac Calendar Voting
- Cat travelled distance
- 2JZ-GTE 3000 24V I6 Supra Motor in a Catera/Omega
- 2001 Catera won't idle properly
- Tranny light fixed...FINALLY!!
- Lower Control Arm Bushings
- Radio locked out and power options not working after battery replacement
- Heat not blowing hot enough air!
- ABS&TCS lights on and no speedometer-What gives?
- 18 Inch rims for sale
- Transmission Fluid Change
- Winter Pictures of my CATERA MV6
- I need your advice...again...
- One messed up CATERA
- What could be the problem?
- coolant leak - drivers side
- Hi beams don't work? Help!
- What are the brightest blubs for a 99 Cat
- 97 Catera Tune-Up
- first drive in snow with 2000 Catera Sport
- help....
- Another timing belt question- need some advice
- Selling Catera.
- Nexen Tires: N5000
- Oil indicator = codes ?
- P0134,P0153,P0455 codes
- Missfire help pls
- Catera Tranny problem - P0740
- Sold my Catera Yesterday
- Steering Wheel Vibration ***Please Help***
- Coolant Now Leaking!
- temperature gauge going crazy!!
- Coolant Light?
- Dash lights & MAF Meter
- carfax sucks
- air bag warning stickers
- Levelling light steady on
- 99 Catera head gasket?
- v8 conversion kit on ebay?!?!
- gauge and length
- Weird thing happened when I bought new keys
- May sell my Cat
- 1998 Catera EBCM
- Cigarette Lighter...?
- Mystery Omega Caravan
- 1984 Cimarron custom Grill
- Catera steering$$$$$
- Any way to get the Catera cooling fans to come on earlier?
- fender ports
- oil sploch on cam cover
- 1999 Opel omega mv6
- Weird Burning Smell: Update
- Driver Side Coolant Leak
- Coolant Smell
- Radio and accessory power
- Shift lever handle
- Brake possibilities…
- 99' Catera Remote Start
- anyone wanting stock wheels?
- Pulled multiple codes on 97 Cat (ignition, temp sensor etc.)
- oil temp VIDEO
- Does 98 Catera have an independent transmission fluid cooler?
- casino cash?
- Rebuilt Front end but...
- Where to buy.....
- shifting
- Cadillac Forums: Any One In Denver Colorado Area?
- Water Leak Passenger Side???
- Low Oil Pressure
- Cadillac Forums: Update-coolant Leak Under My Car--
- Cadillac Forums: Ideas To Make Car Run Cooler
- air bag lite stays on in 97 catera
- anyone tried running a small shot in our cars?
- cylinder and lifters
- Oil Pressure Problems
- flushing heater core. Need help
