- New to dohc engines
- Seat belt proble. need help ASAP
- need info for 99 Catera headlights
- Bobble Head suspension. ahh
- Heating Issue
- Catera Trunk Trim Plate
- Valve Cover Replacement
- Where's that Fuse
- Green gooooooo !!!!
- Need headlight lamp part
- Headlights 97-99 interchangable with 00-01?
- Noisy Lifters??
- Does this sound good? 2000 Catera
- How would one know???
- secondary air injection cut off valve.
- catera overheating
- timing belt
- Is your Cat as power hungry as mine?
- 5 hour Cad ownership and need help ASAP
- Look familiar?
- Lets Make It Easy
- Serpetine tensioner
- CPS and spark plug question on 98 catera
- Whaaaat?!?!?!?!?!
- Fog Lights
- left side dash light out
- Oil Leak and Wiper Problem
- cts/catera drive by wire or throttle cable
- Problems with 2000 Catera Sport
- New owner of a 99 Catera Sport
- running lights
- Engine cranks but then dies
- Whats the cost?
- !!!HID (owners) Clear Lense Upgrade!!! HOW TO
- Transmission Control Module Replacement
- coolant overflow
- 98 Catera won't crank
- 98 Catera starter?
- Bolt Pattern Fitment
- 1998 Catera Special Engine?
- Spark Plug Gap
- Severe Tramlining Follow-up—Problem Resolved
- manual access to trunk '99 Catera
- Catera 97 all the back lights dont work
- Code P1700 Gear Shift Ratio/ Transmission sticking problem/ PS not working
- Catera vs. Tree (the tree won)
- Oil Change?
- battery problems
- help! hood differences
- Is it possible to put a Northstar in a Cimarron?
- H.I.D Bulb Replacement
- This Cat is Finicky!!
- accessing '99 catera with dead battery
- Leveling Light Blinking
- replacing rear brake line and maybee spring
- parting out
- lifter knock? need advice!!
- 2001 Catara poor mileage, sunroof
- wont start
- Where to get exterior trim parts
- Locking lugnuts??
- Catera died
- 2001 Catera Error Codes 0171 0174
- Catera finally died
- 2000 Catera Horn Relay?
- Climate Ctrl ~ Outside Temp reads too high
- Some Questions
- Adjustment For Serpentine
- Small engine knock and low idle in park
- Help Me Jack This Cat!!
- I live in Rhode Island and I want a Cimarron!!
- Does anyone have a spare lug nut?
- Battery dying solved!
- 01 Catera, P0455 DTC Code
- re-appearing oil around valve cover bolts
- Heater actuator/air mix door location on 2001 Catera
- C5 Brake SWAP Log
- Blizzak WS-50s Snow Tires
- Hard shifting transmission when cold!
- 1998 Catera
- Coolant Temp Running Warmer than Normal, Help!
- Coolant dripping from oil pan plug
- Help needed quick - Need left and right headlamp assembly for '99 Catera
- window motors?
- Cadillac Catera and Cimarron - CUSTOM MADE FLOOR MATS
- help, 99 catera eratic idle in park
- tips for coolant pipe???
- Catera V8 LS1 project car for sale & last of Lingenfelter Catera/Omega parts
- can this motor be rebuilt ? with PICS of damage
- No Fuel or Spark
- Headlights question????
- Heater issue...
- Where does the oil cooler leak from??
- Not Seeing a Problem
- Dual Zone Problem
- Redline!!!
- Catera interior trim codes?
- Overheating
- Rear Air shocks to regular shocks?
- Oil Pressure Too High?
- Driver's Window Popping...?
- Engine Diagram help
- Extra key fobs
- What is this Part?
- Just looking for information
- Multi-Ram Vaccum Lines/Connections
- Problems changing thermostat. Aargh!!
- !!! 5 speed manual swap !!!
- Replacing hood struts
- :suspect:Few Questions about radio HU Replacement
- Code P0650 MIL ,Help
- question about dealer powertrain warranty
- 2nd problem of the day
- Problem of the day!
- Should I buy a Cimarron?
- Radio A Fuse and and Oil Cooler
- Oil filter Help!!
- Anyone tried manual conver. yet?
- beauty black catera for sale in the south east
- ENGINE Burning OIL Anyone?
- Valve Cover Gaskets - Uh Oh
- Anybody bought a OEM Bose radio off eBay?
- Simply Put Y'all Are Awesome
- Dash lights flickering!!!
- '99 with issue after issue, and still more...
- Where to purchase parts in Canada
- SEARCH 2001 catera frontgrill
- Pre-Facelift Projector Headlights?
- Check out this beauty
- New member from The Netherlands
- Recall notice 99
- Front Rotors
- I Need Some Convincing
- Occassional burnt-smell and white smoke from under hood pass-side, drives okay though
- Somebody got a cruise control deactivation switch they can spare? Goes on brake pedal
- Any Info on Sport Shifting Problems
- smoking mirror
- Selling my 97 Catera
- Electrical! FOG Light turning off?
- Stalling Catera
- New Member... with a few questions (long-winded)
- What Oil do you run in your Catera?
- Serp. Belt Adjustment?
- 98 catera lossing cooloent HELP!
- catera ss headers?
- New Cimarron thread!
- Catera Forum - a 'no-no'?
- DETROIT Dyno Day/MEET
- Funky heater problem
- Driver's Side Door locks no coming up all the way..
- Rear Driver's Side Floorboard Soaked...
- Got new Wheels ASA AR1s
- Oil pan plug and oil pan
- Coolant Problem need help?
- Oil Filter Leak
- Catera in Commericial for US Fidelis
- 2000 catera
- needs brakes light
- 02 sensor codes
- Brake light switch hard to get back in
- yet another no crank issue, please assist
- CD Changer eat CD'S
- Aux Water Pump
- My Local Caddy Dealer screws me again!
- Catera turn off
- No radio, lights and door lock
- shifting late in first
- Bose radio amplifier removal
- 98 Catera Battery Issue
- Rear Brake Calipers Bad?
- Catera floor mats - custom made for you
- How to and Help on replacing driver side strut !! Any help appreciated..Thanks
- Cat starts ok, runs rough until warms up
- Catera not cranking problem solved
- Catera Euro Headlights OFFER
- Peeling interior anyone? LOL
- muffler for the cat
- Source for Catera CD changer - GTO calipers
- oil pressure gage
- source for right-rear pass door ashtray?
- 1997 Catera not starting after Crankshaft Position Sensor replacement
- !!!FEATURES You found in your CATERA!!!
- Dashboard Temp needle doesnt move
- For everyone having trouble with there locks,radio,fuel door and trunk
- flywheel sourcing
- HELP: Changed Plugs/Wires Now I Have an Extra Hose???
- For All You Cimarron Collectors
- Third light rear deck
- Headlight Fuse
- GTO Calipers with C5 Brake Pads. OMEGA/CATERA
- Door lock fuse keeps blowing?
- engine cover
- '99 OIL GAUGE not working...
- Ignition Coils
- where to get multifunction module for my 2000 cat?
- shift release not working, trunk and fule release not working.
- I'm obsessed with this crazy Catera!
- radiator fan dont work?
- Need a master dirvers side window unit
- ignition switch issues
- multifuncton relay switch
- Water leaking in Drivers side front floor?
- Back in the Cat Forum
- Deciphering the P03xx series misfire codes - please help!?
- high speed fan not coming on
- Spark Plug Seal? Name!?
- that was a short lived ownership!
- Resonators/Muffler/Supertrapp
- Aftermarket Wheels on your Catera
- 99 Catera p171, p174, p442 DTC Codes
- Bucking/Stumble - HEEEEEEELP!
- PCV Valve
- really hot Catera
- Headlight Removal - HELP!
- Supercharger for 01 Catera
- nicks and scratches
- Cruise/Brake Lights Not Working?
- Performance chip, is this for real?
- Cadillac catera / cimarron - custom floor mats - custom made
- radiator fans
- battery charging??
- Parting out 2000 Catera Sport
- Will 98 catera engine fit 2000?
- Finished Painted Brakes!
- Sunroof and Stereo quit at once
- Tires
- All dash bulbs work except Oil pressure and Battery
- WTB: Rear Rotors, Calipers, Pads for 1997 Catera
- 98 Catera for sale cheap
- Slow Leak
- Fuel and truck release not working.
- ignition switch????
- electrical problem????
- alternator needs replacing
- trip to mexico in my cadillac catera 98 in december!
- Sell Outright Or Parts It Out To You
- Head gasket failed
- finally my god!!!!
- Trunk Mount Brake Light
- Catera..... Need help!!!
- how to wire amp, sub and loc
- Battery Drain
- Hooked battery cables up backwards.
- guess what I did to my car =(
- well my baby's gone
- Car thinks all gears below Drive do not exist
- Sport Suspension
- Rear Right window mounts broke...Need Help
- Cat Downshifting by itself
- Thanks TitanCTS/INCONNU
