: Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28
  1. Change Automatic Transmission Fluid?
  2. Led Center Brake Light
  3. 1997 Catera Questions
  4. Catera 2000 CD upgrade
  5. Can the engine and tranny be installed together?
  6. 2000 Cadillac Catera
  7. New Headlights
  8. Best Catera Ever Made pics
  9. Tire Wear
  10. Help! I'm locked out of my Caddy! - Please Respond
  11. I want to put 18" or 19" rims..............
  12. crazy about cateras, but boston winters?
  13. this is freakin me out.
  14. bolt pattern
  15. 2001 Catera with Burning Smell
  16. engine flush
  17. Coolant light comes on
  18. What's the trick to removing the throttle cable?
  19. Just Got A '00 Catera
  20. 99: how to tell if it is a sedan or a sport sedan.
  21. Lund Cadillac of Phx, AZ
  22. After market cd-player for 2000 catera?
  23. Instrument Panel
  24. Rear Main leak
  25. new Owner of 2000 catera sports sedan
  26. synthetic gear lube
  27. 98 Catera Fan Not Working?
  28. Dirty
  29. headlights staying on
  30. Most Annoying Feature
  31. Xenon Lights
  32. happened way too soon --- catera being parted
  33. Anyone need a 2000 Sport?
  34. Back to forum
  35. want to change oil myself + recall questions
  36. Looking to buy a 2000 catera!
  37. Timing belt tensioner recall tip
  38. How to change oil pump?
  39. hardwiriing deck
  40. replacing a pulley
  41. brake pad sensors
  42. Looking to buy a catera
  43. Front Door Panels
  44. Fortunate
  45. Need some help!!! 97 Caddy!!!
  46. problem with instument lights (98 Catera)
  47. On Coolant Mixture
  48. What's the trick to removing the wiper arms?
  49. problem with instument lights (98 Catera)
  50. Yellow goop on oil cap??
  51. Catera Grille - where can I get one?
  52. Heater control valves?
  53. rear powered sunshade
  54. interior
  55. Blown Fuses
  56. Heated seat...er not?
  57. Where to Buy Oil Cooler
  58. cylinder numbers on 98 catera
  59. bad gas mileage
  60. (Car Review) - They liked the Catera..
  61. button on transmission stick
  62. Removing door panels and woodgrain
  63. A/C Blower Fan
  64. Need Immediate Help with Accessory Tensioner!!
  65. opinions re code reader
  66. Fuel filling problem
  67. lug pattern
  68. Frozen doors!
  69. EBTCM Location/Schematic/Pics
  70. heated seat fire
  71. cigarette lighters
  72. baby seat installation
  73. Funny Problem
  74. Oversteer or Understeer ?
  75. aftermarket door mirrors
  76. 97: Sticking door locks
  77. leaking gas cap???
  78. please help no heat
  79. lugnut covers
  80. Want to put an aftermarket Cd player in your car....look inside!!!
  81. Sticky Ign Lock ???
  82. Ignition Wires
  83. dash kit?
  84. anybody know about the TSC on a 2000 catera?
  85. What do I need to read codes with my PC
  86. Balance
  87. engine dying out after high speeds
  88. Filling Problems?
  89. oil cooler gasket?
  90. Rims
  91. alternator for 97 cat
  92. steering column for cat w/ ignition and key
  93. transmission not shifting when cold
  94. Biggest size rims to fit?
  95. Air Intake
  96. Should I buy an extended warranty ?
  97. Looking for help w/ P0171 code
  98. No Cadi Mech Can seem to solve my problem
  99. Bose Amp Wire Harness 1997 Catera
  100. Ignition 98 Catera
  101. 98 catera oil cooler
  102. oil in coolant problem
  103. programing garage door opener
  104. Synthetic oil
  105. Catera alarm problems
  106. Engine cooler?
  107. Am I gonna see elec. probs?
  108. What happened to the Catera?
  109. speaker size?
  110. Sry noobie here
  111. Top Speed
  112. Catera Up keep
  113. winter tires
  114. Anyone Know 2000 Cat Interior Bulbs?
  115. 1998 catera shuts down many times!
  116. 2nd owner 98 Catera, new member????
  117. HELP!!! back driver side window doesnt work!!!
  118. just had brakes done, light still on
  119. Cold Natured Catera
  120. Differential Problems
  121. Oil in the spark plugs?
  122. transmission-97 catera
  123. New Owner
  124. Grill-who sells it?
  125. Just a bulb or two, from mint!
  126. mods for my catera!
  127. Gas Cap Problem
  128. Octane Boosting? "Should I?"
  129. Heat/AC console 'Lights out'
  130. Doin' the brakes!!
  131. Driving with the heater on?
  132. Platinum 2 plugs
  133. weather stripping
  134. Bit of a Rough Idle
  135. keyless entry remote!
  136. Driver's side heated seat
  137. Help - Battery Is Dead Again
  138. Projection lights
  139. to rustproof, or not to rust proof
  140. Oil drain plug
  141. sunroof
  142. body kit for cat
  143. Brake lights...
  144. If U Live In Michigan...
  145. Damn! Anyone help?
  146. Transmission Pump?
  147. gettin my brakes done!!!!!!!!!!!
  148. A/C & Heat
  149. http://tlentz.oldsgmail.com/howto.html
  150. Few Questions...
  151. AM radio static
  152. !!!***help***!!!
  153. clearing codes
  154. High oil pressure
  155. Twin Turbo Catera
  156. Catera Productions Numbers - where to find
  157. bbob,anyone? 4.x engine in cimarron?
  158. My Catera
  159. Looking for a Key
  160. leather seats
  161. 1st Time Oil Change on my 2000 Catera - Help
  162. Pulling Codes
  163. Power Seats...
  164. Wiper Blades
  165. wheel is stuck to car
  166. Parts Source?
  167. Catera body kit
  168. Vent by the windshield Removal '97 Catera
  169. 18's boxed up and ready to sell
  170. Floorboard full of water on '97 Catera HELP
  171. Crate Motor
  172. Done for the year----FED UP
  173. 97 catera Starter HELP!
  174. Catera ABS/Traction Control System
  175. heater control valve
  176. '99 Catera, won't do anything.
  177. Phantom Sunroof - cheap fix
  178. days late and dollars short (O2 sensors)
  179. Bose CD
  180. sparkplugs
  181. electrical gremlin?
  182. H.i.d.
  183. Headlight replacement for 98 catera
  184. Spare key
  185. 2000 Catera Oil Changing - Is there an easier way?
  186. programming new remotes?
  187. Instrument lamp bulb replacement in a Catera
  188. Gauge Cluster Bulb Replacement
  189. New plugs....now missing
  190. Projector Lenses for a 99
  191. Heater Control Valve Replacement.Thanks Sjashbrook!!!!!!
  192. customization?
  193. Interior and Exterior Fit and Finish
  194. Tape Deck to CD Deck Conversion
  195. Oil Pressure Light
  196. Speedometer Cutting out Part II
  197. Check Engine Light and Idle
  198. Tune up time
  199. timing belt
  200. Tornado.....anyone using them??
  201. billet grill for catera on ebay!!!
  202. Speedometer cutting out...
  203. performance pads
  204. auction for my cross drilled rotors
  205. Speaker Sizes For 2000 Catera
  206. Check engine light!!!!!!!!
  207. Broken Power Seat
  208. cross drilled rotors for sale.
  209. Seatbelt refuses to cooperate with me! LOL
  210. Catera 2000 fuses,relays and switches
  211. Cadillac Catera 1998 shuts down
  212. Firing Order - !!!!!!!!!!!!!!!
  213. Transmission mount bushing?
  214. thinking about purchase of 2000 catera
  215. '99 - Door Panel Removal (help)
  216. My Caddy on ebay
  217. programming FOB 97 Catera
  218. 2000 catera sport mode flashes and cel comes on and off
  219. Help with a P0730 transmission code
  220. 18" kaizers goin up for sale
  221. thanx rollin catera
  222. A Little Help Please
  223. Rear Window Cable Broken
  224. looking for a quiet exhaust
  225. Head light Problems
  226. catera.org?
  227. Carjunky25 ...
  228. catera winter tires
  229. my 98' catera
  230. Help
  231. Anyone have any experience with Steinmetz?
  232. headlight cleaner?
  233. Jack stand points - where?
  234. need front rotors for a catera?
  235. Help Asap
  236. Bra recommendations?
  237. 1998 wont start>will start>wont start>......
  238. did i make a mistake?
  239. 98 Catera heater help
  240. Starting problems
  241. Purchase a 99 Catera?
  242. Really Ticked
  243. 2000 Catera Won't Start After Warmed Up
  244. 97 catera - how can I make it lighter
  245. intakes
  246. Misfiring problem
  247. A/C not working
  248. drilled and slotted rotors
  249. RSM Supercharger
  250. need the rubber pads in the front arm rests for a 97 catera...
