View Full Version : Cadillac Catera and Cimarron Forum
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Could use some help locating Cimarron parts
  2. I Seen It !
  3. Serpentine belt and tensioner?
  4. radiator fans
  5. Check engine codes....Help ASAP!!!
  6. catera amplifer stock & aftermarket
  7. Post your LOWERED Catera!
  8. Message from Elvin315
  9. Questions about Serpentine Belt/Tensioner replacement
  10. no climate control lights after stereo install
  11. Broken Oil Canister Mount
  12. Catera featured in TV advertisement
  13. Craigslist find
  14. Bose's works, but no display, advice?
  15. air pump ?
  16. Tip for Checking / Toping Off Transmission Fluid
  17. catera factory alarm
  18. 3.2 swap and 0411 code
  19. Headlights Bulbs
  20. 98 catera pics!!!
  21. Need Hood for 1999 Catera
  22. New bulbs in rear taillights and still ones brighter ??
  23. A message for INCONNU or anyone else willing to help
  24. Heat Issue, Coolant Smell, No Leaks
  25. Oil filter housing fixed !
  26. fast idle 2001 catera
  27. Idle air control 01 catera?
  28. Transmission Clunk Noise /Troubleshooting
  29. Steering Wheel & Shifter Arm Shakes When Braking
  30. New Battery..Sunroof Won't Open????
  31. Used Catera Parts?
  32. Radiator replacement
  33. GTO Front and Rear Springs Upgrade...
  34. My new Headlights
  35. Water4Gas HHO?
  36. Changing oil housing to conventional filter
  37. 97 Manuals & Timing kit for sale
  38. 2001 catera throttle body
  39. I think my cat might be done
  40. well i knew it couldnt be this simple
  41. Engine Coolant Temp.Gage
  42. Water Pump Replacement
  43. Pass side fan stays on after shut down
  44. finally she is home!!
  45. Center Link Bar/stabilizer 98 Catera
  46. Quick question?
  47. dexcool vs conventional?
  48. Bulb replacement in climate control unit.....2001 catera
  49. L read window off- track
  50. Headlight question
  51. Installing aftermarket cd player
  52. 1997 Cadillac Catera
  53. New engine
  54. Oil Filter Housing Problem
  55. 2001 throttle body?
  56. A/C troubleshooting
  57. !!! Motor OIL Discussion!!!
  58. 2000 Catera Trunk and Gas door problem
  59. 1997 Cadillac Catera electrical problem
  60. German Black Mesh Sport Grill
  61. No crank please help.!!!
  62. How to disable the leveling system?
  63. Oil Leaks
  64. changed HCV and that wasn't the problem.
  65. 98 catera oil pressure question
  66. Catera Parking Brake Boot Needed
  67. 1988 Cimarron Fasten Seat Belt Light
  68. Rear Door Panel Removal- 2000 Catera
  69. how to find engine year
  70. well i went digging in!!
  71. Speaker covers loose
  72. How to Replace Brake Light Switch 1998 Cadillac Catera
  73. Mechanic needed.
  74. Discussion on EXHAUST!
  75. weird ac/heat problem?
  76. plug/dust cover for hole in flywheel cover?
  77. Discussion on SEATS!
  78. need info: catera transmission part#? not the model#!
  79. Red Line
  80. problem shifting out of park
  81. NO A/C and Headlights at the same time!
  82. 98 catera A/C problem...
  83. any one here tried using seafoam in their cat?
  84. please clear this up if you can
  85. Adding transmission fluid 98 catera
  86. cat runs much hotter with A/C on
  87. Help! Coolant Leak, the normals all checked...
  88. Instrument Panel Problem
  89. a/c pressure settings on 97 catera
  90. My keys are locked in my car :(
  91. P1701 Code Check Engine Light
  92. How Is the Rearview Mirror Removed?
  93. Rear Sunshade Stuck Up
  94. Clunking from Front End, Vibration at Speed
  95. Climate Control Won't Control on Auto
  96. What in the World!
  97. FORD Employee Car Show!
  98. Vents blow hot air after AC
  99. 99 Cadillac Catera Oil Light
  100. Help with Bose (help Cadillacsts2003!)
  101. Where is the Key Fob transmitter on the vehicle?
  102. blissful silence... >>>
  103. When was the last CIMARRON thread here?
  104. 2001 Catera tune up
  105. Tire Size Question
  106. MAF sensor for 2001 catera
  107. Bose stereo
  108. Radio Antenna?
  109. 2001 Catera, throttle body part number?
  110. Hey Elvin, Crankshaft Position Sensor
  111. Changed thermostat now cat won't start PLEASE HELP
  112. Need help Quick * changing thermostat
  113. Catera Idles Shuts Down after giving it Gas
  114. Vacuum leak!!!
  115. Catera accelerating!!!
  116. Cat Fuel Lines.
  117. Throttle position sensor
  118. Catera Engine Shuts Down While Driving
  119. transmission flush or just change filter and fluid?
  120. Check engine light...2001 Catera
  121. Some Quick Suspension Advice, Please
  122. stabalizer link torque rating help
  123. A.C. not working?
  124. Please please please help!!!!
  125. Car does not crank...
  126. 99 - Which timing belt kit
  127. dashboard
  128. ABS/TC module.
  129. parting out a 2000 sport
  130. Abs and traction control light on with now working speedo
  131. need a source for a new rear axle assembly, 2001 catera sport >>>
  132. What side is Bank 1 for O2's?
  133. replacement shocks
  134. oil light problem
  135. HELP!!! Heater Control Valve
  136. Cooling Fan Operation
  137. 99 Catera Owner Needs Serious Advice
  138. Air conditioner blowing hot
  139. Lights flickering
  140. 2001 Catera...starting problems!!!
  141. 2000 Catera trans problem
  142. Replacing bose deck.. :S
  143. I Want To Sell My Catera, Pls Hlp
  144. Another Photoshoot.
  145. New Upgrade! Can spot it?
  146. 97 Catera Transponder Problem
  147. Bose stereo removal and install
  148. Another Sunroof Question...
  149. interior door panel fix?
  150. Who own's a cat in North Carolina
  151. valve cover bolt stripped
  152. Blowing Fuse ----- Controls?
  153. fel-pro gasket sets for valve covers and intake
  154. what do ya think ;-)
  155. coolant bridge banjo bolt seals
  156. steering module red?
  157. Sunroof not opening
  158. Installation Manual for Parts on Catera
  159. New UPGRADE! EYE LIDS.
  160. simple question: SHOULD I GET ONE?
  161. P0411
  162. Drag racing a Cat, any tips, post times
  163. P0700 Code?
  164. No more Onstar for Cateras.
  165. MW 1997 Cadillac Catera Road Test
  166. Oil cooler plate hole
  167. a/c compressor not engaging.....HELP!!!
  168. Coolent leak..help?
  169. code PO650
  170. Failure to Launch
  171. '01 Catera- Check Engine Light - good tech in 60016
  172. Need Help Before This Weekend!!!!!
  173. Charging/Electrical Issue
  174. Get GTO Upgrades For Your Catera - Cheap!
  175. New from Holland !
  176. Upgrades: Custom parts
  177. What is this? PICS INSIDE!!
  178. Programming RDS?
  179. Urgent Help Pls! Disconnected Tube!
  180. stabalizer link question
  181. Sluggish Acceleration/Idling
  182. custom mods on the catera!
  183. Oil Cooler failure/busted radiator
  184. need help identifying vacuum part
  185. cooler adapter
  186. '01 transmission or electrical issue?
  187. Heat Wave Car won't turn over
  188. more coolant leaking
  189. HHR or G6 wheels
  190. Things you've found in your Car
  191. Begining To Hate My Cat
  192. Center Caps
  193. *MY ISSUES* - Somebody shoot me.
  194. Need help Tranny problem 00 Cat Sport
  195. 1997 Catera Automatic Transmission Light
  196. Massive Coolant Leak
  197. 97 catera AC freeon leak
  198. Temp Gauge
  199. Ignition
  200. Cost to get AC fixed
  201. Has all electrical but Won't start when hot
  202. Replaced Rotors - Bad Brakes!
  203. Outside Air Temperature Display
  204. wheel hub remover/installer tool rental '97 cat
  205. Radio, Door lock, and Fan
  206. Drunk Driver
  207. Secondary Air Injection Question
  208. Security(Theft-Deterrent) System
  209. A/C Orifice Tube
  210. Oil Filter 'upgrade'
  211. 00 Catera Sport Fuel Odor
  212. CUSTOM SPEEDO GAUGES!!! German Made!
  213. Catera Cooling System Needs Work..HELP!
  214. Replacing Serpentine Belt
  215. Help-Car filling up with water
  216. More Dual Piston Calipers on the LS1GTO Forum
  217. 1997 Catera questions
  218. Question about rear brakes
  219. emission problems
  220. catera....need help and advise ASAP!!!
  221. 3.2 cts engine coversion
  222. it finally happened to me
  223. Catera Overheating...
  224. Ball Joint boots for '97 Cat
  225. diagnosis help: junkety sounding engine on cold starts, goes away after warmup >>>
  226. Weird whistling sound at startup
  227. Front Lisence Plate Gap Filler..Thing
  228. Got a question
  229. Catera and Gto Front End
  230. GM 3.0 (L81) V6 in a Lotus Exige
  231. a/c questions
  232. What's mpg are you getting on your Catera?
  233. 2000 Catera will turn over but does not start
  234. Transmission Seems to be sticking when car first drives
  235. Catera REAR TIE ROD Assebly FOR SALE!
  236. Had to go...
  237. what is this part called
  238. Traction Control Light and ABS light
  239. 2009 Opel Insignia
  240. Fully Adjustable Air Spring Suspension
  241. Retrofit - Mods to Save $$$ and Gas
  242. Jack Locations
  243. Some More BLING BLING added to my car!
  244. Reversed HCV lines??
  245. catera P1511 low Boost Pressure
  246. Another Cat Up For the Ls Swap?
  247. Lightening up the load
  248. Replacement O2 sensors
  249. Mive Gtg
  250. valve cover gasket change
