: Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28
  1. Usual 97 problems ;) AC
  2. Need Help Troubleshooting A/C
  3. EBTCM replaced -still having problems
  4. 17inch RIMS: rubber size?
  5. Drilled and slotted disks (rotors)
  6. AC Problem...is there a fuse or relay for the AC?
  7. Ignition Cylinder replacement /Starting problem
  8. Changed EBTCM and now the brakes don't work
  9. Revised alignment specs
  10. will these fit?
  11. New Headunit
  12. Anyone have rims and tires for sale?
  13. Performance Module? Opinions
  14. Black lug nut cover for sale
  15. Xenon Lights for 2000 Non-Sport
  16. Anyone know what: ZJ1 package was?
  17. Painted calipers... anyone done this?
  18. Catera 98 stuff
  19. Comparing the Cats
  20. 1985 custom Cimarron
  21. Low oil pressure
  22. 2001 catera shuts off
  23. 125 - - - - - > 140
  24. A few thoughts
  25. 99 Cartera ECU problem (maybe)
  26. Bolt size for frt pass lower door hinge?
  27. Emission leak
  28. 1999 vs 2001 wheels
  29. Removing radio...instructions???
  30. Catera Rear Breaks
  31. Exhaust
  32. Have you guys ever considered using a european ECU?
  33. what does this light mean?
  34. Timing Belt Tensioner
  35. Whos Catera Video is this
  36. Hi there, i'm new, from germany, and have infos
  37. Catera w/lambo door kit
  38. Tires for '99 Cat?
  39. Courtesy Light Problems - 2001
  40. Courtesy Light Problem - 2001 Non-Sport
  41. Catera owners like CTS?
  42. Make Your Cat Really Purrrrr!
  43. Question about a non working RKE on a 97 Catera
  44. Haveing problems with the Rear window shade
  45. Cat 98 Radio woes... (Redux)
  46. Only decent Catera?
  47. Oil Level Indicator
  48. are these cateras?
  49. blower fan runs on high even with engine off!!
  50. Brake Lights Not Working
  51. CD Changer?
  52. How do you check a relay?
  53. A/C Computer Module
  54. Wheel Offset for 18' 19' or 20'
  55. Lowering Springs or Factory Replacement???
  56. Replacing Brakes and Rotors
  57. ghosts in the machine!!!!
  58. In-Dash DVD Install
  59. Heeeeelllllllllllllllpppppppppppppp
  60. Timing Belt Service Interval
  61. Hello, just picked up a catera...
  62. Timing Belt Question
  63. Spark Plugs and Coils, windshield wipers
  64. 98 Catera - Front End Suspension Tires
  65. Coolent in Oil, Kinda
  66. Ac Issues Any Help Appreciated
  67. Front Struts
  68. blower fan runs on high always,help!!
  69. Well,, the dreaded time has come......
  70. Trick(ed) Cat
  71. Laundry help with 1997 and 1998 Cats
  72. Can a Dead Cat Bounce?
  73. Changing Brakes '99
  74. Need A Front Bumper
  75. Head Gasket???????????? PLZ help!!
  76. Which Rotors from Ebay?
  77. Door sounds wierd and sticks
  78. ***wife backed up into the cadi**pic enclosed
  79. Catera trunk badges
  80. Anyone bought from...
  81. Difference Between The 98' and 99' Catera
  82. Question about Wheel Fitment?? Please Help
  83. Can't find in shop manual/valve gasket replament
  84. Alternator
  85. is a sway bar link and stabalizer bar link the same?
  86. sway bar link part #
  87. sway bar or stabalizer bar?
  88. Anyone ever put Nitrous on your
  89. Lug Bolts
  90. 2000 catera service manual
  91. Inside Door Panel Loose - How is it Attached?
  92. Koni Shocks
  93. CD Changer Available for a 2000 Sport?
  94. InterionTrunk release/Fuel door not working?
  95. 98 Catera Crankshaft Position Sensor Replacement - Cranks Won't Start
  96. image post test
  97. Accessing the door speakers on a 2000 Catera
  98. CATERA 97,98,99...internal OEM PARKING BRAKE SHOES
  99. Custom Floor Mats for sale
  100. High stop Mount
  101. Cd Player Help.
  102. tramlining/darty steering solved!
  103. Cat-a-Tonic - Assistance Needed with CD Changer
  104. Bose Wiring Harness
  105. Door hinge
  106. Fuel Door and Trunk will only open from remote
  107. Wreath & Crest 1999 & 2000 interchangeable???
  108. Any Florida owners
  109. ignition wires: Bosch or Prestolite?
  110. P0135
  111. White sludge
  112. Interior Door/Assist Handle
  113. No Heat/Defrost
  114. Dts P0155
  115. stereo upgrade tips: want a new unit, but maintain the Bose speakers
  116. Dash Light Replacement
  117. tcm for 99 catera on sale
  118. Dash light/ coolant tank
  119. Oil Cooler for Sale
  120. Need a "coolent pipe"
  121. Timeing belt Question
  122. Car threw a Check engine light and
  123. Need Xenon help fast!
  124. Need Rotors and Struts up front
  125. German Opel Omega parts same as Catera?
  126. Totaled Car:( Sideskirts 4 sale!!!
  127. Crank, no start - Crank Shaft Position Sensor question
  128. Rattle in back window area??
  129. MAF Sensor
  130. Interior Clean???
  131. Interesting Discovery on the Auxiliary Water Pump
  132. Heat Exchanger Elimination
  133. MP3 - CD Changer 97 Catera with Bose, Suggestions?
  134. Service Manuals
  135. lexani firestar for sale
  136. Need suspension help
  137. Cadillac Dealership can't figure this out!
  138. Ghost in the machine
  139. Timing Belt Replacement
  140. crankshaft sensor location
  141. door freezing problem - need help!
  142. Ignition Coils???
  143. Throttle Body Cable: Need some help.
  144. Fix For Highspeed Vibration
  145. SRS/SDM mudule
  146. Synthetic Motor Oil: Take a look.
  147. engine just stops at red lights
  148. WRAF Sensors - 1999 and Newer Cateras
  149. What replacement headlight for HID?
  150. Youngest 2001 Catera
  151. Torx bolts oil leak (Valve Covers)
  152. 99 Catera spark plug wires
  153. 97 Catera in PERFECT health needs new home
  154. cylinder head damage
  155. Shop manuals
  156. For those who have changed the BOSE
  157. 97 oil leak from a newbie
  158. Oil Pressure Gauge Momentarily Drops to Zero???
  159. Interior light bulbs
  160. Looking for Catera parts
  161. O2 Sensor still ????
  162. Car drains battery in 30 minutes.
  163. front driver side tire feathering
  164. Front hood supports bad... Replacement needed.
  165. battery wont stay charged
  166. Headgasket?
  167. Air Bag Light?????
  168. Actuators again...Sorry!
  169. Catera Catalytic Converter
  170. Hubcentric Rings???
  171. Bad rotors/Shaky Ride
  172. Catera newbie question
  173. Catera shift knob removal
  174. SJMN Article
  175. Correct Alignment Specs for 2001???
  176. Attn: 2001 Catera Owners
  177. Electrical Problems? Anyone have this problem?
  178. Possible purchase 2000 Catera
  179. customize 1997 Catera drive train
  180. EBTCM Removal.... any tips.
  181. How much should I sell the Catera for?
  182. Vent on recent oil cooler work!!!!!
  183. 200,000 <-- has anyone hit this mark on a '97 catera?
  184. Please Help!
  185. Problems can some1 help?
  186. Problems can some1 help?
  187. Counsel Sought - 2001 Catera Sport
  188. New Key And Fob
  189. H1 vs. H7 Bulbs
  190. Headlight Aiming
  191. Catera Rotors question.
  192. center link and bearings arggg
  193. Power Suroof
  194. Car Leveling
  195. Please Help: Looks Like Gm Pp Won't Honor Warranty
  196. PO171 and PO174 to lean
  197. Catera transmission or timing belt? or what????? HELP PLEASE!!
  198. Thinking of buying, what do I look for?
  199. Brittle camshaft cover bolts
  200. Resetting warning lights
  201. Does Omega parts fit to Catera?
  202. Does anyone know
  203. Goodbye to a good car
  204. Driver's side headlamp
  205. dextron coolant
  206. check engine light
  207. Radio Problems
  208. Catera/Omega/Elite
  209. Remember Ziggy?
  210. Catera and Omega used new and performance parts
  211. 99 Catera problem(s)
  212. hiting my head on a wall here 2 problems catera
  213. Best Remote Starter?
  214. Right-Front Headlight out, need info!
  215. New Guage Pod,wheels,grille!!!!pix!!!!!!
  216. Brake and Shock recommendation
  217. No. 5 misfire
  218. "Sport" button is Stuck
  219. Body Control Module
  220. 99 Catera Factory Service Manuals
  221. 00 catera eletrical problems
  222. Brake Lights Work/Don't Work--'97 Catera
  223. Brake Lights Work/Don't Work--'97 Catera
  224. P0171,0174,0300 99 Cat
  225. brake light switch part number?
  226. Transmission Problem?
  227. AC/Heater gone!!!!!
  228. What is this guy thinking
  229. Just Ordered 20's but need adapter kit for spinner's
  230. Yes. another one of those transmission problems...
  231. Need Quality Car Cover - 2000 Catera Sport
  232. Touch-up paint for Catera Sport Rims
  233. New Catera Website
  234. Just got the GM Service Manuals
  235. will the CTS motor fit.
  236. Burnt smell coming from engine
  237. Running Lights/Dome Lights
  238. Headlight problem
  239. Crankshaft posistion sensor: 97' cater, where is it located
  240. P0140 Code
  241. Catera/Omega Dash Kits
  242. New battery.....oil/water lites are still on
  243. light bulb change
  244. Check Engine Light On
  245. what is this symbol
  246. Burning DexCool
  247. New member and new Catera owner...
  248. Limited Slip differential- Who's interested.
  249. Rear brake rotors
  250. Anyone Selling Catera Rims?
