: Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28
  1. Electrical Problem
  2. catera cooling problem
  3. 97 Catera no A/c and sort of review
  4. 1997 Catera For Sale!
  5. Bye bye stock radio/cassette
  6. Opel Mv6 On Ebay !!!
  7. 2000 Catera AC issue...puzzled???
  8. Rear Sun Shade Problem
  9. Sell, Trade in, or Keep?
  10. N2O and a Maunal tranny question
  11. does any one know about the cimmaron
  12. New member to Forum
  13. Catera => OmegaMV6
  14. help me i wanna know more
  15. HID low beam problem
  16. Something odd....
  17. Power seat
  18. Just bought 97 Catera
  19. o2 sensor
  20. Curious Questions
  21. Which HID bulbs too buy for a 98 Cat?
  22. Radiator Puller Fan
  23. Doggone 'misfire' frustrated
  24. What surrounds the glove box/compartment??
  25. Catera Wagon?
  26. High RPM's on highway
  27. 2000 catera coolant probs
  28. Catera Bose Upgrade, and tranny question.
  29. CE light on and car shakes while idle
  30. Code P0501
  31. Ignition switch feels tight while turning
  32. Instrument panel gauge lights
  33. which sied is bank 1
  34. Front end rattle? 97 Catera
  35. howto: ignition coil remove and install
  36. Code PO171
  37. To Port and Polish my Intake or Not?
  38. Fan on 2000 Catera Won't shut off!!!
  39. Catera Group
  40. 2000 catera for sale
  41. Gas Problem
  42. head light problem
  43. Climate Control has a mind of its own
  44. Easily accessible hole in firewall?
  45. coolant in transmission
  46. Manual tranny an option?
  47. Sub upgrade question
  48. Insight on Headlights for a 2001 Catera
  49. Crankshaft position Sensor
  50. Bad Valve Gaskets
  51. cold air intake
  52. Changing Out the Gas Pedal
  53. Help Me!
  54. Winshield Molding
  55. heater/cooler HELP
  56. Why won't my key work?
  57. Roughness, so frustrating!
  58. New engine
  59. '98 transmission--good for life?
  60. what is this?
  61. catera headlights
  62. Should I buy it? 97 Catera leaking oil
  63. 99 Catera EBTCM removal & installation
  64. Cooling questions
  65. Climate Control
  66. Catera shuts off while idle in traffic!?!?!
  67. if you have advice, please help!
  68. climate control panel?
  69. rear suspension
  70. Catalytic converter support brackets...
  71. Catera oil leak, rear main seal?
  72. heater core
  73. cold air at lights, hot air while driving
  74. spraying onto pedals!? wtf
  75. Phatbox Audio
  76. Key won't turn
  77. Just buy a Cavalier
  78. 1999 Catera problems NEED HELP!
  79. Platinum spark plugs
  80. Good ole Craptera/OmegaPOS
  81. Missing cd cartridge
  82. Should I fix this problem quick?
  83. Check Engine,ABS,TC - time for brakes?
  84. cadillac catera codes
  85. Transmission Fluid Levels
  86. Oil Filter/Service Manuals?
  87. 2000 Cadillac Catera "Fuel Cap"
  88. Resistor Modification Chip/ Cold Air Intake Duct
  89. Sometimes the Best Solutions are the Obvious Solutions
  90. 'fuel cap' and 'sport mode' light flashing
  91. Muffler problem
  92. Right Side of Instrument Panel
  93. Low Oil Pressure
  94. Broken Cup Holder
  95. A/C Panel inop.
  96. Is this fine at all?
  97. Low idle when stopping
  98. Headlight Brows/Spoilers
  99. Radiator Light is on
  100. tape adaptor question
  101. disappearing dexcool
  102. Levelling Light
  103. Exhaust
  104. Headliner
  105. Another Alignment Question
  106. Keyless Remote Problem
  107. 97-99 Intrax lowering springs $80
  108. Selling Cd Changer
  109. Turn Signal
  110. Oil leaks not valve cover gaskets
  111. 2000 catera bose radio problems
  112. Temp gage sending unit??
  113. transmission shifts like 1st - N - 2nd
  114. cd player face kit needed
  115. Instrument panel identification
  116. Relocating Amp/amprack
  117. Need help : sudden accelerating at low speed
  118. Newbie
  119. remote needed
  120. Catera is UK car!
  121. check engine light!
  122. Automatic Transmission fluid/filter change
  123. Lower Control Arm Bushings...
  124. Valve Cover Gasket Replacement... How Much?
  125. First Cat, What to look out for
  126. Jeffrey, electrical problems I think!
  127. Removing the Resonator from my 98
  128. XM radio
  129. door catch broke (or should I say...-the door catch broke the door!)
  130. Catera 2001 Engine Rattle on Idle
  131. Is this safe?
  132. K&N Filter, any good?
  133. Tie Rod Ends 98 Catera....HELP
  134. 98 Catera Transmission ?
  135. 500hp and 500torque in a catera?
  136. strut mounts???
  137. Leveling Light Blinking
  138. Which oil filter do I have?
  139. Can this be possible?
  140. 97 vs 98 catera
  141. 97 catera front of car is shaking
  142. 87MpH quater mile time's.
  143. stereo code
  144. Struts
  145. Erratic Speed of Directional Signals
  146. Hi, I'm Aaron & this is my (stienmetz?)catera
  147. Hewlp Please :( (97 catera)
  148. who says our vehicle is a big problem!!!
  149. 2001 Catera cold start smoke
  150. How to sell extra parts?
  151. Keyless Entry Remote
  152. Oil Filter - How tight?
  153. confort contol panel dead
  154. Need help on scanned codes
  155. Just plain weird. 1998 Catera steering wheel
  156. quick question
  157. 97 Catera Starter Help. Answers?
  158. "CHECK ENGINE" Light On...
  159. Front end shaking
  160. Tire Thread
  161. 16" stock wheels - what offset?
  162. Do we really like our cars overall???
  163. would this work??
  164. need some help
  165. Catera Parts Links
  166. Strange Transmission Experience
  167. cATERAAA :@
  168. Fan Sensors
  169. 2000 Catera with "burning" smell and oil light on
  170. Transmission Pan
  171. catera questions i need help
  172. turn signal always on
  173. Glovebox Latch???
  174. rear suspension problem
  175. Key Problem
  176. Seville Brake Light goes out when turn signal is on
  177. Catera air filtratation system leak
  178. cd changers
  179. Need some opinion
  180. 2000 catera
  181. Here's a new one for you Jeffrey!
  182. radiator light and washer light stays on.
  183. 97 catera heater/ac problem
  184. 2001 Catera Speakers
  185. Grunting Sound
  186. Key stuck in ignition!!
  187. Help!! Catera 1998 Power Window
  188. Problem shifting into gear
  189. High Oil Pressure reading
  190. low voltage
  191. What brand of fuel do you use?
  192. Headlights won't shut off
  193. Headlights gone cross-eyed
  194. Aftermarket Radio or a/m CD changer
  195. my bad
  196. i dont know what's goin' on
  197. cold air intake for 97 Catera
  198. aftermarket air intake
  199. starter spins but not cranking over
  200. Rim Emblems & Lug Covers
  201. difference in 99 and 00
  202. 00 Cat Code: PO100
  203. Catera Fuel
  204. Considering Catera purchase, but need help (Cimarron info also inside)
  205. Coolant Flush
  206. coolant/water leak
  207. "Catera CTS??"
  208. Idle problems, all out of ideas!
  209. Wobble Wobble
  210. Should I!
  211. Grinding Noise from rear
  212. Has anyone tried this?
  213. Stock Alternator Amperage
  214. 2001 Cadillac Catera
  215. Check Engine Light and Rough Running Engine
  216. Brake lights
  217. 97 Catera News Update!
  218. Engine Coolant Temp Sensor/Sender and Gauge
  219. Sealers.., Plese Advice!!!!!!!!
  220. Can we use 180degF Thermostat in the Catera!!
  221. Front struts/ Oil filter--97 Catera
  222. A wierd dustcap??
  223. My Oil Light Is ON---97 Catera
  224. Gas milage
  225. Clearing my Headlights...
  226. Hey I'm New!
  227. $99 Battery!?!?!?
  228. Overheating? Or Close to it?
  229. 2000 Catera: Sport Light Flashes
  230. 97 Catera Timing Belt Replacement
  231. Oil around Spark plugs
  232. Headlight Housing Replacement help!
  233. Change Things Up A Bit...
  234. Learned from MAF and Cranckshaft Position Sensor (CKP) Replacements
  235. Headlight adjustment 1997 Catera
  236. Is 15w40 right for Cat
  237. Oil pressure gauge
  238. Oil filter wrench
  239. Coolant Leak
  240. What to Do ?
  241. I love my CAT
  242. such a beautifull auto
  243. Head lights
  244. Trans MIL on
  245. Communication with the MOTRONIC ECM
  246. Cheap O2 Sensors
  247. Totally Confused-pleeze Help
  248. 96 Catera WONT UNLOCK!!
  249. thewheelguy
  250. Remove Scratches
