: Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28
  1. New member and new Catera owner...
  2. Limited Slip differential- Who's interested.
  3. Rear brake rotors
  4. Anyone Selling Catera Rims?
  5. Power steering and other ?'s
  6. You asked,they're here, burnout vids!!
  7. Torque for valve cover & oil pan bolts?
  8. 00 cruise control question
  9. Heater Question - Actuator ???
  10. problems with ignition coil after replacement ..
  11. aux waterpump for sale
  12. Help with identifying a loose connector in wheel well?
  13. brake lights
  14. Catera problems fixed!!
  15. Catera coolant leak
  16. Airbag light resetting
  17. Heater Question
  18. guess what now?
  19. Extended Warranty
  20. Half of trunk light went out
  21. What are the steps in removing a radiator?
  22. New Owner of 97 Cat - All advice Welcome!
  23. cd player Not working.
  24. New Head Lights?
  25. New Head Lights?
  26. 2000 Catera Power Steering
  27. P225/55/R16 or P225/60/R16 for 97 catera
  28. the new catera
  29. lady-cat rides again
  30. Oil/water lights stays on after battery charge
  31. power window broke
  32. Engine swap a V8 or a turbo v6
  33. climate control/radio bulbs
  34. tune up/ radiator
  35. Rotors for the rear.
  36. New here. Want info.
  37. Ignition Coil Solution
  38. Complex Air Intake
  39. so santa didnt give me my 1 wish
  40. Ignition Coil
  41. P0442 code
  42. Speedometer stopped working on highway!!
  43. what year is my car??
  44. oops! Replaced mass air flow - not oxygen sensor in 97 cat
  45. PO153 code - check engine light on '97 cat
  46. Watch that ice in wheelwells
  47. Cimarron / J-car Custom Jobs
  48. Light replacement on dash / O2 sensor question
  49. Factory Radio
  50. Finally got the code for y'all
  51. road trips in my 2001 catera sport: missing that 5th gear!
  52. 97-99 Headlight recommendations
  53. no heat eeek
  54. 99 Catera Missing on 2,4,6
  55. heater problems - linkage on right side Activator
  56. charging systems
  57. Headlight Switch Removal
  58. Check Oil Light
  59. Need Info Quick. Seats
  60. Helms Service Manuals on sale!
  61. Trying to determine coolant loss source
  62. P0171 Bank 1 Lean
  63. What's up with my HVAC control ???
  64. Labor Hours for Oil Cooler Replacement?
  65. Original Foglight
  66. Performance Transmission
  67. HID Upgrade on 2001 Catera
  68. Does The Oil Cooler Effect
  69. I Need Major Help Please
  70. Help With Oil Cooler Problem ! ! !
  71. cat on 20's?? need help and info
  72. Aftermarket Heated Seats
  73. Headlight Switch Problem
  74. 2001 Timing Belt TSB/Recall?
  75. Oil Cooler Replacement Questions/Summary
  76. CD changer problems
  77. WTB! 97-99 HVAC control/display
  78. Air in the cooling system
  79. Innova 3100
  80. coolent leak on engine
  81. Block heaters
  82. Discounted Caddy parts:
  83. '00 Coolant Mixing w/ Oil - white sludge in oil filler
  84. HCV Installation Question
  85. converible cimarron
  86. MAF Sensor
  87. Instrument Cluster Installation?
  88. "Harsh" Front-End Sound At Low Speeds
  89. Engine shuts off
  90. New owner of 2000 Catera
  91. my '01 sport gets darty and wanders >>>
  92. Suggestions on remote start?
  93. Heat, idle, and recalls
  94. Centrifugal Superchargers
  95. 99 termostat replacement
  96. 98 Catera fusebox
  97. Cheapest Source For Heater Control Valve?
  98. no more lady cat
  99. Valve Cover Gasket Advice
  100. 1998 Catera Heating problem. please help
  101. no heat?
  102. 2001 Xenon Replacement
  103. Brightness Levels of Illuminated Controls
  104. P0171/p0174
  105. Code 0411 Secondary Air Injection
  106. Cadillac Cavalier?
  107. P0171/p0174
  108. programming a new remote
  109. Transmission: slippage to nothing
  110. 99-01 oxygen sensor for sale
  111. Limited-Slip Differential
  112. Campaign 00042???
  113. Where is the CT Sensor located on my 2001 Catera?
  114. 98 catera cruse controll failure
  115. Question regarding paints
  116. 2000 Catera Xenon Conversion
  117. Catera Lowering Springs
  118. NGK spark plugs
  119. 2001 Non-Bose Speaker Sizes + Installation Help?
  120. Wobble/Vibration/Shimmy - definitive answer??
  121. EBTCM symptoms
  122. catera performance parts ????
  123. Not the emission system
  124. Help! Power to stereo head unit question/issue
  125. Unknown Dash board light
  126. !temperature display problem!
  127. Catera Heater problem
  128. Check Engine Light Removal
  129. Catera 2000
  130. Wheel Corrosion
  131. Unstable Engine?
  132. catera in the snow?
  133. snow flake next to shifter?
  134. 1998 Catera Bose Conversion
  135. 97 Catera misfire
  136. Installing a Pioneer Deck
  137. Purchased 97 Catera auto auction
  138. test disregard
  139. Where can I find lamps
  140. 2000 Catera misfire problem
  141. cold-air induction: real or hype?
  142. California Smog Problems?
  143. changed engine in catera went great
  144. Help with Intake temp sensor
  145. before you buy any catera
  146. Timing belt
  147. ignition coil made out of paper?
  148. any good cateras out there
  149. I am looking for Shift Solenoid for Catera 98
  150. No radio, lost door lock programming - HELP
  151. decisions decisions
  152. Another sensor problem
  153. electrical problems??!
  154. Bypassing the Oil Cooler
  155. 1995 Cadillac Catera parking or fog lamp assembly.
  156. Nichole
  157. pep up your catera
  158. New owner
  159. Bosch Platinum +4 Spark Plugs
  160. Brake light switch
  161. Bose CD / Cassette
  162. 00 Sport Rebadged to Vauxhall Omega for sale
  163. catera owners HELP !!!!!
  164. Help with catera exhaust
  165. Aftermarket Stereo
  166. Speakers
  167. How To Change Catera Engine?
  168. Need driver side fender
  169. Catera Needs New Engine
  170. A National Meet Location Vote!!
  171. Idea for Brake Pads
  172. Just gotten into the catria have a question?
  173. Cheap Oxygen Sensors
  174. service nightmare
  175. Replace 97 Catera THERMOSTAT???
  176. chat room
  177. fyi...i now own the 2-volume service manual and the parts# ref-booklet the '01 catera
  178. sway bar
  179. minimally invasive front/rear skirts for '01 catera?
  180. help me please..check engine!
  181. Heater control valves
  182. INJECTORS checking? cleaning?
  183. 1999 Catera, RKE Problem
  184. Aftermarket Stock CD Changer
  185. Window plastic buttons(switches)
  186. which wheels should i get? (photoshop fun)
  187. VERY RARE catera pic :-D
  188. seat warmers don't work
  189. FOG LIGHT housing
  190. Exhaust Systems and Performance Parts
  191. Rear end?
  192. Digital Speedometer Issues
  193. Coolant stop leak
  194. jalowiec, i have a ? for you about your guage cluster
  195. electric going crazy
  196. electric going crazy
  197. Power steering going out?
  198. fuse panel access details
  199. best place to get front rotors and pads?
  200. anemic rear defroster and side mirrors? >>>
  201. 6 year Corrosion warrantee question
  202. Transmission Problems
  203. Low Idle When Stopping - Pls help Miahcornell & JefferyG
  204. Saturn 3.0 vs. Catera 3.0
  205. Rear end oil
  206. Battery Dying
  207. Whats With The Cooling System
  208. Replacing the Rear Main Seal
  209. 2001 Catera CE codes
  210. 99 Catera timing belt recalls?
  211. 1998 Catera MUST SELL!!! Toronto Area
  212. No Dome Lights
  213. new guy-old problems
  214. What Have I Done???
  215. Who Wants my catera?
  216. Not the oil cooler
  217. Climate Control Problem Cont.
  218. what could it be? PLEASE HELP!
  219. Tach and Speedo quit at same time
  220. Coolant level
  221. Ethanols
  222. Manual Transmission
  223. What is the Amp draw
  224. A/C computer module location? RADIO Problems
  225. Problems after battery was disconnected
  226. interpreting the voltmeter scale? >>> (image)
  227. ECC problems
  228. "lumpy" idle...normal? >>>
  229. head gasket
  230. Rear muffler ???
  231. strut replacement question
  232. mildly OT: changing tire diameter & effect on acceleration?
  233. car dies at stop 98 catera
  234. wont start
  235. Projector Lamp problem, please help
  236. In need of O2 Sensors
  237. mildly OT: effect of rims w/ less offset on fit?
  238. Did the 2001 Catera have rack & pinion steering or the recirculating ball system?
  239. The Phantom Oil Light....
  240. CD Changer
  241. Multiple DTC's, need help ASAP!!!
  242. coil pack
  243. What could cause this noise????? transmission?
  244. what's the appropriate gas-pedal feel for an '01 catera? >>>
  245. what's the appropriate brake "feel" for an '01 catera sport? >>>
  246. 1999 Cadillac Catera: low beam issue
  247. ?
  248. Tranny Fluid fill plug??? HELP
  249. 2001 Catera
  250. Fuel gauge way off!
