: Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28
  1. used BCM
  2. '98 catera rear window defogger
  3. Surprised by Year
  4. what's the word on welded alum rim repairs?
  5. Need part number for A/C line
  6. Catera Radio Software Compatibility
  7. catera rearview mirror
  8. Window Problem!!!!! HELP!!!!!
  9. What do you suggest, water pump? thermostat?
  10. Coolant Gauge Sensor Location??
  11. Problems With My Catera
  12. Cadillac Catera 1997 Question
  13. Dealing with complaint
  14. anyone run staggered wheels on your catera/omega-b?
  15. correct ID measurement for hub-centering rings to fit a catera?
  16. 98 Catera keeps cutting off once it gets warm Need Help
  17. Front bumper cover???
  18. what's a good aftermarket brake-pad that doesnt produce tons of dust? nt
  19. Code P100 or P0100
  20. Fog Light question?
  21. new grill...updated project & pics!
  22. 1999 Catera Stereo/Sound System
  23. What is a coil pack remover?
  24. ECM - Electronic Control Module
  25. Oil in the Coolant Resevoir
  26. Interior Lights and etc.
  27. Cadillac 2.8 Vvt V6 Engine 4x2 Trans Cts Gm Oem 2.8l
  28. Driver's door panel removal.
  29. How hard is it to replace an Alt. in a 98'?
  30. Check Engine Error Code PO411
  31. Spark Plug Change?
  32. oil pressure problem
  33. Battery Cable Replacement procedures - Help
  34. Catera Tires
  35. Alternator Removal Help Needed!
  36. transmission removal procedure 98 catera
  37. Steering-Loosing control over bumps?
  38. Bose Problem
  39. new grill fresh from german-land!
  40. transmission only goes into reverse 98 catera
  41. In Need of LH Side Mirror (glass only)
  42. Catera Clear Coat
  43. Possibly a bad EBTCM, What to do?
  44. Aftermarket timing gear or chain?
  45. External oil cooler
  46. 16 inch Wheels
  47. How to launch?
  48. gas mileage ?
  49. Replacing MAF - Instructions for an '01 Catera?
  50. Transmission: Range Switch
  51. Ipod to 98 bose
  52. speed sensor
  53. INTRAX Springs, Rear Rotors and Calipers. Few questions.
  54. radio shut down with loud volume
  55. BCM replacement
  56. Wheels
  57. Transmission Problems and the alternator?
  58. Park Gear shift Lock won't release
  59. Where's the audio section of this forum?
  60. Definitive answer on fuel door/trunk release inoperative
  61. Aftermarket Lights
  62. Car Bra??
  63. 3.2 Ebay MOtor Swap
  64. fender bender causing multiple problems?
  65. check engine light
  66. What's the Bottom Line on 98 Catera Timing Belt
  67. Best price on timing kit?
  68. Idle RPM - whats yours
  69. Lowering springs
  70. HID Light Help
  71. Performance muffler
  72. A little advice please A/C
  73. location of blower motor resistor?
  74. Ethanol issues?
  75. 1987 Cimarron
  76. '99 Catera starting problems
  77. Weird Noise Coming from front end
  78. A few performance questions
  79. 97 cat crapped out @ 72k miles
  80. Cat 98 Timing belt: news
  81. Opinions and any experience with RockAuto service?
  82. 3.0 VS 3.2 Catera/CTS
  83. rear sunshade problems
  84. Drilled/Slotted Brake Rotors For Sale
  85. Door Panel Removal
  86. Fuel Economy
  87. 20' Rims for my 2000
  88. Radio Problems
  89. 2000 Catera Sport Rims Fading!
  90. 2001 Won't Start - CPS?
  91. Setting up BCM
  92. 97 cat a/c compressor noise
  93. The best fuel system cleaner?
  94. Rain Leakage on Passenger Side - 98 Catera
  95. No skills + service manuals = i can fix my valve covers?
  96. Radiator Hose
  97. 98 chassis, 2001 motor swap?
  98. loose fuel door on '99 Catera
  99. source for aftermarket catera grills?
  100. Intake manifold gasket
  101. Air Condition Recharging
  102. 98 catera parts for sale: inner tie rod end and idler arm
  103. Coolant flushing
  104. Filling the Gas Tank (Time to read War and Peace)
  105. Intermittent starting problem
  106. wire Diagram for the gear shift position
  107. After market alarm please help
  108. XM radio woes
  109. Bought Catera before reading "Considering an older Catera? READ THIS>>!!
  110. Caliper Kit
  111. anyone interested in renting a timing belt kit?
  112. p0300, p0301, p0302 -> replaced MAF sensor
  113. '01 Cat - Check Engine Woes
  114. Lug Caps
  115. Catera EBTCM (Electronic Brake Traction Control Module) Part number please
  116. So tired of fog light irritation
  117. Timing Belt Kit TCK285
  118. CHK-ENGINE light came on, but no ODB2 codes?!
  119. Replacing a Transmission - 97 Catera
  120. Need help new to Catera
  121. Please HELP!!! Can't get Started!
  122. coolant color? & check engine light
  123. Wiring aftermarket alarm to open fuel door, can it be done
  124. Tire Balancing
  125. what style/spec of fuses are used in cateras?
  126. Where is the oil drain?
  127. PHOTO-ESSAY: removal of all on-star equipment from my catera!
  128. Audio's gone
  129. Brake Light Switch
  130. Oil Pan Removal
  131. Air inprovements
  132. Catera Dyno
  133. Leveling sensor-compressor
  134. Projector Headlights/Inspection
  135. 98 Cat Cooling - Radiator Cover Question
  136. Slick Car
  137. Drive in movies (what not to do)
  138. Problems with drivers side door lock
  139. Cadillac catera help
  140. Me again
  141. 1999 Cateras, and Maybe Newer Cats, Too
  142. HELP..............if you can!
  143. Smoke-out my head/tail lights
  144. Will not start after driving and parking for a while
  145. New Lights and Daytime Running
  146. 97 control arm bushings?
  147. Key in ingition, crank, no start?
  148. Anyone? Loose front brake pads
  149. New to the Catera and leveling
  150. what sort of summertime mileage improvements do you see?
  151. Can Anyone Tell Me What This Light Means?
  152. Radio trunk release and fuel door only work in gear. PLEASE HELP
  153. Want better gas mileage???
  154. Catera 4 sale
  155. Universal O2 Sensor vs OEM ($71 vs $250)
  156. dtc's (trouble code) diagnostics or sensor replacement details
  157. clock problem
  158. Fog Lights
  159. Horrible Vibration at 68-70mph
  160. air bag light
  161. Repair Manuals
  162. Entry?
  163. Sunroof
  164. gas?
  165. catera leaks ie oil & coolant
  166. Engine won't turn over?
  167. Behind the dash light bulb holder....
  168. "lumpy start-up" syndrome, various codes...
  169. 50k odo milestone
  170. Idle RPM fluctuation
  171. Do You Have Used Oem Brake Rotors?
  172. Power door locks
  173. Poor girl stranded! Need some help
  174. shifting points for 98 catera?
  175. Engine Swap or turbo
  176. Fuse Keeps Blowing
  177. fog light issue
  178. Belt Exploded and ripped out a wire.
  179. Info and opinions on 98 Catera (or any year for that matter)
  180. catera 97 - how to check transmission fulid level
  181. Possible to change the color of the dash lights?
  182. Couple questions for the pro's....
  183. Fuel pump replacement?
  184. oil leak
  185. Can I use laptop on Catera 97 Lighter outlet
  186. P0171 and P0172 ???
  187. Oil Pressure
  188. Weird Noise
  189. just got my CarChip/EX OBD2 data logger!
  190. Oil Levels
  191. had a problem today can anyone help!!
  192. a lil problem
  193. '85 Cimarron Concept Indy/Cart
  194. Cruise Control
  195. headlight questions
  196. Vacuum hose, P0171 & P0174
  197. Performance parts
  198. Aftermarket Alarm?
  199. Newbie Needs Help -speedo Inop?
  200. Different angle on low oil pressure
  201. how easy are lower control arms, idler arm and tie rod to replace?
  202. Could anything else go wrong with my Catera?
  203. Lights and gears
  204. Belt and Suspenders
  205. 98 catera with misfires?
  206. am I being overcharged???
  207. MAF sensor...$115 @ rockauto.com
  208. Misfiring everywhere!
  209. Car stays in High Beams
  210. anyone considered/tried removing the onstar system completely?
  211. low-profile replacment for OEM on-star antennae?
  212. OEM.. Wing spoiler install**Help**
  213. Brake pads, shoes, rotors, and sensor
  214. Speedometer and Tach goes out
  215. Head gasket or oil cooler
  216. Clunking over bumps & holes?
  217. 98 Cat intermittent stalling
  218. Extra Vacuum Line??
  219. P0171 and P0174 Lean Bank 1 and 2
  220. Satellite Radio
  221. Got some anoyine problems with my catera.
  222. I think the cat needed to take a crap today.
  223. Cheep! Cheep!
  224. Catera NEWBIE Questions - Interested in buying a Catera.
  225. Emergency brake assembly anyone?
  226. Engine is in , and now Low oil pressure?
  227. need help on 97 catera battery idle low
  228. Help for a new old catera shade tree mechanic
  229. Do you guys think Continental Warranty is a good idea?
  230. No More bose- New Headunit Qs
  231. Are all these cars posessed, or just mine?
  232. Catera Selector Cable (Shifter hard to move)
  233. Coolant leak
  234. Oil Pump Replacement Info requested
  235. 97 catera need help please
  236. Cigarette Lighter
  237. Well it looks like......
  238. goooodbye to yooou
  239. Anyone have this problem?
  240. Spark Plugs
  241. Shorting Throtle cable
  242. Need help finding a part...
  243. It's a good thing I enjoy working on it...
  244. anyone aftermarket their exhaust?
  245. Stoplight Switch PN 90563455 and now what?
  246. Catera Engine Change
  247. Catera Station Wagon?
  248. I am just full of questions
  249. What type of air intake?
  250. Question on type of gas for 98 catera
