View Full Version : Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28
  1. Gas mileage!!!!!!!
  2. 1998 catera radio problems
  3. 1998 catera radio problems
  4. shifter boot replacement on a 2001 catera
  5. 2000 Catera AC Compressor Replacement
  6. Wheel cap
  7. AC line connector question. Tools?
  8. code 171 and 174 but after changing MAF, car idles bad, and light comes back again.
  9. radiator light came on, filled up coolant about 500 miles ago., please read & advise
  10. airbag issue, driver bag was missing, after change it, b1000.
  11. competant and inexpensive mechanics near bay area for cadillac catera
  12. Starter
  13. Suspension Evaluation Log / 08-11-2012
  14. 99 catera random misfire 1-6 on idle!!
  15. more airbag questions - please respond.
  16. Yet another oil leak and window regulator question
  17. Help! 98 Catera starts but dies.
  18. help Catera misfire nightmare
  19. Chrome rims leak air
  20. shifter problem
  21. '98-'99 CD/Cass Radio in '97?
  22. really bad oil leak (really long question)
  23. really bad oil leak (long question)
  24. 98 catera
  25. fan motors
  26. cruise control
  27. Engine Replacement
  28. Lost Spedo, Odo, CC, etc.
  29. Cylinder 4 misfire
  30. '01 catera radiator yellow warning light on, after change radiator reservoir same -on
  31. '01 catera psi guage problem - goes up to 80+, idle at middle, and goes to 0 sometime
  32. had code 171 and 174, after change and MAF (remanuf), now have code 172
  33. CTS V exhaust question
  34. Tune a 2001 For Speed?
  35. Electrical issue. Radio, fuel lid, trunk lid, radio don't work. 2001 Catera
  36. Intermittent Oil / Voltage Guages
  37. Ignition wires
  38. cooling problem again
  39. DIS sequence
  40. Control arm
  41. 2001 Cadillac Catera: TC/ABS Light!
  42. vid: 1983 Cadillac Cimarron Design and Promo
  43. New Catera Owner with part questions
  44. 1998 catera 54,500 miles secondary water pump issue.
  45. 2000 Catera MAF sensor bypass
  46. 4 rear Plenum hoses
  47. Heavy overfueling on cold start - seeking advice
  48. Catera ownership experience?
  49. 97 Catera Head Gasket replacement-- Please Help!
  50. Map Lights not working when Engine is on. They only work when car is off.
  51. Rear strut deflated but a few days later reinflated.
  52. Buzzing noise coming from Throttle Body where Throttle Position Sensor is located.
  53. Valve cover interchangeability question...
  54. New catera owner really need help
  55. Rear squeaking brakes ????? :(
  56. air ride compressor
  57. knock sound
  58. A Catera with less than 2000 miles?
  59. Catalytic converter question
  60. Location; oil sending unit (light)
  61. Need a new ecm
  62. Transmission band adjustment???
  63. rear pinion bearing
  64. How cam caps marked? Am I crazy? 01 Catera
  65. Urgent!!! Need help finding valve covers!!!
  66. Forum members free s&h coupon code - cadillac merchandise, floor mats and car covers
  67. Rear window regulator solutions?
  68. Cadillac catera 1998
  69. 2000 catera charging system issues
  70. New to Cadillac and have 12 codes in less than 24 hours. Please help!!!
  71. Spark Plug tube seals
  72. Rear differential removal, need to remove cv shafts?
  73. Headlight bulb??
  74. J 42069 Cam Tool Kit for timing belt change
  75. Rough idle and check engine light...
  76. Valve Cover change log...
  77. 2000 Catera - What are these parts?
  78. code p172 and p175, before was p171 and p174
  79. Catera rear subframe quetion
  80. '01 Catera, starts up but dies
  81. High gas mileage usage!!! Help!!!
  82. Limited Slip Differential???
  83. Are these stock wheels on a '98?
  84. How do you remove the left bank spark plugs on a '98?
  85. Remove Power Steering Pump?
  86. Fixing up my A/C System, What Should I Do?
  87. 2000 Catera--Trouble Getting Started (Catera Groundhog Day)
  88. Replacing heater core in a 99 Catera
  89. 1998 Catera won't upshift
  90. Possible causes of misfire?
  91. Quick Question About A/C Compressor Replacement
  92. Transmission problem fixed
  93. 1999 Catera
  94. Well, I've given up.
  95. Anyone know if K134 Multifunction Module is grounded or suppose to be?
  96. Just Got a Catera
  97. Need help with new sound system!
  98. 2 Door Catera
  99. 01 catera frequent use of 'S' button
  100. Celsius to Farenheit conversion for 1999 Catera
  101. Long time Catera owner about to be Catera-less
  102. Quick question need some help please
  103. 1999 Catera gas Mileage
  104. Cadillac Catera Factory Service Repair Manual (1997-2001) - PDF Download
  105. Cadillac Merchandise - Free S&H Coupon Code Offer
  106. Radio/trunk/fuel door malfunctions
  107. I need new rear shocks
  108. 2001 catera water pump pulley removal
  109. Windshield Fluid Nozzle Cleaning?
  110. Cooling leak
  111. 2001 Sport: My Problems, And How I Fixed Them!
  112. 2000 catear ground wires
  113. 97 catera wont shift
  114. 2001 Catera
  115. Ugh! replaced old Battery~ have power to dashboard, but the car wont START?
  116. Spark Plugs!?
  117. replaced the cps, still won't start
  118. Timing belt?
  119. Oil Bypass Hose
  120. Just did the rear brakes
  121. catera oil catch can
  122. 98 Catera heater not warm and front heated seats dont work help
  123. Passenger side heat not working?
  124. 2004 gto rear shocks to install on 2001 catera I already read the threads before.
  125. ac control unit has burned out bulb on fan speed 2001 catera
  126. 1st time poster. Autocredit box removal
  127. Need help with potential new sound system!
  128. Need help!!! did the bypass hcv mod and now i dont get heat
  129. Omega Bodykits on Catera
  130. Volt?
  131. Fog Lights don't work?
  132. Cadillac merchandise - free shipping offer
  133. 98 catera gives heat only at high rpms
  134. Catera shut off on me today
  135. 2001 catera how to add to rear differential fluid and some stop leak?
  136. switching valve covers
  137. dropping rpm when brake
  138. P0411
  139. Alas, no Catera for me
  140. New brakes all around
  141. Slow start off the line
  142. Need help ....ASAP!!!
  143. First car
  144. Hey Guys, new to the forum and have some questions with my 2000 Catera
  145. 2000 catera overheating, fans not coming on.
  146. Spark Plugs and A Tranny Question
  147. Universal vs Direct fit catalytic converters
  148. 1999 catera front passenger right side fender tan
  149. 87 Cimarron Transmission Speedometer Gears have finally worn
  150. Alternator Question
  151. an obvious lie
  152. Front Brake Pads (Ceramic) Charlotte area
  153. O2 Sensors
  154. ENTIRE oil filter cylinder loose HELP!!
  155. Head lights and fog lights
  156. Adapting European DIC into Catera
  157. No High Beams
  158. 2000 Catera Sport with intermittent engine stop problems
  159. Oil filter housing leak????
  160. Catera Front Struts?
  161. 1997 cadillac catera hesitates on acceleration.
  162. Drop in oil pressure
  163. 2000 catera defrost
  164. 2000 Catera Glove Box Latch
  165. Steinmetz rims
  166. need wiring diagram for 01 catera
  167. need wiring diagram for 01 catera
  168. Is this a Sport?
  169. Intermitten start
  170. Mine!
  171. Bank 1 sensor 1
  172. Engine Coolant
  173. Poor Gas Mileage
  174. List of problems in your Catera. Get money ready!
  175. Help,I broke a wire!
  176. Hvac control head removal
  177. Saturn Astra XR Wheels - Direct bolt on for the Catera
  178. Weird issue
  179. Differential oil change
  180. Free S&H Coupon Code Offer - Cadillac Logo Merchandise, Floor Mats & Car Covers
  181. Anyone need a K-134 Module?
  182. Sea Foam
  183. Seat differences?
  184. 2000 Cadillac Catera Auxillary Electric Water Pumps
  185. 2000 Cadillac Catera creeky noise
  186. po 301 code
  187. Bad starter
  188. Operating Temperature
  189. over heating,leaking water!!!
  190. Seats for 01 catera, Tampa junkyard
  191. Tcs issue, and bumper fitment question...
  192. code P1870 and 1700
  193. Charging problems
  194. 2001 Catera throttle body and O2 sensors
  195. 98 Catera Oil leak
  196. climate control not functioning/ passenger side heated seat wont shut off/
  197. Need opinions
  198. Rims, Tires and all that good stuff
  199. Security light
  200. Security system malfunctioning
  201. Frozen? windshield wipers
  202. High beam malfunction...annoying...
  203. front swing arms
  204. Catalytic Converters condition?
  205. oxygen sensor help
  206. Driver side headlight out!
  207. 98 - Catera Stereo Install - In Detail
  208. 97 Catera Misfire on cylinder 3 help!!!
  209. my heater
  210. hose identification
  211. Valve cover torque specs
  212. 2001 Catera cold start shake / vibration
  213. Need help with my '97 Catera
  214. Catera driveline axle / propeller shaft support bearing
  215. Front sway bar bushings
  216. Powerflex Bushings Wanted
  217. Fuel / gas odor
  218. Paint Code
  219. 1998 Catera - oil change information
  220. 1999 Cadillac Catera - headlight assembly adjustments
  221. 1999 Cadillac Catera - picture box
  222. 97 Catera brake line help
  223. touch up paint
  224. Gas chips that remap fuel/air ratio on eBay and other sites
  225. Do you let your Catera warm up in the cold mornings?
  226. Every here of someone lowering there car with the stock air ride system?
  227. 1999 Cadillac Catera - sluggish shifts
  228. Power Steering Pump 99 Cadillac Catera
  229. Milky oil cap and down in pour pipe but dip stick looks good?
  230. 1999 Cadillac Catera fog lights
  231. Front control arm bushing.
  232. gto break swap questions
  233. Security Alarm
  234. Wanting to install sound system into Catera, would like some help.
  235. how much hp is everyone putting out
  236. 1999 Cadillac Catera vs Opel Omega Headlights
  237. Audio system problems?
  238. totalled my catera
  239. 10% Forum Member Discount Code - Cadillac Merchandise
  240. Engine Sputters at cold start
  241. 98 Catera valve cover swap
  242. New to Catera's! need help on specs for inside lights
  243. What is this part?
  244. New problem with my Catera
  245. Oil?
  246. project car catera
  247. wont run
  248. 2001 Cadillac Catera
  249. 1998 Catera Cranks, not firing, no fuel pressure.
  250. Wood grain around the shifter
