View Full Version : Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Another Cat Up For the Ls Swap?
  2. Lightening up the load
  3. Replacement O2 sensors
  4. Mive Gtg
  5. valve cover gasket change
  6. 1999 Catera serpentine belt replacement?
  7. Need Help With Vacuum Hose Layout
  8. radio wiring colors
  9. Catera Oil Leak - Engine oil or tranny oil
  10. radiator fans
  11. Check Engine Light
  12. Heater Actuator?????
  13. Slick 50?
  14. Coolant Sensor
  15. need advice on brands
  16. dash backlights intermitttently turn off/on
  17. Suspension 99 Cat
  18. Vibration when braking
  19. High RPM idle
  20. Blown Head Gasket? Or something else?
  21. Classic Cadillac - Custom Floor Mats
  22. Rough Idle (w/videos and pictures)
  23. Scan Gauge
  24. Cross-Drilled/Slotted Rotors
  25. coolant light
  26. water leaking inside passage side?????
  27. clock is resetting itself on 98 catera
  28. Heater motor control
  29. 2000 Catera Check engine code "P0411"
  30. oil leak
  31. Thermostat
  32. '99 Cat - coolant goes quick, no leak evidence
  33. Oil Light on
  34. No Ac
  35. Tech II Via Laptop?
  36. Catera vs. Saab
  37. Auxilary Water Pump
  38. starting in sport mode
  39. water pump....
  40. Dexron VI or MD-3 as a replacement for Dex II ?
  41. car pulls when breaking
  42. Bump steer!!!
  43. cross drilled rotors
  44. Who Thanks The Catera Is Junk
  45. Parts for 1997 Catera
  46. catera exhausts/mufflers
  47. Truck Lettering for 1997 Catera
  48. winshields were automatic.
  49. Heater core gone south
  50. My Catera Photoshoot... Cleand and Debadged (V6Emblem)
  51. Tempature sender wire connection
  52. My New Catera - pictures :-))!!
  53. oil pan gasket
  54. manual swap
  55. MIL request circuit fault
  56. Transmission range censor or EMC
  57. 1998 Catera-Please help
  58. Heated seats don't work
  59. Suspension problems
  60. MAF Sensors Purpose
  61. air bag light on?
  62. Oil presure problems...
  63. Pittsburgh mechanics?
  64. ABS/Traction control light
  65. Thermostat Replacement
  66. Catera '99: Trunk lid not closing and Bose radio problems
  67. Questions about the cooling system?
  68. Fast Idle
  69. Cooling Questions
  70. Catera Grill
  71. Bose Stereo Conversion
  72. Catera thermostat? Radiator? What?
  73. ashtray light bulb?
  74. 2000 catera bose radio problem
  75. catera - questions before I buy
  76. Starter 97 catera
  77. Missing on 2,4,6 need help please,99 Cat
  78. Oil cooler major FUBAR!
  79. odd idle
  80. Good reason to replace your fuel filter...
  81. 98 Catera Procedure to Drop Fuel Tank
  82. catera vibration
  83. shifting
  84. need help decideing a body kit
  85. Shifter lever is stuck! Please help
  86. goodbye Catera
  87. My Poor Cat,.....
  88. 97 Catera - suddenly wont start
  89. ? about my catera. please read! HELP!
  90. new cadillac catera!!!
  91. $450 Shocks??? I Think Not..
  92. catera heater blower won't shut off
  93. Bose for free
  94. 99 Catera Error Code P0455
  95. 99 Catera Error Code P0455
  96. Rear Trunk Lid
  97. Show us your Catera.
  98. Catera - Known issues, common questions. CLICK HERE FIRST!
  99. O2 sensor queston
  100. Help with Oil Filter Caniser
  101. Grille Mod - Red Stripe...
  102. catera purge
  103. A THUNK noise from the glovebox area when I start the car?
  104. 1998 Catera Cylinder 1 misfire
  105. 1999 Catera Sport??? Huh??
  106. rear tie rod ends?
  107. Catera cuts out
  108. Catera Fantasy Project.
  109. About to give up: Smoke, low oil pressure...ARGHHH
  110. What is the deal with my starting system?!?
  111. Trans Fluid
  112. Monroe's 99
  113. what is this?
  114. Need Catera Part Number
  115. 2000 Catera Sport
  116. Traction Control wont turn off.
  117. Which Starter and Starter Solenoid terminals do I jump together to start engine?
  118. Button next to fan control
  119. New Tires Continental ContiExtremes... 245s
  120. Coolant leak could it be head gasket or hcv?
  121. Some what newbie showing off my CAT
  122. weird steering problem
  123. Aftermarket Suspension Bushings
  124. 2000 Catera Sport CEL
  125. came accross a catera today...
  126. tire advice
  127. Interior Lights Not Working On 97 Catera
  128. Custom DRLs
  129. intermittent Cruise Control Problem
  130. Help
  131. Ignition Coil Issue
  132. Anyone have good engine mount?
  133. Code P0412
  134. 110,000 miles they die???
  135. 2000 catera turning signal problems....
  136. 98 catera 3.2 or 3.6 swap help / info
  137. 97 Catera Electrical Problems
  138. eBay Astra Wheels 18s - 1K
  139. Head Gasket Fix Products???
  140. Radio, fuel door, trunk down, still down after changed mulitfuntion module!!
  141. Make your own
  142. Malibu
  143. only half of rear brake light lights
  144. Catera For Sale!!! Excellent shape! Great price!
  145. 98 catera parts search
  146. 200 Catera window regulator
  147. head light problems
  148. Plug Wires
  149. Suspension Issue
  150. Catera - CTS comparison
  151. WTB: In-trunk CD changer
  152. Oil Cooler Pics: Is it leaking?!?
  153. Sticky caliper anyone know of any frnt GTO brakes for sale?
  154. 2001 Catera Fog Lamp Problem
  155. Mystery Coolant Leak
  156. New Catera Owner, have a few ?'s
  157. EBTCM Question
  158. catera interia floor carpet
  159. need some help
  160. tires and rims...
  161. Wanted: Air intake thing
  162. 99 Cat hesitates on accel.; idles rough
  163. Hi...New here. Have a few ?'s.
  164. who wants a 1999 catera for parts
  165. Catera A/C Compressor
  166. 1997 catera instument cluster removal,anyone know how it comes out?
  167. Smog-Air Pump Squellllll
  168. 2ooo Catera Radio/CD shut off.
  169. diagnostic code PE108
  170. E-Brake Part Number? Gto Front Struts?
  171. ATL Tornado/Storm owns Catera
  172. LED Bulb Conversion
  173. Catera front door panel
  174. Oil Leak
  175. Engine Noise under stress
  176. Looking At 98 Catera
  177. Resetting Computer - Methods?
  178. Heater/ac Problem Please Help!
  179. The Catera Forum
  180. Drill and slotted rotors?
  181. Holden Concept Car. The Next GTO??
  182. White stuff Under Oil Cap
  183. catera swaping
  184. some good links
  185. This guy is smoking something GOOD
  186. 2001 Catera Transmision sport mode flashing
  187. Got The Gto,sold the Catera Miss it
  188. Winter in Buffalo
  189. VIN numbers
  190. 98 catera blower motor inop,a/c clutch inop
  191. Ward
  192. head light de-hazing
  193. Help--Oil Cooler Problems
  194. 2000 catera strut mount replacement
  195. 2000 catera turn signal flasher issue
  196. One Year in the Making...
  197. Catera Won't Start
  198. Leaving group, thanks to all!
  199. 97 Catera coil problem
  200. Just showing off my cat...
  201. Some helpfull info I found for after you reconnect your battery.
  202. Oil on Plugs / Misfire After Valve Cover Replacement
  203. Brake Pad Indicator
  204. Camshaft bolts ??
  205. Removing fuel from tank
  206. Secondary Air Pump
  207. quick instrument cluster question
  208. 97 Catera that is being parted
  209. 2000 catera transmission issue 80k miles
  210. Pics of my GTO to be (hopefully)
  211. 2 Cateras for parts
  212. Selling the catera =( i must to get GTO read
  213. 4 Fast 4 Furious. Detroit Drift... PREVIEW
  214. 97 Catera, trunk deck brake lights
  215. Anyone Selling a Catera?
  216. Lug Bolts
  217. Steering Groan
  218. Turn Signal Bulb Upgrade...
  219. Just another bogus chip?
  220. Flashing (Sport) symbol on Dash (HELP)
  221. headlight switch replacement
  222. Valve Cover Gasket Change - Parts Needed?
  223. Headlight Assembly Removal on 1999 Catera
  224. aftermarket stereo install for 00-01 Catera
  225. rock auto discount code
  226. Help with long distance trouble shooting
  227. Catera Meet, greet, fix and upgrade
  228. To: CateraMV6
  229. Timing Belt Change
  230. STICKY: V6 CATERA S Photo Archive...
  231. STICKY: V8 OMEGA Photo Archive...
  232. 1999 Catera
  233. EBTCM removed... Now what?
  234. Engine Removal
  235. rough idle to stall
  236. Euro-style Grille
  237. Look V8 conversion kit on ebay
  238. 2000 Catera wont go in PArk!
  239. Radio cuts off and on!
  240. No heat on passenger side!!!!
  241. another performance chip question.
  242. Alarm activates with wipers
  243. Looking to buy a Catera
  244. random multi cylender misfire?
  245. Radio and Climate Control Problems!
  246. wondering what it would cost for a dent to come out of the door...
  247. no heat from rear vents
  248. dash lights
  249. Strut Tower Bars
  250. e brake cover, bose enhancement and me
