View Full Version : Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28
  1. Ex Police Omega Limited Slip Diff on Ebay UK
  2. RE: Cimarron part question
  3. Replaced thermostart and now it won't run
  4. RE: Cimarron food for thought?
  5. Coolant & Gas Smell
  6. "High Mileage" switch to synthetic?
  7. My car won't start. Can the problem be the crankshaft position sensor?
  8. Possible sensor / Crankshaft Position Sensor?
  9. A thank you to kaustein - and black factory mats available $25
  10. Fuel shut off switch
  11. High Engine Temp Low Oil Pressure
  12. Rim bolt pattern size
  13. Maxi fuse and positive terminal
  14. lifting magnet question
  15. New Exhaust
  16. LS1 Catera?
  17. RE: Cimarron fuse box?
  18. Driver Side Rear Signal Problems
  19. Leaking out the back of head
  20. Cadillac: New products & coupon code offer
  21. 2001 Cadillac Catera speedometer and radio problems. HELP NEEDED!
  22. A/C Not cooling right
  23. Please I beg of you...HELP! I'm drowning....
  24. No cranking... nothing!
  25. CPS vs. NSS
  26. finally some pics guys
  27. does anyone have?
  28. does anyone have?
  29. Codes, again...(plz)
  30. 5 Speed Automatic Trans in a Catera?
  31. HVAC lights
  32. water leaking between crankcase breather box and head
  33. Ignition Switch question
  34. Pics of your modded cat?
  35. LS1 Catera Oil Pan
  36. could use some help
  37. A place to go for all of your hard to find mods!
  38. One dash light is out
  39. 98" catera climate controls
  40. EBTCM Replaced
  41. Recharge: AS-12
  42. My 97 catera project..need helpfull insight
  43. please help! need advice!!
  44. Oil Light?
  45. E-bay Heater Control Valves - Any Good?
  46. Problems problems a-z
  47. Need Parts
  48. Swaps are good. Conversions anyone?
  49. 98 Catera wont down shift and is in limp mode
  50. Does Brake pad wear sensors affect ABS light & Traction control light?
  51. catera problems help!!!!!!!!!!!
  52. 24 Valve DOC V6 Valve Spring Compressor
  53. 98 Catera running a little hot? help please
  54. V-belt chewed up! Help!
  55. Looking to redo my suspension.
  56. what sensor
  57. Milky White Goo inside Oil Filler Cap
  58. P0301 #1 Cylinder Misfire 97 Catera
  59. 97 catera no spark no fuel ?
  60. Cadillac: New products & coupon code offer
  61. 98 catera panel lights
  62. Need to find a Fram Sure Drain Hose
  63. CateraMV6 Please contact Me - I have questions for you
  64. Hello everyone
  65. RE:good car/ bad daughter/Cimarron
  66. What is this suspension part?
  67. problems
  68. Check Engine Light
  69. CateraMV6 please contact me
  70. driver's side door panel trim or rubber piece
  71. Minor emergency - 1999 Catera
  72. Rear View Mirror Help
  73. Just wondering
  74. fuel pump issue 1997 cadillac catera
  75. Mass air flow sensor help
  76. Catera door strips outside
  77. Bad oil pump, where is it located on engine???
  78. transmission filter / fluid change
  79. 97 catera wont start after the alarm went off
  80. Re: Cimarron V6
  81. 97 catera
  82. What do I need to do now...? From: Desperate.
  83. Oil
  84. 2000 Trunk lock Actuator compatible with 1997?
  85. Is the airbag missing?
  86. Got Tints?
  87. 2001 Cadillac Catera?
  88. Radio Swap, Removal - Comments?
  89. '99 Catera: Driver's Door Makes Three Loud Popping Noises When Opening and Closing
  90. '99 Catera: Keyfob Dead... Can the Battery be Replaced?
  91. Brake light help
  92. Very weird problem.
  93. Mechanical error on cd player.
  94. Where do the vac lines go from the UPPER INTAKE VACUUM MANIFOLD? HELP PLEASE
  95. 97 catera//how to turn off a flashing secuity light
  96. Crankcase vent tube adapter gaskets/o-rings?
  97. Classic cadillac logo merchandise - free shipping offer
  98. Differences in Model Years
  99. 98' Catera radiator replacement
  100. Filling Power Steering Fluid
  101. 2001 Cadillac Catera Throttle position sensor?
  102. BOSE sound system huh!!
  103. Rear Driver Side Window Problem
  104. New Catera Owner
  105. problems with trunk release,radio,and fuel door
  106. Keyless Remote
  107. 2001 Catera Parts online???
  108. K134 Multifunction Relay
  109. Headlight Project Problem!!!!
  110. heater problems
  111. Catera would'nt turn over
  112. Catera Rubber Mats
  113. UGHHH Help PLEASE low stage cooling not working
  114. 2000 Cadillac Catera Need help to get car going after no car for 2 years. Thank you.
  115. What should I do with the cat?
  116. Moved and looking
  117. Air Conditioining Issue...Any input?
  118. NO TC/ABS/CELs but Speedo and Tach not working???
  119. '99 Catera - changed transmission fluid & filter, now stuck in limp mode
  120. compressor not working
  121. 2000 catera engine puttering, maybe misfiring, need help urgent
  122. '99 Catera: Fuel door fell off, now lying on the interstate shoulder somewhere
  123. Brake Pad Wear Sensor Light won't go out.
  124. Where is the thermostat located & which hose do you cut in antifreeze flush kit tee?
  125. Catera stops on me
  126. anybody know where i can order a good timing belt kit for00 catera inside canada? thx
  127. engine flush
  128. 2001 Cadillac Catera Check Engine Code P0411 Secondary Air Injector Improper Flow
  129. Interior Lights
  130. Keep or sell
  131. Loose power steering at low speeds
  132. Radio Power
  133. Oil leak with pics
  134. "S" flashing on panel & all gear modes (P, R, etc) light up - Please READ need HELP
  135. Cooling fan staying on to long?
  136. Catera Shifter Issue
  137. Anybody got a 2000 or 2001 Parts Car, I need some parts.
  138. Help with AC on my catera
  139. 2001 motor swap
  140. well, gents...my Catizzle is no more {sniff, sniff}
  141. 2000 Catera sport parts car for sale!!!
  142. Help with Thermostat housing O-ring
  143. busted the small connctor on the brake booster vacuum line
  144. air conditioner
  145. Correction to AC problem
  146. Oil in coolant - second time in two months
  147. Gear Box or TCM? Or?
  148. Melted cat tips on best suppliers and likely part replacement
  149. 2001 Catera Myriad of Issues
  150. 2001 dilemma - car wont start
  151. Forum searching question
  152. Intermittant Speedometer, ABS, and Traction Control
  153. 2001 catera odometer
  154. Instrument cluster lights
  155. 2000 Catera replacing fuel pump headaches
  156. Depo lighting
  157. car wont start sometimes, no power
  158. Transmission help
  159. 2000 Cadillac Catera Flashing S. and check engine light on.....
  160. 2000 cadilac catara (radio runs) but no sound
  161. catera project
  162. Overheating and AC... Help!
  163. 2001 Catera service maintenance schedule booklet
  164. transmission lights!
  165. Coolant flush using Super Radiator Flush chemical
  166. Vacuum hose problem
  167. Throttle body problems!
  168. Some problemas with my catera 98'
  169. Headlights don't turn off, and car won't start??
  170. '98 Catera Headlight Aim - - oops, I discover the "Crunchies"...
  171. Car smells like gas
  172. Cooling System Fan Noise...
  173. OBD Readiness Monitor Drive Cycle
  174. ignition problem?
  175. Upgrading stock sub woofers (pics)
  176. DAsh lights
  177. Catera to hot to restart??
  178. P0705 code 2001 Caddy Catera
  179. Tuning vacuum valve?
  180. 2000 Catera Starting problems
  181. abs tc light no codes
  182. valve cover leak
  183. Catera starting problems
  184. Getting new car
  185. 99 catera oil in Main Pre Throttle Breathers
  186. 99 Catera Traction Control
  187. Crossover bridge seals, shouldn't they be rubber?
  188. Now THIS is a Cadillac!!!
  189. Pulled the Front Seats From a Catera Transplanting Them Need Help
  190. Does 2001 Catera Have a Diagnostic Mode?
  191. Part Needed
  192. 1998 catera trans problems and gauges not working
  193. At what PSI should the cooling system be tested?
  194. Still looking for these parts.
  195. Any idea's on how to fix a stripped wiper arm motor post?
  196. EBTCM part number? 1998 Catera
  197. 2000 cadillac catrea
  198. Brake lights
  199. 1999 catera not starting
  200. major vaccume leak ..
  201. Is there a connection between trouble codes 301, 1100, and a sudden downpour?
  202. Catera 98...............
  203. Banging noise on suspension & creaking steering...
  204. Mass air flow replaced
  205. 1998 catera major transmission fluid leak! - please assist.
  206. 2001 Catera Aux pump part #
  207. Your rims...
  208. Any thoughts about going turbo?
  209. my 98 cetera wont start
  210. It is obvious that the Catera is a repair prone vehicle.
  211. Catera Temperature Sensor & coolant leak
  212. 98 Catera driver's side front door problem
  213. Overheating problems??? head gaskets??? oil cooler???
  214. 99 Catera , Auto windows / Interior lights Quit
  215. 99 Cat Engine Power Loss?
  216. Front (or rear) crank seal leak?
  217. 98 Timing Belt Alignment Problem
  218. Which one I should choose?
  219. special tools for timing belt-2000 catera-do you need them to replace head gasket?
  220. 12V LEDs - Success and help.
  221. Dallas Cars and Coffee October 1, 2011
  222. 98 Timing Belt Cover Bolts
  223. AC vacuum pump?
  224. HELP! My radiator Blew and I have coffee colored gunk all over... need advice asap.
  225. 1998 Catera Interior lights won't shut off
  226. Fuze Keeps Blowing
  227. 1998 Cadillac Catera Oil Pressure prob. - Need clarification on "Oil pressure switch"
  228. Oil cooler replacement???
  229. 1998 Catera TC light on, RPM tack stopped.
  230. 98 Catera windows don't work
  231. 1997 Catera parts: new, used, aftermarket, custom etc.
  232. Mis-fires, did spark plugs, now P0340 and no start. Help
  233. Misfire code, replaced spark plugs, now car will not start (but cranks) & P0340 code.
  234. 2001 Catera Coolant Leak
  235. searching for post #221 from10-10_09
  236. CD changer
  237. Electrical Help needed please
  238. BCM Reprogram
  239. Road Trip in first Catera
  240. Is the trunk lid supposed to fully open automatically after releasing?
  241. Please!
  242. I need a PVC vent tube adapter for my 99 Catera....
  243. Serpentine Replacement
  244. bypass heater core in 1998 Cadillac Catera
  245. small inlet pipe ontop of water pipe
  246. How do I flush the water system/radiator??
  247. Oil leak, upper oil pan gasket?
  248. Can I use a 1997 Catera Radiator on a 2001?
  249. Rear inner tire wear and trim height
  250. Steering- idler arm bracket attachment?
